Paging anyone with a 955 Sprint + a grease question
Discussion in 'UK Motorcycles' started by Jeremy, Apr 20, 2007.
  1. Jeremy
    Jeremy Guest
    Started working on the post-ambush repairs last night. Removed the
    bodywork to gain access, removed and then dismantled the hangers. All
    good so far (only one pingfuckit but that was recovered). The exhaust
    made contact with the tyre briefly when the incident occurred but
    bounced back a little - the clearance being I would say < 1cm.
    Can anyone take a ruler out and tell me what the gap between the can and
    the tyre should be? Is it OK to grab the can and simply pull it away
    until there is sufficient clearance? It doesn't feel like it wants to
    bend - it is very springy and i am concerned that if I pull too hard,
    something will fracture and I'll be looking at a bigger repair bill.
    Obviously it has been bent in one direction, all I want to do is to
    restore it to its original.
    Re grease - the footpegs and a couple of other items which are connected
    to the hangars appear to have some form of grease, so clearly a quck
    smear on rebuild is a good thing, is there any particular kind I should
    be looking for?
    cheers
  2. Jeremy
    A decent waterproof grease
    Castrol LM etc.
    Hog, Apr 20, 2007
  3. Jeremy
    Chris Sharp Guest
    This isn't the most scientific measurement ever taken, but the gap
    between rear tyre and the innermost point of the exhaust on my RS is
    roughly 6 cm.
    The rear brake caliper is mounted directly between the two, though -
    in order to get as close as 1cm, the can would need to be pressing
    right against the caliper, or even bent round it. So perhaps your ST
    is put together differently...
    Good luck getting it back in shape, anyway.
    Chris Sharp, Apr 20, 2007
  4. Jeremy
    It may not actually have bent anything at all. The whole can assembly
    is designed to swivel round, such that it can sit in a high-ish normal
    position or a much lower one if you have the Triumph panniers fitted.
    IIRC this is a single clamp on the pipe some way in front of the can
    itself, so it may simply be a case of loosening this and swivelling
    the can assembly back round to what looks like a reasonable position.
    _______
    Ace, Apr 20, 2007
  5. Jeremy
    Jeremy Guest
    Ah good point. Though the pillion hangers are rigid so the height
    adjustment as far as I can tell isn't variable (though I could be
    missing something but it seems like a pretty rigid arrangement).
  6. Jeremy
    Jeremy Guest
    Hmmm... mine's 3cm after a bit of tugging.. more effort required.
  7. Using the patented Mavis Beacon "Hunt&Peck" Technique, Jeremy
    Wicked Uncle Nigel - Podium Placed Ducati Race Engineer as featured in
    Performance Bikes and Fast Bikes
    Honda GL1000K2 (Falling apart) Kawasaki ZN1300 Voyager "Oh, Oh, It's so big"
    Wicked Uncle Nigel, Apr 20, 2007
