Paging anyone who'd happen to know what the correct tyre pressures are, for a CBR600FM
Discussion in 'UK Motorcycles' started by JackH, Oct 3, 2004.
  1. JackH
    JackH Guest
    As per the subject line.
    TIA
    JackH, Oct 3, 2004
  2. JackH
    Chris H Guest
    Correct? As in correct to the owners manual?
    36psi front
    42psi rear
    Chris H, Oct 3, 2004
  3. JackH
    SP Guest
    36 Front
    42 Rear
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Oct 3, 2004
  4. JackH
    JackH Guest
    Excellent, many thanks for the very quick response. :-D
    No wonder it felt a bit vague round a roundabout earlier!
    JackH, Oct 3, 2004
  5. JackH
    JackH Guest
    Ta
    JackH, Oct 3, 2004
  6. JackH
    Stonge Guest
    As I learned, it depends on the tyres. On my bandit6 the manual says 36/31,
    but Dunlop's site for the D207 says 41/36.
    So I opted for Dunlop's recommendation and improved the handling loads.
    Stonge, Oct 3, 2004
  7. JackH
    dwb Guest
    Is this standard for all Honda motorcycles?
    dwb, Oct 3, 2004
  8. JackH
    dwb Guest
    Hmm, just checked Bridgestone's site and apparently I should be running the
    014 at 42PSI in the back, rather than 36 - might have to give that a try.
    dwb, Oct 3, 2004
  9. JackH
    Seems to be pretty much standard for all modern road bikes over 600cc.
    Pip, Oct 3, 2004
  10. JackH
    spida Guest
    I did that with 010s after switching from Corsas - the worrying thing
    is I never 'felt' anything was wrong. Maybe 6 PSI isn't enough to make
    a real difference for road riding.
    spida, Oct 3, 2004
  11. JackH
    dwb Guest
    Yeah - manual does say 36/36 though. Certainly nothing 'wrong' with 36 -
    suspect I won't notice a difference with 42 TBH but I shall see.
    dwb, Oct 3, 2004
  12. JackH
    dwb Guest
    Um, okay. If you say so.
    dwb, Oct 3, 2004
  13. JackH
    Salad Dodger Guest
    No.
    Nor is it standard for all tyres fitted to any particular Honda (or
    any other) motorcycle.
    | ___ Salad Dodger
    |_\_____/_| ..73025../..16437.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR-Visited:83 Pts:1800 Miles:6890
    Salad Dodger, Oct 3, 2004
  14. JackH
    Mo Guest
    And one exception appears to be the Suzuki SV650 at 33/36
    Mo, Oct 3, 2004
  15. JackH
    dwb Guest
    Most Suzuki's seem to be the exception.
    dwb, Oct 3, 2004
  16. JackH
    dwb Guest
    Ah okay - just seems the CBR is 36/42. The hornet I had - 36/42. The VFR I
    had - 36/42...
    dwb, Oct 3, 2004
  17. JackH
    Salad Dodger Guest
    With Dunlops, Bridgestones, Avons, et al?
    GL1500:
    Dunlop/Metz. 33/36
    Bridgestone 38/42
    Avon 36/42
    Michelin 34/38
    | ___ Salad Dodger
  18. JackH
    Female, innthey? Pear-shaped, like.
    Pip, Oct 3, 2004
  19. JackH
    dwb Guest
    Considering there's usually at least one tit on top, you could be right.
    dwb, Oct 3, 2004
  20. JackH
    When my brother first got his R1150R, he set the tyre pressures exactly as
    specified in the handbook. However, there was a misprint in the handbook,
    so the spec was 2.8 (IIRC) bar, but the conversion given was the multiplier,
    not the actual pressure. So he did the first thousand-odd miles with the
    front on 14.5 PSI...
    platypus, Oct 3, 2004
