Paging any migraine sufferers. Got a good relief tip?
Discussion in 'UK Motorcycles' started by Mike Barnard, Apr 28, 2006.
  1. Mike Barnard
    Tom Warner Guest
    Diclofenac and other NSAIDs don't do anything for mine.
    Pain killers (including opiates) have never worked.
    The only thing I've found that works is Ergotamine, so I take Migril.
    <http://www.netdoctor.co.uk/medicines/100001665.html>
    Tom
    Tom Warner, Apr 29, 2006
  2. If she is at that stage it's largely too late..
    Nurophen Plus - I take 3 N+ with a glass of milk and go back to sleep.
    I take sumatriptan - but it's a prescription-only drug - and like most
    of them needs to be taken when the first symptoms start.
    Taking enough codeine-based painkiller so that I go to sleep. That's
    about the only thing that works if I don't take a sumatriptan quickly
    enough.
    I avoid paracetamol both because of the rebound effect and the fact
    that it doesn't seem to work too well on me..
    Phil
    Phil Launchbury, May 2, 2006
  3. They can help - they contain codeine and paracetamol along with a type
    of antihistamine.
    They don't work particularly well for me but I suspect thats because I
    don't react well to paracetamol.
    Phil
  4. Too much coffee.
    Too little sleep.
    Cranberries..
    Phil
  5. Pain relief - most people think that migraines happen with abnormal
    blood flow in the brain (the blood vessels overdilate causing the
    pain - the triptans work by being a selective vasoconstrictor within
    the brain).
    The NSAIDs work because they short-circuit the pain responses - the
    asprin/nurophen in the site of the pain and paracetamol within the pain
    centre in the brain[1][2].
    Phil.
    [1] Which is why rebound pain is greater with paracetamol - the pain
    messages are still being sent by the source. Because the central pain
    response is being blocked the source nerves ramp up the volume. Once
    the central supression wears off the increased level of signal gets
    through. Or at least that is how my arthritis doc explained it..
    [2] As far as I can remember anyway..
  6. It not contrriction - migraines are caused by over-dilation of the
    blood vessels in the brain (they think anyway..). Which is why
    selective vasoconstrictors like sumatriptan work.
    Phil
  7. Hmm.. - asprin and morphine. That would work.
    Phil
  8. Mike Barnard
    I did a bit of work on that one, you know (actuially I may have
    mentioned it before). Got a crappy little clock to prove it an' all.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, May 2, 2006
  9. Some of have holidays y'know..
    Phil
  10. Or a large bar of chocolate, a gallon of coffee and a bag of oranges.
    Phil
  11. Mike Barnard
    deadmail Guest
    I'm sure you need to include a pair of tights in there somewhere.
    deadmail, May 2, 2006
  12. Mike Barnard
    There are times, you know, when I'd be really interested to know how
    your mind works.
    At other times, like now, I'm _so_ glad I don't.
    _______
    Ace, May 3, 2006
  13. Tights? They don't give me migraines.. allegedly.
    Phil.
    Phil Launchbury, May 3, 2006
  14. Mike Barnard
    Thankfully not.
    _______
    Ace, May 3, 2006
  15. <small voice>
    Likewise
    </sv>
    Phil
  16. Mike Barnard
    Ace, May 3, 2006
  17. Mike Barnard
    gomez Guest
    Sounds like a permanent cure for migraine, to me.
    gomez, May 3, 2006
  18. Mike Barnard
    Well of course I could post anything about anything and expect you to
    get the 'reference', but normally it implies that there is some
    connection between a new posting and what's gone before.
    It's like, you know, a _conversation_? Where each statement relates to
    the last? Otherwise it's what's known as a 'non-sequiteur'.
    _______
    Ace, May 3, 2006
  19. Mike Barnard
    well, it would, wouldn't it.
    I'm happy for the both of you.
    _______
    Ace, May 3, 2006
  20. Err.. it's a list of the most common migraine triggers.. (aka the Three
    C's[1])
    Phil
    [1] Chocolate, coffee and citrus
