steam: [URL]http://games.slashdot.org/article.pl?sid=07/10/25/1845228[/URL]
Heh. I've been in NY for the last week but I guess I'd better check if it still works! Looks more like slack programming on Valve's part if they were able to buy an out-of-region version from within that region, especially as you need to run Steam to buy.
Not strictly true.. you need steam to register but they could have bought a boxed copy if the softeware.
Yes, we've discussed it in other threads. The Striders? I thought it was tough until I figured out the easy way to do it!
I didn't want to give too much away, just in case. Striders come with two Hunters, so just mow them down while in the car as it saves the hassle of trying to kill them; one fast blow will finish them off. The Striders are a bit dumb and rely on the Hunters to pick you off as they can only "see" forward. The best way to tackle them is to, in the best UKRM tradition, take them from behind. Just beware that once you've thrown the bomb at them, they will turn and shoot so you need to be quick in swapping guns and shooting the bomb. I get in the car and drive around and attack from behind. The Strider will blissfully continue walking to the target while you dispatch the Hunters (be quick though as they're intelligent enough to run for the trees and/or hide once they figure out what you're doing!) and you can then take them out a well.
Nope, never had a response to my Call For Beers. I did meet another friend while over there though, and had to ride the F-train to Brooklyn! Scary!
