Paging antonye
Discussion in 'UK Motorcycles' started by ogden, Sep 25, 2007.
  1. ogden
    platypus, Sep 26, 2007
  2. ogden
    I'd guessed it was something like that, but one each side seems a bit
    OTT.
    darsy, Sep 26, 2007
  3. ogden
    antonye Guest
    I'm sure it was designed to go round left-handers
    just as well as it does round right-handers, YTC.
    antonye, Sep 26, 2007
  4. ogden
    what I meant is, why can't both forks share a centrally mounted
    reservoir - it's not like your actually going to want different
    pressures in them, is it?
    darsy, Sep 26, 2007
  5. ogden
    antonye Guest
    No use back-pedaling now!
    I would presume it's because the bit that needs the gas
    is located at the axle, which makes it difficult to run
    a line between the two without going up and over the wheel.
    It would then require a reservoir mounted somewhere near
    the yokes at the headstock and taking up space - there's
    also an air duct in that region that probably fills all
    the available space anyway. Don't forget that the lines
    would have to move with the wheel as you're going from
    static to moving (headstock to axle) so you then end up
    with flexing lines, chafing problems and more points of
    failure.
    Besides, it looks cool, ok?
  6. ogden
    why didn't you just say that in the first place - that's by far a more
    convincing argument for me than all that technical crap.
    darsy, Sep 26, 2007
  7. ogden
    antonye Guest
    Stupid boy, this is UKRM!
  8. Just like the Morris Minor Centre in Bristol can build you a brand new
    Moggie if you want them to. Other than gearboxes - some bits of them
    are like gold dust (apparently).
    Phil.
    Phil Launchbury, Sep 26, 2007
  9. ogden
    Looks like a bad tempered tree frog.
    sweller, Sep 27, 2007
