Pagaing TOG - even though you don't rate 'em....
Discussion in 'UK Motorcycles' started by WavyDavy, Nov 15, 2003.
  1. WavyDavy
    WavyDavy Guest
    ...... How much would you suggest is a 'fair, market price' for a Honda
    NS400R?
    I've just seen one which is virtually standard, but has 35k on the clock,
    but has a 12k, receipted[1], engine in it, with new rings etc and the old
    engine 'for parts'.
    It also had corrosion on the *outside* only of the fork legs and has a few
    blemishes, which is what I'd expect off a 16 y.o. stroker.
    The rad fan is operated off a manual switch, which is a worry, but apart
    from that and the cosmetic minor blemishes it seems good for the age.
    The joker is asking £1850, I was thinking of offering max, £14-15 hundred.
    What do you think, ignoring the whole fact that you don't like 'em anyway?
    TIA
    [1] The engine is receipted and I don't doubt the seller's honest, but how
    can I trust the breaker (unnamed) he got the 'new' engine from....[2]
    [2] And how do I know it ain't cobbled together unlike std NS engines with
    their balanced pistons & cranks & stuff [3]
    [3] The throttle is v v heavy which I'm not sure of - is it easy to
    accidentally route the cables so it feels light on the first1/4 and stiff
    for the rest of the turn, or is it, as I hope, just a crappily lubed
    throttle on a bike that has done only 300 mile in the past 18 months.....
  2. Avoid.
    Avoid, avoid, avoid.
    The Older Gentleman, Nov 16, 2003
  3. WavyDavy
    WavyDavy Guest
    message
    Ta for that! :)
    Had guessed you might say that. Just out of curiosity why don't you rate
    'em? Is it a stroker thing or have you had some bad experiences with NSs?
    If I were to change tack and start looking at RD/RZ500s or Gamma 5s would
    the answer be the same?
    What (reasonably) large capacity (for a two stroke at any rate) would you
    recommend, if any?
    TIA
    WavyDavy, Nov 16, 2003
  4. They blow up. The one I rode blew its gearbox under me.
    H1, H2.....
  5. WavyDavy
    WavyDavy Guest
    Never had any trouble with my previous two... Maybe I was lucky (the first
    one was from the original Honda UK test fleet - I know this as i saw a pic
    of it's plate in an old bike mag article. Strange how that was considerably
    quicker than the second......)
    So which one then? I've never been a Yam stroker fan and I know that Gammas
    had a habit of eating 2nd gear, but just wnat (as opposed to need) an 80s
    race rep stroker again.
    When the missus inherits her squillions I intend to have a whole garage of
    stuff like that, but for now want a (two stroke, more than 2 cylinders) bike
    I can ride (almost) every day and still take on the track without it making
    me look too shabby.. [1]
    [1] Yes, yes, I know. A CG125 would make me look shabby with my shite
    riding, etc etc etc :)
  6. That was the one I blew up. They must have repaired the gearbox and then
    flogged it.
  7. WavyDavy
    The Older Gentleman said....
    ROFLMBO.
    Lozzo
    ZZR1100D, GPZ500S, CB250RS x3
    BotToS#8, GP#2, SBS#10, SH#3, DFV#14, KoBV#3.
    http://www.glfuk.com/ for MJK Leathers in the UK.
    Lozzo, Nov 16, 2003
  8. WavyDavy
    mups Guest
    Never ridden an NS400 so can't comment but I did own an RD500 for a few
    years and have ridden a few RG500's. IMO the RD500's a better bike. OK so
    it's not as fast but it's much better built and doesn't have the habit of
    blowing up quite so often. I did 15000 miles on mine in standard tune and
    5000 with a Stan Stephens stage 3 motor. The only problem I had was the
    rear pots nipping up when the oil pump cable snapped.
    For a large 80's 2 smoke I'd get an RD500, fit 17" FZR600 wheels and
    forks[1] and get some decent exhausts[2]
    [1] They drop straight in apparently
    [2] The original ones are very restrictive and weight a ton
    mups, Nov 16, 2003
  9. Coo, it's a small world, innit?
    GS 850 x2 / SE 6a
    SbS#6? DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Nov 16, 2003
