Ow.
Discussion in 'UK Motorcycles' started by Nigel Eaton, Feb 24, 2004.
  1. Nigel Eaton
    I've done the chuck key thing on several occasions. Also done the wander
    off and come back to tortured screaming to find the tool now attempting
    to face off the chuck.
    Apprentice entertainment was to get a roller bearing (about 4-5" dia)
    spinning using air then drop it on the floor. First one on the bench was
    a wuss, last one out the pit had smashed ankles.
    I wonder why I "resigned with a reference".
    sweller, Feb 25, 2004
  2. Nigel Eaton
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, sweller
    Blerk I knew did that one day for a laugh (with a smaller bearing) and
    got it spinning to the point where the outer cage let go. He survived,
    the fate of his underpants is unrecorded.
    Nigel Eaton, Feb 25, 2004
  3. May I just say OUCH - I presume he kept the hand but scarred?
    Boots Blakeley, Feb 25, 2004
  4. Nigel Eaton
    Zobo Kolonie Guest
    So did mine (they made injection moulded plastic wot nots too).
    [Snip gruesome tale of molten glass]
    My dad told me that one day one of the blokes operating an injection
    moulding machine thingy overrode the safety device so that he could speed up
    his work and managed to press the go button with his hand still in between
    the two halves of the mould. Apparently those moulds come together with
    several tonnes of pressure, so no more hand!
    I've seen a chap wearing ordinary shoes have his foot run over by a forklift
    truck. No loss of limb but he wasn't very comfortable for a few weeks
    afterwards.
    A bloke I worked with managed somehow to get his tie caught in the shredder,
    which even he saw the funny side of once he'd got some oxygen back into his
    system.
    One time at work we lost all power to the main computer room, which was odd
    because it was on its own independent supply... off I toddled downstairs to
    the cupboard where the leccy pipes came into the building only to find one
    of the maintenance men flat on his back making "nnrrrr nnrrr" noises and
    looking rather dazed. He was holding a drill with a somewhat molten blob
    where the drill bit usually goes. It turns out that he'd managed to drill
    straight into a big cable... though he later claimed "it wasn't me" (which
    did make I laugh).
    Then there was the chap who was inspecting an asphalt mixing machine when
    the operator let rip with a quarter of a tonne of the stuff, oooh, not
    comfy, though he survived remarkably intact.
    One of the more gruesome industrial accidents that I've read about was that
    of a chap working on a nuclear reactor thingy, ISTR that it was an
    experimental reactor. Anyway something wasn't working properly and it was
    all going badly wrong so they decided to perform an emergency shutdown (they
    'scrammed' the reactor). Well the scram didn't work, the control rod
    mechanism wasn't pushing the moderators back into place, so this chap
    toddled off to stand on top of the reactor vessel and manually scram the
    reactor by winding a winch wot not to push the control rods back down
    between the fuel rods. Unfortunately he was too late. The reactor went pop,
    not Chernobyl style pop, but pop nevertheless. When his body was recovered
    his torso was found spiked to the ceiling by a rod, and all of his remains
    bar one of his legs had to be taken away and disposed of as radioactive
    waste, the remaining leg was buried in a shielded coffin. (This might sound
    like a tall story, but I'll dig out my references if I have to).
    Zobo Kolonie, Feb 25, 2004
  5. Nigel Eaton
    [snip industrial accidents]
    Don't forget the guy who fell into the lens grinding machine
    and made a spectacle of himself.
    CT, Feb 25, 2004
  6. Nigel Eaton
    flashgorman Guest
    <snip accident tales>
    <fx: looks at paper cut. Decides to keep stum>
    flashgorman, Feb 25, 2004
  7. Hang on, me being dense here, I'm sure - did they stitch his hand
    onto/into his stomach? Or take the skin off his stomach and put it on
    his hand...?
    Power Grainger, Feb 26, 2004
  8. AIUI I guess the technique Rope is describing is where the skin to be
    grafted is left connected to the donor graft point until it's started
    growing at on the injured area. IIRC this was done with a work
    colleague some years back who needed a graft on his elbow. The initial
    tries with draping skin from his arse on the wound didn't work, so he
    spent some time in hospital whilst a live transfer took place.
    Boots Blakeley, Feb 26, 2004
  9. Nigel Eaton
    But afterwards, could he tell his arse from his elbow?
    CT, Feb 26, 2004
  10. Nigel Eaton
    It's called a pedicle, and was much used before micro-surgery was
    refined to where it is today. It is _not_ a skin graft, but involves a
    flap of flesh, which is generally taken from the stomach area. In
    t'old days (20+ years ago) they'd carefully cut it and roll it into a
    tube, leaving major blood supply to it intact, then attach the other
    end to the part needing repair, where it would establish new capillary
    connections within a few weeks, at which point it would be cut off
    from the original area completely.
    In some cases, the flap would have been moved three or more time, for
    example, stomach-wrist, wrist-good leg, good leg-bad leg, before many
    more ops to smooth and stretch the new flesh over the wounded area.
    The original area is just left as a nasty scar, although genuine skin
    grafts[1] are used to cover it up.
    My ex had more than 20 ops over two years, then a couple more some
    years later, to mend a nearly-amputated leg.
    [1] Just the epidermis, shaved off with an instrument very much like a
    potato-peeler and laid over the exposed area to form a seal while
    healing, and scarring, takes place.
    Ace, Feb 26, 2004
  11. Nigel Eaton
    FISHWAVER Guest
    They use puppies?
    FISHWAVER
    XL1000V
    as the ocean tastes of but one thing, salt, so the truth has but one
    flavour, that of freedom
    FISHWAVER, Feb 26, 2004
  12. Nigel Eaton
    gomez Guest
    Paper cut, was it?
    gomez, Feb 26, 2004
  13. <snip gruesome newklear plastic powered ashphalt forklifts>
    When I were but a lad in my first job at a steelworks there occured a
    terrible axledunt in which one of the molten-steel-carrying crucibles
    upended in the wrong place and poured the contents all over 3 blokes
    standing on the furnace shed floor.
    Raised the carbon content a bit.
    I was told (though I don't know if this is true) that a geezer threw
    himself into the furnace one nightshift; he went on to become part of
    the British car industry.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Feb 26, 2004
  14. Nigel Eaton
    Zobo Kolonie Guest
    Eeeep! Lucky bastard!
    Unfortunately computer related stories don't usually make such good reading,
    but here's a few:
    Myself and my oppo were hauling the mother of all line printers out of the
    machine room one day, shit that thing was *heavy*. Well the room had been
    designed by our bossman, who was a little squirt of no more than 5'5" I
    reckon. Myself and soft-lad are both over 6ft. So what happens? Soft-lad
    stands up as we finally manage to win the battle twixt gravity and the
    mother of all line printers when he bangs his head on one of the big red
    emergency stop buttons.... ooops! Standing there in total darkness as the
    room slowly died (sounds of disks spinning down etc) we didn't really give a
    toss that we'd just wiped out most of our European IT facilities, oh no, our
    first concern was how the **** we were going to get that brute of a printer
    back onto its stand without dropping it on ourselves :)
    Some time later said mother of all line printers was installed in our
    accounts building (we got it moved from building to building by forklift)
    when it developed a minor fault. We called in the maintenance contractor, a
    *huge* chap of 6'9" and about 30 stone. Him being a bloody Titan what did he
    do? He just picked it up and wandered off down the office with it. Ah, but
    him being a clumsy oaf too what else did he do? Totally ignored the fact
    that the fucker was still wired in and actually printing at the time....
    *kerunch!* Not a happy moment for some, but oh how me and soft-lad laughed
    Then there was the time that a cow-orker of mine was testing some new mail
    distribution thingy she'd developed, whatever. Erm, 'whatever' included her
    test messages being delivered to all mail recipients enterprise wide,
    including external clients... tens of thousands of recipients at the very
    least, maybe hundreds of thousands, possibly over a million. Because it was
    taking so long for her stuff to come back to her mailbox she assumed that
    she'd done something wrong, so she was sat there going through and testing
    it again and again. It worked perfectly each and every time... ten or more
    times she sent out her test message... which thankfully she had literally at
    the last minute decided to change from summat like "**** this I am fucking
    bored I want a fucking beer" to something a less offensive :)
    Then there was the time that the development director issued my code to the
    client test platform before I'd Ok'ed it... thank **** I had at the last
    minute changed a certain 'supposedly-impossible-to-reach' error message from
    something like "**** **** bollox and wank, this should never happen" to "Oh
    Bugger"... they still weren't impressed, but it was funny :)
    I'll stop there (for now).
    Zobo Kolonie, Feb 27, 2004
  15. <G>
    Boots Blakeley, Feb 27, 2004
Similar Threads
Loading...
