oversized bearings needed
Discussion in 'Motorbike Technical Discussion' started by aggie, Mar 21, 2006.
  1. aggie
    aggie Guest
    i have a 1938 UL (Harley Davidson flathead 80") and i need oversize
    connecting rod bearings. my motor came with an FL crankshaft assembly
    with a tapered pin and not the step pin that a stock UL crankshaft
    would use. i have not had any luck finding bearings that are half a
    thousandth oversize so far and if anyone has a source i can get em from
    or a set they will part with i would be very happy. Thanks
    aggie, Mar 21, 2006
  2. ROLLER/TAPER/SHELLS? i have a bearing book that lists every bearing
    size, application made, if roller, deep groove, or taper roller, number
    from case please, not a harley man, but have seen rod set up, if needle
    rollers still may be asble to help with fractional sizes.
    jimmy
    jimrichards1964, Mar 22, 2006
  3. try FAG AUSTRALIA PTY.LTD, thats where my books from, it also cross
    references
  4. aggie
    aggie Guest
    thank you for the source...
    aggie, Mar 24, 2006
