Overheating - Bike Stalling
Discussion in 'Australian Motorcycles' started by ambition80, Feb 11, 2008.
  1. ambition80
    ambition80 Guest
    Gidday,
    I have an '99 CBR600F4. That I have owned since Jan '03. In this time
    I have never replaced the battery. The bike starts first time fine
    every day ( I commute to work ) with no issues, fires first time every
    time.
    In Sydney's traffic ( back to school grid lock ) and the heat the last
    few weeks the bike has been running hot, the fan kicks in ( as it
    should ) but then the bike has trouble maintaining idleing revs and
    when you apply throttle it stalls.
    When the bike stalls I can't start it again, the bike turns over but
    doesn't fire. The fan is still blowing. I am able to jump start it
    easily enough though.
    The idle revs is usually around 1200-1500 rpm, When it's hot it drops
    to under 1000 and possibly closer to 800 or so rpm. You hear the bike
    almost stall, but it corrects itself as it should. When you then go to
    take off, it's almost like it's choking of fuel or not enough power to
    fire the spark plugs.
    Basically I have been sitting at lights or in traffic holding the bike
    at 2000 rpm to stop it from stalling at low revs.
    Is this possibly an old battery with not enough juice to handle the
    load of the fan and a hot bike. Or is it something else? The bike is
    serviced every 6000km as scheduled, it's currently still got 2000km to
    the next recommended slot.
    Cheers
  2. ambition80
    Theo Bekkers Guest
    Sounds like your fuel is vapourising in the lines to me.
    Theo
    Assuming carburettors are fitted.
    Theo Bekkers, Feb 12, 2008
  3. ambition80
    ambition80 Guest
    Yes it is a carburettored bike.
    Is this just because there so hot, would a service remove this issue?
    I have noticed this bike has always run hotter than my previous '98
    CBR600 F3.
    Cheers
    ambition80, Feb 12, 2008
  4. ambition80
    Theo Bekkers Guest
    Possibly, if it is tuned incorrectly, it will run hotter tha it should. Is
    it possible to re-route the fuel lines so that they run in a cooler area. A
    lot of bikes have fuel-lines that cross over behind the engine. This can
    cause the problem you describe. If possible run the line from each side to
    the nearest carb or carbs. The fan is possibly making the problem worse when
    it comes on by blowing hot air over the engine area.
    Theo
  5. ambition80
    JL Guest
    I'd be suspecting the alternator / battery myself - sounds like
    insufficient charging current. It'd be worth checking what current is
    being generated.
    JL
    (but it's only a guess)
    JL, Feb 12, 2008
  6. I'd be suspecting the alternator / battery myself - sounds like
    being generated.
    I agree. Stick a multimeter on it. Easy enough for it to be the first thing
    you check.
    Fraser
    Fraser Johnston, Feb 12, 2008
  7. ambition80
    NagaThai Guest
    In my experience - take the simple things first.
    Check the electrics here with this .....
    www.electrosport.com/Images/fault_finding.pdf
    Important for you is the charge voltage of the chart in the first instance.
    NagaThai, Feb 12, 2008
  8. ambition80
    Theo Bekkers Guest
    What have you done to the attributes Fraser?
    If it turns over but doesn't fire it may be low on battery but surely would
    have enough to run the ignition without the starter motor. ??
    Theo
  9. True. But a multimeter takes 2 seconds to check.
    Fraser
  10. ambition80
    Theo Bekkers Guest
    Only if you know what you're looking at. :)
    Theo
  11. ambition80
    I'm on the fuel bandwagon instead of the alternator/battery one.
    Easy enough to check though; just find the temp sensor and pull the wire
    off.
    Now; with the bike running ground the wire. Does the fan start?
    OK; now get the bike warm and idling smoothly and then ground the wire.
    If it upsets the idle you've got an electrical problem, if it still idles
    smoothly look to fuel/carbs.
    You may also wish to pull the four sparkplugs (don't mix them up) and see if
    one looks different to the others (burnt, sooty or oily).
    Check the vacuum line to the fuel-tap for cracks or perishing and drain the
    carby float-bowls (then turn the tap to 'prime' and flush them through with
    clean petrol).
    If that doesn't fix it it gets trickier from here on......
    Knobdoodle, Feb 12, 2008
  12. ambition80
    Yeebers Guest
    A multimeter isn't it ? That's what it looks like ..
    Yeebers, Feb 12, 2008
  13. ambition80
    Theo Bekkers Guest
    Hehe, I was envisioning the OP looking at a multimeter, after asking the
    Dick Smith person to show him where they were.
    Theo
  14. ambition80
    Damien Guest
    If it's a Honda and you suspect the battery, I'd be giving the reg/rec a
    good examination as well, given their reputation for failure and the
    implications that has on battery life/performance.
    Damien, Feb 14, 2008
