Overfilled with oil - what to do?
Discussion in 'UK Motorcycles' started by Dave Jennings, Jul 16, 2005.
  1. Arse. This morning I'd changed the oil in the VS, and being brain
    dead/hungover put in the full 5l instead of the 4l of oil I was
    supposed to. Is is that big a deal, or should I drain the extra off
    just to be safe? Is too much oil as bad as too little?
  2. Dave Jennings
    Tim-mz500r Guest
    Drain it out too much oil not good :(
    Tim-mz500r, Jul 16, 2005
  3. Dave Jennings
    Get it out. Too much oil can lead to foaming (not good) and/or the
    excess going up the crankcase breather into the airbox & getting sucked
    into the top-end (hydraulic lock = bent valves/conrods).
    A turkey baster down the fill hole[1] is your friend.
    [1] No, that isn't a euphemism.
    Krusty, Jul 16, 2005
  4. Dave Jennings
    Krusty says...
    A Mytivac does the job nicely too, if you have one. They are also
    useful for bleeding brakes and filling forks with oil to the correct
    level.
    Lozzo, Jul 16, 2005
  5. Dave Jennings
    And syringing yer lug-holes.
  6. Lozzo wrote
    Please try and restrict yourself to just the one helpful tip a day if
    you please sir, no matter how useful they are. We don't want you over
    exerting yourself do we now.
    steve auvache, Jul 16, 2005
  7. Dave Jennings
    steve auvache says...
    Over-exertion is not something I do often.
    Lozzo, Jul 16, 2005
  8. Dave Jennings
    Molly_Thai Guest
    Use an angle grinder to cut a slot in the crankcase.
    Molly_Thai, Jul 16, 2005
  9. Dave Jennings
    Monz Guest
    If you cut the slot horizontal at the fill level you will never need to
    worry about overfilling again :eek:)
    Monz, Jul 17, 2005
  10. Dave Jennings pretended :
    It is......
    You risk the additional crankcase pressure blowing seals as well as oil
    being sucked into air box. The quick way to solve it is by draining the
    surplus out via the sump plug into a clean bowl, then put it back in to
    the correct level.
    Harry Bloomfield, Jul 17, 2005
  11. Dave Jennings
    Molly_Thai Guest
    Good idea Mr. Monz. It would also be useful when racing, just lean the bike
    into a bend and...
    Molly_Thai, Jul 17, 2005
  12. Dave Jennings
    Phil Kyle Guest
    Filth!
    Phil Kyle™
    Uno
    Dos
    Tres
    Cuatro
    CINCO!!!!!!
    "Be very aware that my willingness
    to continue to criticise your sig
    is infinite." -- Neil Barker
    Phil Kyle, Jul 17, 2005
  13. Dave Jennings
    SimonJ Guest
    What is the dipstick telling you? (I mean the one in the engine, not Kyle)
    Personally, I don't think 1l will do any harm.
    SimonJ, Jul 18, 2005
  14. Dave Jennings
    Nick Guest
    I would definitely drain some off if its that much over the top...... maybe
    1/4 or even 1/2 but a litre over..... drain it and sleep better ! will
    only take a few moments
    Nick
    Nick, Jul 18, 2005
  15. Dave Jennings
    andrewpreece Guest
    I overfilled a car once. I managed to get some distance befre I was engulfed
    in choking clouds of blue smoke. I was in the centre of town and the
    pedestrians
    were unamused too. Drain some out.
    Andy.
    andrewpreece, Jul 19, 2005
  16. As the 4l means "fill from bone dry" and there's likely to be still half
    a litre swilling around inside it after an oil drain, it's probably
    one-third overfilled. Drain the excess now.
    The Older Gentleman, Jul 19, 2005
  17. I agree with Nick, 1 litre over is much too much (that's 25% more, isn't
    it?).
    You may get oil in your air filter, rendering it useless. Oil may leak past
    your crankshaft rear oil seal, and get on your flywheel and clutch pressure
    plate (resulting in clutch drag). Oil may leak past your valve guides,
    causing increased carbonisation of combustion chambers, etc...
    Have I frightened you? Good!
    Sylvain (retired mechanic)
    Sylvain Van der Walde, Jul 19, 2005
  18. Dave Jennings
    zymurgy Guest
    Heh, I did this on the 12R. The spec said 4L, so I dropped in 4L. (it
    was a filter off job too)
    It was rather full ! but not way more than over the window.
    Got me there and back to Chimay.
    Which was nice
    P.
    zymurgy, Jul 19, 2005
  19. Dave Jennings
    The pukka Kawasaki manual for the 7R quotes 3 quantities:
    - oil change
    - oil and filter change
    - dry engine.
    Champ, Jul 19, 2005
  20. Dave Jennings
    'Hog Guest
    I'm in pain here remembering Shane and the K1100 who interpreted a black
    sight glass as still needing oil. I drained about 8L out of the 4L sump
    <snort><wince>
    'Hog
    'Hog, Jul 19, 2005
