over-inflated tires?
Discussion in 'Motorbike Technical Discussion' started by Dallas, Apr 19, 2004.
  1. Dallas
    Dallas Guest
  2. Dallas
    OH- Guest
    <snip>
    The centre will wear more than the sides _but_ it will still wear
    slower than a normally inflated tire because it will run real cool.
    Some people will pump the tires right up to the maximum for
    fast motorway transport to save rubber for the twisties at the
    far end of the trip. Do not try this if you don't understand the
    trade of in grip and handling and think it's safe enough.
    OH-, Apr 20, 2004
  3. Dallas
    Matt Whiting Guest
    Why the difference? I've never heard this before and it doesn't make
    sense at first blush. Can you explain?
    Matt
    Matt Whiting, Apr 20, 2004
  4. Dallas
    Matt Whiting Guest
    I buy that, but unless you live in a place with lots of really curvy
    roads, you will spend most of your time within 10 degrees of vertical
    and that isn't going to wear much of the sidewall. I've always run my
    tires on the high side, but never above the max that the tire maker
    allows, and I tend to get decent mileage from both ends and good
    handling. You do sacrifice a little ride, but for the most part I
    didn't find that too objectionable.
    Matt
    Matt Whiting, Apr 21, 2004
  5. Dallas
    Matt Whiting Guest
    I've worn out several sets of tires and I've never seen a motorcycle
    tire ever wear out first anywhere but the center of the tire.
    Matt
    Matt Whiting, Apr 22, 2004
  6. Dallas
    Matt Whiting Guest
    The topic was under or over inflation, not racing.
    Matt
  7. Dallas
    Matt Whiting Guest
    That is my experience as well.
    Matt
    Matt Whiting, Apr 23, 2004
