OTish: FOAK: Cordless drills
Discussion in 'UK Motorcycles' started by Whinging Courier, Apr 26, 2006.
  1. What's hot and what's not?
    I installed a big FOAD ground anchor with the help of Robbo and his
    equally FOAD SDS drill but now I have bought one of these:
    http://www.thebikebarn.net and this also requires the bolting-down-to-
    the-ground scenario.
    So, I want a cordless drill because it's obviously portable and one
    doesn't have to faff around with wires but I'm thinking that maybe
    they're a bit crap compared to their corded counterparts.
    I do need a drill and I've been putting it off for ages but what's the
    best type to get? Is 24v better than 18v better than 12v? Also, is a
    cordless drill going to be man enough to drill through concrete for more
    than a couple of minutes or should I just **** the whole idea off and
    get a corded?
  2. Whinging Courier
    Buzby Guest
    I bough a B&Q an 18v 'Pro 3 Gear Cordless Hammer Drill' - seems to drill
    through anything pretty well [1] - has an 19 point torque setting on the
    screwdriver and a nice torch in the battery cover which is suprsingly
    useful. Came with two batteries, charger and a nice shiny case. Half price
    in the sale £49.50
    [1] drilled a few holes right the way through the house double layer brick
    walls with no problem
    Buzby, Apr 26, 2006
  3. Whinging Courier
    Switters Guest
    Most of the issues with drilling are down to having the right drill bit.
    Masonry bits are shit for going through metal etc. For really solid stuff
    (like concrete), I've found that a hammer drill makes light work of it.
    More volts is good, as can be rpm, but you don't need **** off revs to go
    through concrete.
    The one this I miss with mine is having and extension arm that stops you
    drilling at a certain depth. That can be dead handy.
    Switters, Apr 26, 2006
  4. Whinging Courier
    SP Guest
    A cordless drill will do the job no problem - providing you are using
    the correct type of drill bit for the material you are drilling the
    holes in :eek:)
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Apr 26, 2006
  5. Whinging Courier
    But if it's French concrete a cordless, or indeed any normal corded,
    drill will have no chance. More revs don't help, and a standard
    hammer-action won't do it either. Electro-pneumatic is the only way to
    go.
    Of course, for soft-as-cheese british concrete, you'l probably get
    away with it with a cordless, but it _will_ still be a lot of effort
    without any hammer action.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Apr 26, 2006
  6. In uk.rec.motorcycles, Switters belched forth and ejected the following:
    Ah! The "drilling arm" is a good idea.
    Noted!
  7. In uk.rec.motorcycles, SP belched forth and ejected the following:
    I've still got the M-10 sized bit that came with my ground anchor :)
    So far it appears that hammers rock[1] and drill bits a vital ;-)
    [1] SDS rocks more but for well over 300 quid, I'd want to be using it
    more than every now and again.
  8. In uk.rec.motorcycles, Me here belched forth and ejected the following:
    Robbo, if that's you I've tried phoning you.
    Saturady may or may not be ok - it all depends if my leathers are ready.
    I had to have zips put in to make them track compliant and I want to
    collect them when they're ready.
    What time Saturday were you thinking?
  9. Whinging Courier
    A couple of days ago I wrote off my admittedly elderly mains hammer
    drill on British concrete, I'll have you know.
    So :ppPpPp
    Hmm. Wonder if they do petrol ones?
    Pip Luscher, Apr 26, 2006
  10. Whinging Courier
    chippy Guest
    How much trouble to wrap a couple of turns of insulating tape around
    the bit, and watch the drill?
    chippy, Apr 26, 2006
  11. Depth stop. Most drills have them but are rapidly lost after the new
    owner scratches his head/arse and throws it away.
    GS850x2 XS650 SE6a
    Every post contains Nutri-Ceramide-R and Pre-Biotics
    for your reading pleasure.
    Folding@Home Team UKRM
    Grimly Curmudgeon, Apr 26, 2006
  12. Nah. You can pick up some cheap but serviceable SDS drills these days
    for 50quid from Homebase, B&Q and the like. Not as long-lasting as the
    300quid ones, but fine for occasional use.
    GS850x2 XS650 SE6a
  13. In uk.rec.motorcycles, Grimly Curmudgeon belched forth and ejected the
    following:
    Ooo, ta muchy.
    I had a quick squiz at B&Q but no doubt I'll be passing a few DIY places
    today.
    I'll make it my business to go in and have a looksee.
    Whinging Courier, Apr 27, 2006
  14. Whinging Courier
    **** me, you don't need to be spedning that sort of money. IIRC mine
    was somethin IRO 160 Euros, and I'd gone for a good manufacturer
    (Bosch) and the fully-functional model, including a chisel hammer
    setting (i.e. it doesn't rotate) which is great for digging out
    concrete or removing tiles.
    Mine's like this one
    http://www.tool-net.co.uk/data/index.php?ToolID=318387 which seems to
    be available in the UK at around £110 from a variety of sources. I'd
    have no hesitation in recommending it.
    They do a much higher-spec range (coloured blue) which are for
    'professional' use, presumably meaning they could be used day-in
    day-out for years without burning out, but I think they're way OTT for
    99% of home users.
    _______
    Ace, Apr 27, 2006
  15. Whinging Courier
    Buzby Guest
    I had a drill and screwdiver - they both packed up just outside of their
    warranty. I wouldn't go there again.
    Buzby, Apr 27, 2006
  16. Whinging Courier
    Switters Guest
    No trouble at all, it's what I did at the weekend, but if you're a ham-
    fisted biff, or your misses busts into the room at the wrong time....
    Switters, Apr 27, 2006
  17. In uk.rec.motorcycles, Nicknoxx belched forth and ejected the following:
    Bloody hell, that's good!
    Just one thing:
    What does "20mm capacity in concrete, 13mm in steel and 30mm in wood"
    mean?
    Cheers.
  18. Whinging Courier
    I'd guess it's the maximum diameter bit you should use for each
    material.
    _______
    Ace, Apr 27, 2006
  19. In uk.rec.motorcycles, Ace belched forth and ejected the following:
    Hmm, getting a feel for it now, I am.
    Thanks.
  20. Whinging Courier
    Nicknoxx Guest
    Max Diameter
    Nicknoxx, Apr 27, 2006
