OT Xananews filters
Discussion in 'UK Motorcycles' started by Paul - xxx, Oct 26, 2007.
  1. Paul - xxx
    Paul - xxx Guest
    Trying to make Xananews either not download, or mark ignore, threads
    that are cross-posted to more than three newsgroups. Can SWK post
    details of how I can do that?
  2. Paul - xxx
    I don't know, but you could try the Xananews support group
    xananews.support on forums.talkto.net
    CT, Oct 26, 2007
  3. Paul - xxx
    Paul - xxx Guest
    Will do, cheers.
  4. Paul - xxx
    Paul - xxx Guest
    LOL, bad form and all that ... still downloading messages from 2002 ...
    ;) Good retention on that server ... ;)
  5. Paul - xxx
    Actually select Tools - Options - Default Settings - Filters and you
    can creat a filter that won't download posts that are cross-posted to
    'x' groups. I haven't actually tried this to see it work though.
    CT, Oct 26, 2007
  6. Paul - xxx
    Paul - xxx Guest
    Cheers.
    If anyone else is interested it appears it can't be done easily, say by
    having a filter to drop posts with more than x cross-posts ... just
    have to do it by unique text or particular newsgroup I expect.
  7. Paul - xxx
    Paul - xxx Guest
    Doesn't seem to work .. but thanks.
  8. Paul - xxx
    I can't see anything but that doesn't mean it isn't there. Once a
    filter is set, this can be applied on a per-newsgroup or per-server
    basis. Maybe this is what you were [mis]remembering?
    CT, Oct 26, 2007
  9. Paul - xxx
    Oh yeah!
    It doesn't seem to work though as it's checked in my settings but I
    still get cross-posted messages through as normal, unread messages.
    CT, Oct 26, 2007
  10. Paul - xxx
    Eddie Guest
    I'm not familiar with Xananews, but I'm guessing that option is so that
    if you've read a cross-posted item in one newsgroup, it's also marked as
    read in any other of the cross-posted newsgroups to which you subscribe.
    Eddie, Oct 26, 2007
  11. Paul - xxx
    That makes sense.
    CT, Oct 26, 2007
  12. Paul - xxx
    Paul - xxx Guest
    *ding*
  13. Paul - xxx
    So does Xananews but it also has the facility to ignore/mark read/not
    download posts crossposted to more than X number of groups. So you don't
    even have to see the rantings of the bewildered if you so wish.
    sweller, Oct 28, 2007
  14. Paul - xxx
    Yes it can.
    Go to Tools > Options > Filters
    Then "Add" the name of your filter in, er, "Filter Name" then select the
    "Crosspost" radio button, then as the filter text enter 5 or 4 or
    whatever the number of crossposts you want to ignore.
    Then check "Don't Download" and "Don't Display".
    I have mine set at 5 and a quick check shows I have no nutcase rantings
    crossposted to more than 4 groups. Conclusive proof it works...
  15. Paul - xxx
    and select "Greater or Equal" - forgot to add that bit.
  16. Paul - xxx
    Paul - xxx Guest
    Nice one, thanks.
    .... and it works ... ;)
    Paul - xxx, Oct 28, 2007
