OT Washing Machine Death
Discussion in 'UK Motorcycles' started by sweller, Dec 3, 2006.
  1. sweller
    Pete Fisher Guest
    OK, I twist the octagonal topped grey plastic tube thing anti-clockwise.
    The round plate job turns with it until the arrows are not quite 180
    degrees from where they started (just like in the how -to video on the
    Bosch web site). Then the tube, plate and round filter should pull out
    as a unit and release the rectangular mesh filter no? On mine ,the tube
    pulls away from where it clips on to the round plate. I am sure a little
    judicious prising should free the plate but I don't want to bodge it.
    The silly thing is that it works OK anyway. The filter is not actually
    blocked. IIWDFI.
    | Pete Fisher at Home: |
    Pete Fisher, Dec 3, 2006
  2. sweller
    You rotate the assembly anti-clockwise by about one-third of a turn. The
    arrow that's at 6 o'clock should be at 2 o'clock when the thing stops
    turning. At this point, the whole assembly should lift out freely.
    Are you trying to turn it further - say, against resistance?
    Does the plate hit a positive stop at the 2 o'clock position?
    The plate/filter tube assembly holds the rectangular plate down. The
    locking flanges for the round filter tube are on the bottom, right down in
    the hole. There's nothing to pry at the top of the tube.
    Best time to sort this type of thing out. DAMHIK,IJK,OK?
    platypus, Dec 4, 2006
  3. sweller
    The bearings have been rough (now they've become rough and v. noisy); the
    door hinge broke a month ago when I was doing the juggling of the
    crashing plates and now it refuses to spin.
    sweller, Dec 4, 2006
  4. sweller
    Pete Fisher Guest
    Sorted. Peering down in to the bottom I could see the locking flanges
    and that they were disengaged. I could see that the rectangular filter
    plate looked slightly uneven. Plan A revisited. A sharp knife at the
    corner of the rectangular plate and a bit of a twist and lever knowing
    that everything really was unlocked. Out it popped. Hardly needed
    cleaning anyway. All restored to position carefully and hopefully will
    be easier next time. Perhaps the rectangular filter plate is slightly
    deformed and binds in the mounting recess.
    Anyway thanks for the second opinion (and also the moral support from
    Ali). UKRM FOAK strikes again.
    Pete Fisher, Dec 4, 2006
  5. Heh. Glad to be of assistance. (How did I ever manage without a dishwasher!)
    Ali
    Alison Hopkins, Dec 4, 2006
  6. sweller
    raden Guest
    So ... generally fucked then
    raden, Dec 4, 2006
