OT (very) Woooooooohooooooo!!
Discussion in 'UK Motorcycles' started by Andy Hewitt, Feb 9, 2004.
  1. Andy Hewitt
    Pete M Guest
    In
    as an ex owner of a few Lancia Delta Integrales, I can confirm that some of
    them are *still* water soluble. Crying shame.
    Bought my last one four years ago when it was 9 years old, and every time I
    opened the garage door, there was slightly less Lancia, slightly more
    ferrous oxide.
    Weird really, none of the other ones I've known have rusted anywhere near as
    badly, but this thing was turning literally seamless. Gutters, sunroof, boot
    floor, chassis legs, floorpan... all in less than 9 months. Thing that
    freaked my chicken was there were no signs of filler when I wrote it off, so
    it hadn't been botched and painted just to flog it to me.
    Fastest trip across the periodic table I've ever seen a car do.
    Pete M
    Alfa 164 TS,
    Mercedes 500 SEL,
    Jaguar XJ-S 3.6
    Scouse Git extraordinaire.
    Liverpool, Great Britain
    Pete M, Feb 12, 2004
    #61
  2. Andy Hewitt
    Zobo Kolonie Guest
    Loads and loads of Mk-I Golfs have survived. I drive one and since buying it
    I've noticed a huge number of them on the roads; they seem to just keep
    going forever. As for rust, what rust?
    Zobo Kolonie, Feb 12, 2004
    #62
  3. Andy Hewitt
    SteveH Guest
    Ask Pip.
    SteveH, Feb 12, 2004
    #63
  4. I had both why who knows, they were both crap. The Avenger luched it's
    gearbox 3 times, the cortina got through 2 camshafts and 2 engines.
    Boots Blakeley, Feb 12, 2004
    #64
  5. My old Mark One Escort rusted. Curiously, the Allegro was very corrosion
    resistant by the standards of the day. Seriously.
    The old Austin 1100/1300 granny car had such a bad reputation that for
    it's successor, the Allegro, they did something about it.
    Even more bizarrely, if you want a 1970s/1980s car that really doesn't
    seem to rust, look at a Skoda.
    The Older Gentleman, Feb 12, 2004
    #65
  6. Andy Hewitt
    Grimly Curmudgeon was seen penning the following ode to ... whatever:
    Buggeroff.
    Timo Geusch, Feb 12, 2004
    #66
  7. Andy Hewitt
    Catman was seen penning the following ode to ... whatever:
    Fortunately it doesn't talk back...
    #67
  8. Andy Hewitt
    Catman Guest
    Hmmm, I can never tell with you :>
    www.cuore-sportivo.co.uk
    Catman, Feb 12, 2004
    #68
  9. Andy Hewitt
    Andy Hewitt Guest
    The biggest problem they had was not with failing to rust proof though.
    As you say, rust traps were common place, Rover, BL, Ford, indeed almost
    everybody had them.
    The worst was to come though. The cars that really rotted quickly were
    actually the ones that were undersealed. The problem was not in the
    material, but in the application. In order to maintain production
    levels, the manufacturers were applying the under seal while the welded
    joints were still hot. This meant that condensing moisture was being
    trapped under the sealant.
    Worse still, there was Ziebart (sp?) [1], who were applying underseal to
    cars long after production - usually to newly purchased cars. In a lot
    of cases the stuff was being applied to a car that had just been driven
    there. I actually watched them do one, and they were steam cleaning the
    underside before applying the treatment.
    Eventually they went bust from the number of claim they were getting.
    [1] got took over by Dinol.
    Andy Hewitt, Feb 12, 2004
    #69
  10. Andy Hewitt
    Andy Hewitt Guest
    Well, yes, they were both crap, but the Avenger less so, IMHO.
    But look at the alternatives of the time:
    Avenger, Cortina, Marina..... nuff said!
    #70
  11. Andy Hewitt
    Andy Hewitt Guest
    When it comes to mentioning Alfas, I can understand that ;-)
    #71
  12. In message
    I bought one for Jane as a shopping trolley when I broke her Datsun
    shopping trolley. The thing never rusted, never broke down and went like
    a rocket for it's engine size.
    And towed a Diahatsu 4x4 out of a muddy field when it got stuck much to
    the 4x4 owners shame.
    Mick Whittingham, Feb 12, 2004
    #72
  13. Andy Hewitt
    Catman Guest
    Oh *yuss* Our first Alfa was done by them. 6 months........
    #73
  14. Andy Hewitt
    Andy Hewitt Guest
    That'd be about right
    #74
  15. Andy Hewitt
    Timo @ work Guest
    Oi Steve, I'm surprised that *you* of all the people is regurgitating
    the approved bar room opinion on these cars, presumably without ever
    having driven one.
    RX7s don't really have a reputation for rusting badly, just about all
    the ones I've seen do have a bit of rust in the rear wheelarch but
    apart from that they tend to hold up rather well, for whatever reason.
    Yes, mine wants welding on the wheelarch but it certainly doesn't look
    that bad for a 20 year old car.
    Oh, and as with Alfas, the main source of engine problems can usually
    be traced to the muppet behind the steering wheel - these engines use
    oil (and are supposed to) and are just as allergic as the Alfa twin
    cam to revving hard when cold. And as we all know, there are a lot of
    people out there who don't care about either. Yes, there can be issues
    with the rotor tips, but by the time the RX7 was built they were
    mostly due to people not changing the oil on time or using cheap oil -
    the tip seals can stick in the rotor much like coked up piston rings
    either because the car was pottering about town all the time or
    because someone didn't change the oil every 3000 miles.
    Strangely enough the 12A engine (which is the one in the first
    generation RX7) is supposed to be more durable than the later ones;
    something to do with the fact that most of the later engines are
    sandwiched alloy/cast iron whereas the 12A is all-alloy AFAIR. Plus,
    twin turbos to squeeze stupid power from a fairly small engine doesn't
    help much, either.
    Timo @ work, Feb 12, 2004
    #75
  16. Andy Hewitt
    Pete M Guest
    In
    6 weeks. Bizarre fuel related failure.
    Pete M
    Alfa 164 TS,
    Mercedes 500 SEL,
    Jaguar XJ-S 3.6
    #76
  17. I'll give you fifty quid.
    It'll be worth buggerall after it breaks.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Feb 12, 2004
    #77
  18. "Victor Meldrew - the Scarlet Avenger."
    I sorta liked the Avenger - it was a basic, unpretentious, fairly well
    designed fleet car. There was the odd lemon, to be sure, but they were
    generally quite reliable and handled reasonably well for their day.
    Servicing was a doddle, and all major parts could be changed bloody
    quick. 20 mins to do a clutch, for example.
    GS 850 x2 / SE 6a
    #78
  19. Andy Hewitt
    Zobo Kolonie was seen penning the following ode to ... whatever:
    That's only half correct, though. *Early* (small rear light) MkI
    Golfs, especially the mid- to late 70s ones basically don't exist any
    more. In Germany, VW bought up most of the pre-77 or pre-78 ones and
    crushed them because they rusted in a very Italian way.
    Later ones are pretty good rust-wise, though
    #79
  20. Andy Hewitt
    Pete M was seen penning the following ode to ... whatever:
    Someone pissing in the tank?
    #80
