OT : Underfloor heating
Discussion in 'UK Motorcycles' started by frag, Jan 31, 2010.
  1. frag
    frag Guest
    I'm getting a new kitchen put in in a couple of weeks time.
    I want underfloor heating but CBA with all the hassle of digging up a few CM
    of the concrete floor to lay the pipes, etc, etc.
    Then I was told about this lot:-
    http://www.speedheat.co.uk
    who claim they can install underfloor heating, including the covering screed
    layer, in 5mm, which if any good will be fucking ideal as I've got to take up
    the current tiles and Moben are going to lay a self-levelling screed layer. I
    can just get Speedheat to pop along in the morning and lay down their heaty
    stuff then come back to finish off a couple of days later.
    The only thing that's concerning me is how much heat escapes downwards and is
    wasted?
    Anyone got any experience of this type of system?
    frag, Jan 31, 2010
  2. frag
    Tim Guest
    [snip]
    Moben? Eeek, no. Well not in my experience. I have never met a ruder
    salesdroid than the one that came here to sell me a kitchen. It took a
    lot of restraint not to show him the door with my toe up his arse and
    probably the door not opened first.
    Tim, Jan 31, 2010
  3. frag
    Simon Wilson Guest
    From their site: "On solid floors, the element is usually laid on
    insulating material, limiting any heat loss to the base"
    Doesn't sound like 5mm will include much insulation. I've installed
    warmup several times on wooden floors upstairs, but never on the
    concrete floor downstairs. I think if you don't put insulation
    underneath then a lot of heat will sink into the floor and take a long
    time to get to temp.
    Simon Wilson, Jan 31, 2010
  4. frag
    Nige Guest
    On 31/01/2010 18:00, frag wrote:
    Moben
    Oh ****.....
    Nige, Jan 31, 2010
  5. frag
    frag Guest
    took a blunt brush and painted...
    They've been 110% throughout so far.
    Desiger / sales bloke was genuine and a good laugh. Knew his stuff, listened
    to me, came up with useful suggestions for the bits I was stuck with.
    Technical design engineer bloke ditto.
    I normally fucking hate any sort of salesy people coming round to my house as
    I've experienced the hard sell, and any sign of that and they get told "I'll
    be in touch, thankyou and goodbye" (adjusted in politeness as necessary) but
    these two have been great.
    frag, Jan 31, 2010
  6. frag
    crn Guest
    There should be a 25mm layer of insulation below the underfloor heating
    pipes. The screed around and above the pipes is load bearing because the
    insulation is compressible so a decent thickness is required to prevent
    cracking.
    Be afraid and get a proper opinion from a structural engineer.
    crn, Jan 31, 2010
  7. frag
    frag Guest
    They're local to me so I'm obviously going to give them a call tomorrow.
    The next, obvious question is how do you go about removing a layer 5~10mm off
    the top of a concrete floor? I suspect I know the answer and I don't like it!
    frag, Jan 31, 2010
  8. frag
    frag Guest
    Que?
    Or do you just want to **** the sales lass in your local Moben showroom? :)
    frag, Jan 31, 2010
  9. frag
    Tim Guest
    [/QUOTE]
    The one we had could not have been more different. He ignored the things
    Anne wanted and effectively told us what to accept from his great
    expertise. FFS who is the customer? Then to finish it all off, when he
    looked at the boiler in the garage he said something to the effect of,
    "why don't you get rid of those nasty bikes so you can get a decent
    car?".
    Tim, Jan 31, 2010
  10. frag
    Adrian Guest
    Adrian, Jan 31, 2010
  11. frag
    Simon Wilson Guest
    *bzzzzzt*
  12. frag
    Simon Wilson Guest
    Jeebus. That must have taken some digging.
  13. frag
    geoff Guest
    Almost down to the earths core then ...
    geoff, Jan 31, 2010
  14. frag
    mark Guest
    It's very thin mesh of electric heat elements so no pipes.
    I've been asked to quote for this stuff a few times.
    The theory is that a thin layer of insulation slows the conduction of
    heat downwards while there's very little to prevent it conducting
    upwards to the air. <Shrug>
    I'd contact Speedheat and ask about energy usage for a given
    area,exactly what they are using as insulation and check that they *do*
    fit the insulation.
    The type of insulation used under these electric underfloor heating
    mesh's is usually at least a 1/4" and is not as compressible as the
    usual stuff because of the thin screed above the mesh.
    I'd say 5mm does *not* include insulation.
    mark, Jan 31, 2010
  15. frag
    mark Guest
    Cosy :)
    mark, Jan 31, 2010
  16. frag
    Beav Guest
    He probably wouldn't have come to fit anything at your place though.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jan 31, 2010
  17. frag
    Tim Guest
    Get his hands dirty? No I bet not. But even after applying 50% discount
    "only if you sign now" the total price was ridiculous. Still we managed
    to get him to go back to his car for some sample door material long
    enough to get a look at his catalogue with the item price list.
    Tim, Jan 31, 2010
  18. frag
    frag Guest
    If it doesn't then **** it. I'm not messing around hacking off 10mm of
    concrete.
    I did discover this stuff though
    http://www.warmup.co.uk/uk-foil-heater.phtml
    which looks promising.
    Won't be anywhere as near as good as a proper insulation panel but it's only
    to take the chill of the tiled floor anyway.
    frag, Jan 31, 2010
  19. By their own figures, there can only be 3mm of insulation underneath, so
    that means reflective foil layers. Those work, but just not as great as
    is claimed for it.
    So wibble flip. I dunno, suck it and see.
    I can only tell you that I've seen a couple of installations and they
    worked well, but I don't know how much was wasted downwards.
    Grimly Curmudgeon, Jan 31, 2010
  20. frag
    frag Guest
    I'm doing all the tiling, no granite worktops, mate is plastering the ceiling
    and it financed through Hitachi Credit who will get nice and shouty on my
    behalf.
    But tis nice to be forwarned. If some spotty pimp turns up by himself to do
    the work he won't get over the doorstep.
    frag, Jan 31, 2010
