OT : UKRM.co.uk server woes Pt II
Discussion in 'UK Motorcycles' started by frag, Apr 16, 2005.
  1. frag
    frag Guest
    Arse II - This time its WAR
    Another smeggin motherboard goes titsup.com
    At least this one didn't bother with any weeny "memory errors" for
    months and months.
    Oh no. Dead. Unbootable. Parrot sketch.
    Replacement on its way, ETA saturday, normal service should be resumed
    by saturday evening. Apologies to ukrm.co.uk users.
    Anyone want a couple of motherboards that need various caps replacing
    but are perfect otherwise? Abit BP6 dual pro + 2 x celeron 533s + the
    cap kit to fix it - £50, Epox 8RDA needing cap kit - £0.
    frag, Apr 16, 2005
  2. frag wrote
    Do you want a pizza box? I have a perfectly good one which could be
    donated for ukrm's use. Course it only runs unix.
    steve auvache, Apr 16, 2005
  3. frag
    Dan White Guest
    I tried the UKRM patent "Bung it inna freezer for 2 hours" technique on my
    last dead drive, and actually resurrected it for long enough to get
    everything off it.
    Course, that kinda depends on you having *another* 300Gb of space lying
    around...
    Dan White, Apr 16, 2005
  4. frag
    BORG Guest
    I think 50£ is way to much
    you can get this
    Intel Pentium III 600MHz CPU x 2
    512Mb Ram
    4.3Gb SCSI Hard Drive
    CD-Rom Drive
    Floppy Drive
    Onboard Sound, LAN & SCSI
    Desktop Case
    £65 inc courier delivery
    Its for sale in uk.adverts.comp if your interested
    <--ROT13 it
    Spam Trap in Header
    Freedom isn't FREE
    GHPOTHUF #69
    http://borg.no-ip.com
    BORG, Apr 16, 2005
  5. frag
    frag Guest
    Simian scribbled:
    It is a complete PITA that the only thing with enough space to store
    all the stuff you've gathered on your HDDs is another HDD.
    Which you'd much rather use for even more stuff.
    I mean, dual layer DVDs, a piddling ~9GB. What use is *that*???
    frag, Apr 16, 2005
  6. frag
    frag Guest
    BORG scribbled:
    So thats a firm offer then?
    Anyway, it was a price off the top of my head. If no one wants it for
    whatever its for the bin (the mobo, the chips may have their heads
    ground off and used as bling :)
    I've already got a slow test machine with next to no storage space ta.
    4.3Gb? Bits? Thats like 400MBytes! Win XP couldn't even fit on that! :)
    And even at 4.3GB, bung XP, Office and a few other things on and its
    full.
    frag, Apr 16, 2005
  7. frag
    Tim Guest
    Funny bit I have never had any problems with Maxtor. The only one that
    ever went bad was replaced for free and that was really good of them as
    I had got the disk second hand.
    I do hope sir has a backup.
    Tim, Apr 16, 2005
  8. frag
    Dan White Guest
    So she didn't TIU... never mind.
  9. frag
    tallbloke Guest
    Well, if you will insist on using bloatware.
    tallbloke, Apr 16, 2005
  10. frag
    frag Guest
    tallbloke scribbled:
    And the linux server (dead) has 3 x as much storage as anything else.
    So :p to you!
    frag, Apr 16, 2005
  11. frag
    Dan White Guest
    Wow, you're quite tolerant. By that point I would have removed the equipment
    (or at least key components) and told her to stick it up her fucking arse.
    You could also consider a phone call to C&E to see if she claimed the VAT
    back on the invoice. I'll give you serious odds that she did.
  12. frag
    Christofire Guest
    Had quite a run of maxtor drives come back at work. Seem to have
    tailed off now though. That could be because they're ok now, or we've
    stopped using them.
    Christofire, Apr 16, 2005
  13. frag
    Tim Guest
    I must have been lucky. I didn't even know of this phenomenon.
    Oh no tape or second drive. At least drives seem to be getting cheaper
    lately.
    Tim, Apr 16, 2005
  14. frag
    It used to be a common problem with lots of drives in the bad old days,
    caused by the grease on the bearings going hard when the drive cooled
    down, stopping the platters from spinning. The standard fix was to take
    the drive out, grasp it firmly then flick your wrist. The platters'
    inertia would break the grease seal & it would work fine when hooked up
    again.
    This used to be a standard Monday morning routine for me when I worked
    on support at a large BT site.
    Krusty, Apr 16, 2005
  15. frag
    BORG Guest
    Thats a typo by the seller I would think, and you can add your own
    HDDs to it
    <--ROT13 it
    Spam Trap in Header
    Freedom isn't FREE
    GHPOTHUF #69
    BORG, Apr 16, 2005
  16. frag
    Tim Guest
    That was in the 80s, I thought this was a reference to a newer problem.
    I can remember the dreaded sticky grease too.
    Tim, Apr 16, 2005
  17. Rope wrote
    That is not just grease. Conventional paper filled electrolytic
    capacitors of the type used to calm power supplies and stuff can work
    fine as capacitors for 30 years, until the day the power goes off and
    then they become resistors.
  18. frag
    raden Guest
    Yeah - having just successfully repaired a motherboard, sounds good
    email me offlist and I can get them picked up
    raden, Apr 19, 2005
  19. frag
    frag Guest
    raden scribbled:
    <emailed>
    <waits>
    frag, Apr 22, 2005
  20. frag
    raden Guest
    <emailed>
    [/QUOTE]
    Not seen it
    maybe I deleted it accidentally
    ... hunts around in the wastebin
    raden, Apr 23, 2005
