OT Thick mode on
Discussion in 'UK Motorcycles' started by Big Al, Jan 20, 2006.
  1. Big Al
    Big Al Guest
    I have a right angled triangle, with the base length 10"
    the height 3" so the Hypotnuse i think is 10.44"
    If so, whats the other two angles inside the triangle?
    I know there all supposed to add up to 180 but my
    brain has stopped working.
    Thanks
    Alan
  2. Big Al
    You need to use the SOHCATTOA rules for trig finctions.
    e.g. Sin(a) (where a is the smallest angle) = Opposite/Hypotenmuse
    = 3/10.44
    So a =ArcSin(3/10.44) = 16.7 deg.
    you can work out the others, I suspect.
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Jan 20, 2006
  3. Big Al
    Nicknoxx Guest
    Arctan 3/10 and arctan10/3 or 16.69 and 73.0
    Nicknoxx, Jan 20, 2006
  4. Big Al
    Nicknoxx Guest
    Ace wrote:
    snip
    It doesn't have to be the smallest angle.
  5. Big Al
    Eiron Guest
    It has to be the smallest angle in Ace's statement because he was
    calculating the smallest angle. If he was referring to the other acute
    angle the sine would have been 10/10.44.
    As a pedant, I should point out that it's a bit daft using approximate
    derived values instead of the two exact given ones.
    Eiron, Jan 20, 2006
  6. Nicknoxx:
    Ee! I've forgotten how to do *all* of that!
    FrJack @ work, Jan 20, 2006
  7. Big Al
    Stanley Guest
    Why don't you post the question to a newsgroup and get someone to do the
    work for you.
    It's what I do, I'm a Cosmetic Scientist. I make £54K per year and I've
    never
    done a days work in my life.
    Stanley, Jan 20, 2006
  8. Big Al
    Stanley Guest
    I also did the same at University. Never done a days studying in my life.
    Stanley. BA.
  9. Big Al
    Quite so.
    Hardly. One decimal is plenty in this context.
    No, if you were a real pedant, you'd have spotted the error in my
    rule, quoted above, I did as soon as I re-read it after posting, but
    no-one's pointed it out yet...
    _______
    Ace, Jan 20, 2006
  10. Big Al
    Nicknoxx Guest
    Hypotenmuse SP As a pedant, I was trying to point out that Sin(a) =
    Opposite/Hypotenuse for BOTH angles
  11. Big Al
    Eiron Guest
    It's considered bad form to correct someone's spelling, unless you can
    make a joke out of it, such as "You misspelled hippopotamus"
    (or fictions, or DSTIUTA).
    Eiron, Jan 20, 2006
  12. Big Al
    Still not spotted it, then.
    _______
    Ace, Jan 20, 2006
  13. Big Al
    Not that, no.
    Indeed, but that would have been obvious, no?
    _______
    Ace, Jan 20, 2006
  14. Big Al
    Jim Ingram Guest
    You need some new trig tables 90+16.69+73.0 does not equal 180
    Jim
    Jim Ingram, Jan 20, 2006
  15. Big Al
    Nicknoxx Guest
    Obvious to some, but not necessarily obvious from a literal reading of
    your post.
  16. T being equal to H in this instance? :)
    Higgins not @ Work, Jan 20, 2006
  17. Big Al
    Finally.
    _______
    Ace, Jan 20, 2006
  18. Big Al
    Nicknoxx Guest
    No I need to read my calculator more carefully
  19. Big Al
    Eiron Guest
    What do you mean by finally? I pointed that out at 11:41.
    Or was I being too subtle for this world, as usual?
    Eiron, Jan 20, 2006
  20. Big Al
    Did you? You alluded to a spelling mistake, of which there were two,
    but not the mnemomic.
    Possibly. Or too ambiguous, which is not always the same thing.
    _______
    Ace, Jan 20, 2006
