OT Suggestions Reqd
Discussion in 'Australian Motorcycles' started by Mark Gardner, Aug 11, 2004.
  1. Actually, it was a diesel mechanic who put me on to it, for starting a very
    old diesel pump motor.
    And he's a very good diesel mechanic.
    As for me personally, I've found it very useful for getting two-stoke
    engines that have been left sitting for >3 months started. One quick spray,
    and they start first go, and then keep running fine (and restarting without
    the aid of it again).
    Enlighten me as to why "absolutely no professional would use crap like
    that"? And as to how you know this about all professionals?
    James Mayfield, Aug 12, 2004
  2. Mark Gardner
    Nev.. Guest
    of course not... they'd buy it in a generic blue 44gal drum
    Nev..
    '03 ZX12R
    Nev.., Aug 13, 2004
  3. Mark Gardner
    sharkey Guest
    Nah, they'd use Zippo fuel. Weren't you at Wintersun?
    -----sharks
    sharkey, Aug 13, 2004
  4. Mark said....
    Ah good. I have this chrysanthenum that has some dodgy petals that need
    looking at....
    WOFTAM Maintenance?
    Martin Taylor, Aug 13, 2004
  5. It's not easy getting the coal for those.
    Pat
    Pat Heslewood, Aug 13, 2004
  6. Mark Gardner
    Mad Biker Guest
    Oh its got to be
    "Bloke with a spanner" Mechancial service..
    in the them of the people who made my father inlaws house they were called
    "two brothers and a hammer" luckely they only built their own houses.. even
    when one got sfa when they had a 4 some and his missus ran off with the
    other bloke, but left the other woman behind, who lived there for a year,
    sold the house cheeply, but boy is it an intresting design ;-) very large
    spa bath in the large bed room...
    cheers
    Nathan
    Mad Biker, Aug 13, 2004
  7. How about "**** Off Spanner Bitch"?
    Pat
  8. Mark Gardner
    Mark Gardner Guest
    Hi James,
    In reply:-
    The only time any ether based starting aid should be used on a compression
    ignition engine would be in cold weather conditions. Generally sub zero
    centigrade temps.
    It should only be used on a well maintained engine which is in good
    mechanical condition.
    By using it to start a worn or poorly maintained engine, the user is just
    masking any underlying faults with the engine.
    There should be no need to use any form of starting aid on an engine if it
    didn't come out of the factory with it fitted. The only exception being in
    severe cold weather as mentioned above.
    As to how I know this about all professionals. I didn't say I did know this
    I actually said " Absolutely no professional would use crap like that !"
    Perhaps I should have added. Worth their salt or some other similar phrase,
    before the exclamation mark.
    Unfortunately as with all professions the ability and aptitude varies from
    one to another. Personally I have only ever seen bodge it & scarper types of
    so called professional mechanic use things like this.
    I also don't mind them using it as it brings more work to my doorstep.
    I'm also glad to see your using it very sparingly, though if you drained the
    fuel from the carbie and or tank and used new fuel you wouldn't need to use
    it at all.
    Regards
    MarkGee
    Mark Gardner, Aug 13, 2004
  9. In aus.motorcycles on Fri, 13 Aug 2004 22:49:40 GMT
    Which is why it got used a lot on the old Fergie.
    As the poor old thing was definitely old (late 40s) and probably poorly
    maintained (it was a small tractor dammit, who maintains them?) and not
    often used (only need it a few weekends a year on a hobby farm orchard),
    Aerostart was very useful to get it going.
    Never had to use it on anything else.
    Big did try it on the Spada once, but even Aerostart doesn't work if the
    sparkplug goes on strike.
    Zebee
    Zebee Johnstone, Aug 14, 2004
  10. Mark Gardner
    [very respectful applause]
    Clem
    Knobdoodle, Aug 14, 2004
  11. Mark Gardner
    Mark Gardner Guest
    Clem whilst I think I can see why you passed on very respectful applause.
    I feel the poster could possibly be slightly more insulting yet.
    Yoy may used the clapommeter in haste this one time.
    We shall see.......
    Regards
    MarkGee
    Mark Gardner, Aug 15, 2004
  12. By using it to start a worn or poorly maintained engine, the user is just
    But in this particular engine, an engine rebuild would be several thousand
    dollars. Not really worth it for a pump engine that gets used once a month
    and only really has to see out the next 5-10 years.
    Everything has their use. I agree it's not something that should be used
    every day. (And I do drain the fuel etc, but 2-stokes are a little too black
    magic for me. I'll stick to 4-stokes where I can see and understand how it
    all works.)
    James Mayfield, Aug 15, 2004
  13. Mark Gardner
    Mark,
    maybe you don't hang 'round here much these days but "**** Off Spammer
    Bitch" is almost a mantra when someone advertises their business in
    aus.motorcycles. (In fact people even rush over each other to be the first
    to say it).
    Changing spammer to spanner and then using it to advertise the business is
    literary genius (....or as close to literary genius as you're gonna' get
    on usenet anyway!) and ought be acknowledged! (Nay CELEBRATED!)
    But then again... I don't get out much.....
    Clem
    Knobdoodle, Aug 15, 2004
  14. Mark Gardner
    Mark Gardner Guest
    I agree that everything has it's uses.
    My comments were made with the intention of hopefully preventing you from
    using it to start any of your decent engines on a regular basis.
    The old pump engine which is probably only used occasionaly more than likely
    likes a good snort on it !
    Recently I had the honour of fixing an old Honda XR80 which the owner had
    been using start ya bastard to get going. Even after it was finally running
    he said it wouldn't run properly.
    He had put 2 stroke mix in the tank and the points were beyond salvation. A
    quick drain of fuel and carbie clean. Followed by a new set of points and a
    new plug and he's happily chugging around the paddock with his little boy.
    The noise it makes when starting a compression ignition engine should give
    you a clue as to how it works. You'll here one hell of a clatter as it
    fires, this is because the ether mixture ignites far more readily than
    diesel fuel. In effect this like advancing the ignition similar to an old
    bike or car petrol engine with a manual advance/retard lever.
    Regards
    MarkGee
  15. Mark Gardner
    Mark Gardner Guest
    Ah I am enlightened oh snoorer to the stars !
    Your right I don't hang around here much anymore. I never seem to have the
    time these days.
    I shall maybe contribute more after the house is built, at present this is
    computer room and babies room. Whilst I can still get away with the odd
    night of grog and asscoiated noisy activities, I find my life far easier on
    baby & mother fronts if I vacate his room at the time I'm told to !
    Hence my lack of contributions.
    With that I must go coz it's time to hand over the room to the wee man.
    Cheers n all that
    MarkGee
    Mark Gardner, Aug 16, 2004
  16. Mark Gardner
    I got sick of vacating the room so I built in the garage andmoved all my
    crap into there.
    Unfortunately the wimmens followed and now I'm back to being vacated again!
    (And I've lost my garage!!)
    Clem
    [Snoorer to the stars]
    Knobdoodle, Aug 17, 2004
  17. Mark Gardner
    Mark Gardner Guest
    No doubt something very similar will happen to me.
    Which is why I need to build the big shed with double locking mechanisms and
    an alarm system.
    With just the one key which I keep about my person all the time...........Ah
    well.....I can still dream I spose.
    Cheers
    MarkGee
    Mark Gardner, Aug 17, 2004
  18. Mark Gardner
    smack Guest
    already done that.
    Now where the hell is Bekkers?
    smack, Aug 17, 2004
  19. Mark Gardner
    conehead Guest
    I reckon he eloped with IK
    conehead, Aug 18, 2004
  20. Mark Gardner
    sharkey Guest
    Good point. What news from the Ivory Shed?
    -----sharks
    sharkey, Aug 18, 2004
