OT renault megane keys
Discussion in 'UK Motorcycles' started by Alan Crowder, May 13, 2009.
  1. Alan Crowder
    Alan Crowder Guest
    I have just purchased for my sins an 02 Megane and it has two keys,
    one works with the central locking and starting, the other does not,
    it lights up when it's pressed but nobody at home, so i guess the key
    and the car need to get on friendly terms, anybody got the slightest
    info if this is a diy job?
    No its not going to be my car, but a seller as i got it cheap.
    Thanks
    Alan
  2. Alan Crowder
    Alan Crowder Guest
    Or as they say around here, I'm going to Nige it.
    alan
  3. At a guess, I'd say prepare yourself for a nasty and expensive shock.
    Could be several hundred quid.
    The Older Gentleman, May 13, 2009
  4. Alan Crowder
    crn Guest
    Try a fresh battery in the key.
    crn, May 13, 2009
  5. Alan Crowder
    boxerboy Guest
    Its a Dealer job for the key to be reprogrammed and I would advise a
    new battery. Had to do the same on my 01 scenic about 12 months ago
    and was charged £22 by the dealer. Check with the dealer first though
    incase they have realised that the price is lower than a lot of other
    makes. There must be independents who can do it cheaper but I do not
    know of any, GSF must be worth a try.
    Boxerboy
    boxerboy, May 13, 2009
  6. I was told that to have a new key made or reprogrammed or whatever for
    the Scoob is something silly like £500. Got to find out if that's
    true....
    I think a colleague had to shell out something unbelievable for a
    replacement key for a Fiat Marea (of all things).
  7. Alan Crowder
    Paul - xxx Guest
    Wife had one, same problem .. £165 for a replacement.
    The car went within three days. ;)
    God call .. ;)
    Paul - xxx, May 13, 2009
  8. Alan Crowder
    SteveH Guest
    That will be because he'd lost the red master key - meaning a complete
    ECU and lockset was needed.
    SteveH, May 13, 2009
  9. Alan Crowder
    Simon Wilson Guest
    The newer Renault keys (card type) are not codable/reprogammable.
    Replacement keys now come directly from the factory once you supply the
    VIN, proof of identity yada yada. 200 quid plus IIRC.
    There are usually loads of Renault keys for sale on ebay that are all
    completely useless.
    Simon Wilson, May 13, 2009
  10. Those card-type keys are the most inconvenient crocks of shit anyone
    ever came up with. IMHO, of course.
  11. Could have been. ISTR the sum of £800 being mentioned.
  12. Alan Crowder
    Andy Carvell Guest
    Sometimes (rarely, these days) you can put the car into programming mode
    with a nifty combination of button pushing from within the car.
    Autodata has this kind of info on it, I can have a check tomorrow if it
    can be done with the Megane.
    For a dealer to just program the key up and not supply one it may end up
    not costing much at all, depending how many gizmos they have to get out.
    Probably worth a call.
    Andy Carvell, May 13, 2009
  13. Alan Crowder
    antonye Guest
    Same as BMW - they make eight keys that are coded to the immobiliser
    and you pay £90 for a new one direct from the factory, ordered through
    a dealer. Once they're all gone it's new lockset time.
    If you kill the transponder in the key then it will still work the
    central locking remote, it will still unlock the doors and it will
    still turn the ignition on but it just won't start the car. If you
    then try and jump start the car, it will decide it's being nicked
    and then shut down for a few hours instead. This is *really*
    inconvenient when you happen to be at Cadwell Park and you live
    in Essex. DAMHIK,IJK,OK?
    antonye, May 13, 2009
  14. Alan Crowder
    The Older Gentleman wrote:
    When I bought Cane's Fireblade there was a receipt in the paperwork for
    a new ECU, lockset and keys - I guess he lost the keys at some point.
    Total cost was something like 850 quid.
    Lozzo, May 13, 2009
  15. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    You did check the frame and engine numbers against the V5, right?
    go and talk to the Catholics.
    Wicked Uncle Nigel, May 13, 2009
  16. Alan Crowder
    geoff Guest
    Must be a fireblade thing
    Darsy lost the spare set too
    geoff, May 13, 2009
  17. Alan Crowder
    I flogged it before I got the chance to.
    Lozzo, May 13, 2009
  18. Alan Crowder
    a colleague at my last job managed to leave his key in the boot of his Clio
    of similar vintage, then slammed the hatch. As none of the doors had been
    opened the central locking deadlocked. He didn't have a spare key.
    AA patrol called. He couldn't get in without resorting to breaking a
    window. Colleaugue told him to FRO and called a local independent in
    Cwmbran. Within an hour the SO had arrived with a correctly cut & coded
    key, all from the VIN.
    wessie, May 13, 2009
  19. Alan Crowder
    Cane Guest
    The ECU blew due to a seized value and had to be replaced.
    Cane, May 14, 2009
  20. Alan Crowder
    Ooer, costly for something as simple as a seized exup valve.
    Lozzo, May 14, 2009
