OT Radio controlled clock problem
Discussion in 'UK Motorcycles' started by gomez, May 28, 2007.
  1. gomez
    gomez Guest
    Anyone else had a problem with their radio-controlled clock since they
    moved the transmitter from Rugby to somewhere upt'North?
    Mine now shows consisently four hours behind when in its normal
    position in the kitchen on the East side of the house but corrects
    itself when moved to the hallway on South side of the house.
    Options?
    1) Reposition the clock permanently to the hallway.
    2) Find a way of stopping it synching and use it as a normal clock.
    3) Move the kitchen into the hallway - it is a kitchen clock after all
    and looks out of place in the hallway.
    gomez, May 28, 2007
  2. 4. Buy another clock.
    The Older Gentleman, May 28, 2007
  3. gomez presented the following explanation :
    Er, No!
    Could your kitchen be in a different time zone perhaps?
    Harry Bloomfield, May 28, 2007
  4. gomez
    Jim GM4DHJ Guest
    All five here in the near of Glasgow working fine......
    Jim GM4DHJ, May 28, 2007
  5. 4) Launch a reflector into space, positioned about 10 light hours
    distant and read the radio signal from that.
    GS850x2 XS650 SE6a
    river cleaned out in a day.
    Grimly Curmudgeon, May 28, 2007
  6. gomez
    Frotfrott' Guest
    Measure distance between kitchen and hallway, then take the house down
    and rebuild it that same distance away from it's original position.
    Easy, it's done everyday in different parts of the world...
    Eric,
    Frotfrott', May 28, 2007
  7. gomez
    BGN Guest
    Both of ours here in Kent are fine.
    BGN, May 28, 2007
  8. gomez
    Fine here in East Anglia.
    Pip Luscher, May 28, 2007
  9. gomez
    SteveH Guest
    No, 2 clocks and a watch all working fine here.
    SteveH, May 28, 2007
  10. We don't have a radio controlled clock, but our clock radio teasmaid still
    appears to be functioning correctly today.
    Brownz \(Mobile\), May 28, 2007
  11. gomez
    Our clock stopped today but after I wound and restarted it seems to be
    keeping good time - still does the odd random chime occasionally.
    So the move of radio transmitter appears not to have affected it.
    sweller, May 28, 2007
  12. gomez
    Tosspot Guest
    New batteries?
    Tosspot, May 28, 2007
  13. gomez
    Chris Guest
    Yep. 2 here[1] refuse to sync since the move.
    [1] Surrey
    Chris, May 28, 2007
  14. Clocks are for poor people who need them so that can be at the factory
    in time to suit the needs of their bosses.
    steve auvache, May 28, 2007
  15. gomez formulated on Monday :
    4. You might try changing the wall it hangs upon, so that the antenna
    faces towards Cumbria.
  16. gomez
    Eatmorepies Guest
    My radio clock works perfectly here in Wales - unlike my radio which has to
    hang on its mains lead with the aerial pointing out over the sink. I do wish
    the clock could receive radio 4.
    John
    Eatmorepies, May 28, 2007
  17. gomez
    Rich B Guest
    Yer radio's fucked. Analogue's fine here - it's the digital signal that's
    marginal. Preseli transmitter in the throes of an upgrade. Ferryside is a
    law unto itself, mind.
    Rich B, May 28, 2007
  18. gomez
    raden Guest
    Funny you should say that, yes
    the one in the lounge has been a couple of hours ahead three times in
    the past month, the alarm clock 4 hours behind twice
    raden, May 28, 2007
  19. gomez
    DR Guest
    Anthorn, former RNAS Nuthatch, Cumbria, otherwise mainly used as a VLF
    transmitting station for RN submarine communications. Funnily enough
    the only one I encounter regularly works fine, although it is only
    about 15 miles from the new transmitter.
    DR, May 28, 2007
  20. gomez
    raden Guest
    So how do bosses check that the poor people are at work in time?
    raden, May 28, 2007
