OT & PSA: Vista crashing the last few weeks.
Discussion in 'UK Motorcycles' started by Krusty, Apr 12, 2011.
  1. Krusty
    My Vista PC started crashing every evening a few weeks ago, & I've
    finally figured out the cause. It's one of the NVidia services - either
    Driver Helper Service, Performance Driver Service or Steroscopic 3D
    Driver Service. Stopping all those & setting them to manual has solved
    the problem.
    Thought I'd mention it in case anyone else has the same problem, & for
    Google fodder.
  2. Krusty
    Why is anyone running Vista?
    Hog, Apr 12, 2011
  3. Krusty
    Why not? It does what I need it to do (on this PC), & has done so
    reliably for years.
  4. Krusty
    That's no excuse
    Hog, Apr 12, 2011
  5. Krusty
    Fabian Guest
    As its an nvidia related issue and many Vista machines used chips that
    were defective the problem may appear again and even get worse. Google "
    nvidia defect" and see if the chip used in your machine is one that is
    affected. Although most problems occur with laptops, poorly cooled
    desktop graphics chips are also affected. I've had one laptop go down
    and become unbootable and a desktop graphics card produce lined output
    necessitating replacement, both chips were 8400 series.
    Fabian, Apr 12, 2011
  6. Krusty
    Because they don't fancy paying for another copy of Vista rebadged as
    Windows 7?
    ogden, Apr 12, 2011
  7. Krusty
    Heh. I couldn't *wait* to get Win7 on my HTPC simply cos it supports
    multiple TV cards (which Vista didn't). But no need for that on this
    PC, so I've never bothered upgrading it, even though the only cost is
    my time.
  8. Krusty
    <snort>
    Hog, Apr 12, 2011
  9. Krusty
    and not much time at that
    Hog, Apr 12, 2011
  10. Krusty
    A good couple of days at least to get everything setup again (on a
    clean install). I'd call that quite a lot of time.
  11. Bollocks, I'm still running XP Pro quite happily. I decided to give
    Vistula a miss, as I'd heard so much bad about it, and even W7 will be
    getting the swerve from me. My next OS set up will likely be Ubuntu/XP
    mix, running on VMWare or something along those lines.
    Grimly Curmudgeon, Apr 12, 2011
  12. Krusty
    XP is functional. W7 is also ok.
    Hog, Apr 12, 2011
  13. Krusty
    Doesn't seem to match the problems I've been having, especially as it
    only crashed when I hadn't been using it for a few hours. It's still ok
    so I'm sure it was one of those services causing it.
    Krusty, Apr 13, 2011
