OT : Paging the wirelessiti ....
Discussion in 'UK Motorcycles' started by Biffa @ Work, May 13, 2005.
  1. Biffa @ Work
    Biffa @ Work Guest
    Hi,
    Apols for the OT, but I respect the pooled knowledge on here much more than
    anywhere else....
    I've just been given a Cisco Aironet 1220 Wireless Access Point.
    Great I thought, I can use that at home as the laptop has an a/b/g wireless
    card fitted.
    Its attached like this.
    NTL Cable Modem is connected to Linksys BEFSR41 4-Port Router. (Set up to
    Serve DHCP)
    X-Box is on Port 1 - Connects fine.
    PC is on Port 2 - Connects fine.
    Cisco WAP is on Port 3 - Not Seen.
    I downloaded an app from Cisco for detecting the IP address from the WAP's
    MAC Address (IPSU.EXE).
    When I enter the (correct) MAC Address the app tells me it can't communicate
    with the WAP.
    Is there anything blatantly wrong going on here ?
    I checked the patch lead and that's fine if I plug my laptop into it.
    Any suggestions would be gratefully received - feel free to take it off of
    the NG and mail me - admin [at] brownz [dot] org
  2. Biffa @ Work
    Catman Guest
    1) Plug the Cisco into your laptop or desktop PC direct.
    2) Use the CIsco app to get to the WAP. Set it for DHCP or give it (better
    IMO) a static IP address on the correct range.
    3) Plug it back into the Linksys. All should be well
    *Unless* it needs to be plugged into an uplink port / needs a crossover
    cable. That would be the case if 1 and 2 work, but three still fails.
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 155 TS 75 TS
    www.cuore-sportivo.co.uk
    Catman, May 13, 2005
  3. Biffa @ Work
    Biffa @ Work Guest
    Thanks Catman.
    Now you'd have thought I would have tried that first wouldn't you .....
    [slaps forehead]
    I'll give that a go when I get home tonight.
    I noticed there is a config port that takes an RJ socket, I shouldn't have
    to have it plugged into that should I ?
  4. Biffa @ Work
    Statto Guest
    e-mailed.
    Statto, May 13, 2005
  5. Biffa @ Work
    Catman Guest
    I would doubt it. It's probably a serial type, or possibly crossed over
    port. I'd stick with the 'normal' one first.
    Shout if you're still having trouble tonight
  6. Biffa @ Work
    Catman Guest
    Biffa Bacon wrote:
    Certainly sounds like it.
  7. Biffa @ Work
    Statto Guest
    First off, one of those links I e-mailed is a troubleshooting
    document. What do the LEDs on the front indicate?
    If it is FUBARed, then find out how old it is. According to
    http://www.cisco.com/en/US/products/hw/wireless/ps430/products_data_sheet09186a00800937a6.html
    the unit has a 12 month warranty, so you may be able to get it
    repaired or replaced. You'll need to find out who the reseller was
    though.
  8. Cisco like using serial comms for their config - and supply a lead with
    each device with a 9-pin serial on one end and an RJ45 jack on the
    other.
    Plug it in, set your serial port to 9600,8N1 and bob's yer uncle.
    Mind you I suspect that the resultant pages of stuff won't be
    particlarly meaningful to you..
    Oh - and general rule of ethernet connectivity - like-to-like needs a
    crossover cable, like-to-unlike needs straight through. So connecting
    two network cards direct needs a crossover, connecting to a hub or
    switch needs straight through.
    Phil
    Phil Launchbury, May 16, 2005
  9. Biffa @ Work
    Ben Blaney Guest
    Except the two gigabit ethernet cards I joined with a straight cable
    this morning.
    Not necessarily.
    Ben Blaney, May 16, 2005
  10. Biffa @ Work
    mups Guest
    Ben Blaney says...
    One assumes you took the afternoon off after such a hectic morning...
    mups, May 16, 2005
  11. Biffa @ Work
    Ben Blaney Guest
    Err.. yesterday afternoon. Umm... what did I do?
    Oh. Meeting.
    Ben Blaney, May 17, 2005
  12. Which is why I said "general rule".
    See above.
    Phil
    Phil Launchbury, May 17, 2005
