OT Link two pc's to one monitor/keyboard
Discussion in 'UK Motorcycles' started by flashgorman, Nov 3, 2003.
  1. flashgorman
    flashgorman Guest
    As per the subject really. Want to share one monitor/ keyboard/mouse between
    two pc's. As cheaply as possible.
    TIA.
  2. flashgorman
    Sean Doherty Guest
    A KVM switch.
    A stolen KVM switch.
    Sean Doherty, Nov 3, 2003
  3. flashgorman
    Sean Doherty Guest
    Seriously, if one of your PC's can boot sans keyboard, install VNC on
    it and remotely drive it from the other machine. This will cost you
    nothing.
  4. William Grainger, Nov 3, 2003
  5. flashgorman
    Slider Guest
    A Belkin "Omniview" is what I use at work for the 3 machines I use
    frequently.
    http://catalog.belkin.com/IWCatSectionView.process?Section_Id=56
    They come in many varieties, but I use a 4 port one (4 machines controlled
    by 1 keyboard, mouse and monitor).
    Slider, Nov 3, 2003
  6. Seconded - this is exactly what I do.
    The machine without accoutrements is configured with VNCserver in the
    startup process, so as soon as it's booted I use my good machine with
    VNCviewer to control the other machine. Free, easy and useable.
    Doesnotcompute, Nov 3, 2003
  7. flashgorman
    flashgorman Guest
    Sounds interesting. Will give it a go. Cheers.
  8. flashgorman
    Or, if using Windows 2000, enable Windows Terminal Services.
    Champ, Nov 3, 2003
  9. flashgorman
    Slider Guest
    Which is /so/ much faster than VNC it's just not funny.
    Slider, Nov 3, 2003
  10. flashgorman
    flashgorman Guest
    I'm got one pc with XP home and one with win2000 server. Any good for
    terminal services?
  11. flashgorman
    you'll definitely be able to use terminal services from the XP box
    onto the Win2000 Server (which I suspect is the way round you'll want
    things), but not sure about the other way around.
    XP home is for pikeys.
    darsy, Nov 3, 2003
  12. flashgorman
    HooDooWitch Guest
    Yup.
    Enable TS (it's a service) on the server.
    Stick Terminal Services Client on the XP home box.
    HooDooWitch, Nov 3, 2003
  13. flashgorman
    which is quite considerably faster and more secure than VNC. In fact,
    VNC's *only* saving grace is that it's cross-platform.
    darsy, Nov 3, 2003
  14. flashgorman
    Sean Doherty Guest
    Aye. Which is why I suggested it initially.
  15. flashgorman
    flashgorman Guest
    I think you mean XP Caravan.
  16. flashgorman
    "XP Mobile Home" for the upwardly mobile pikey.
    darsy, Nov 3, 2003
  17. flashgorman
    simonk Guest
    These *can* be a bit dodgy with XP/2000, though - occasionally the mouse
    will stop working when you switch machines. Suspending and reactivating the
    PC sorts it.
    As others have said, though, if you're using XP/2000, terminal services is
    loads, loads better. The KVM switch thing is only really necessary if
    you're forever rebooting and diddling around with BIOS settings on multiple
    PCs, or running some lame-ass seventies operating system
    simonk, Nov 3, 2003
  18. flashgorman
    Quite. I've only used VNC once, and thought it was slow clunky shite.
    Pre-W2K, we used to use PC-Duo for remote management of servers, which
    is still quite a good product, but now for most things Terminal
    Services is the no-brain choice.
    Champ, Nov 3, 2003
  19. flashgorman
    unless your "sysadmins" are clueless frogs who fear change, and insist
    that you use VNC, despite repeated requests to use Terminal Services
    instead.
    darsy, Nov 3, 2003
  20. flashgorman
    PeterT Guest
    Andrewr At Work
    Good use are you these days, that wasn't even funny. What happened? All
    phunny bones broken in another scaffolding incident?
    PeterT, Nov 3, 2003
