OT (IT): Help me, I've got NFI
Discussion in 'UK Motorcycles' started by the man with no idea, Dec 19, 2008.
  1. OK here's the background. Dell Inspiron 510m laptop, 40 gig hdd almost
    full to bursting. I bought a new 160 gig drive and an external usb
    enclosure. Following advice on here I downloaded Acronis True Image
    and set about using it - sort of.
    Oh hang on, something else happened. I had written to Dell customer
    services to ask if there was a limit to the hdd size I could use - no
    answer. Phoned them up and they said the bios would recognise 160 but
    they could only sell me 80 gig (for over a ton!). After I bought the
    hdd I then got a reply to my email telling me that the max usable size
    was 80 gig. So I thought I'd have a play with the drive (Ididn't have
    the enclosure at this point) and tried installing Mandrake 10.1 on it.
    That seemed to install ok then failed - I think because it didn't
    recognise the video gear. Anyway, back to the story.
    I was looking for a button that said "clone" but their wasn't one -
    just image. Using the XP disk management I tried to more or less set
    up the same partitions on the new disk as the old one - a fat16 of
    55mb, a fat32 of 3.49gb and an ntfs of 33.7gb. I figured one of the
    FATs was probably the Dell diagnostics and had no idea what the other
    was. I couldn't fit the image of the NTFS anywhere else so I made
    another partition to store stuff on. Then I imaged the 3 partitions
    onto the stuff disk and restored the images onto the equivalent
    partitions on the new drive.
    This seemed all well and good until I swapped the drives over. As I
    turned it on it booted to Mandrake giving me 2 choices - Linux or
    failsafe, both of which get as far as "kernel panic: No init found.
    Try passing init= option to kernel" although there are lots of other
    errors en route.
    My question is, since the ntfs image of my old c-drive is marked as
    the boot partition and the old hard drive (from whence the image came)
    was never touched by linux, why is it booting to Mandrake? More
    importantly, can I stop it?
  2. the man with no idea
  3. the man with no idea, Dec 19, 2008
  4. the man with no idea
    I tailor my output to the audience
    I originally typed "don't be such a fucking pikey" but I knew you would get
    it from the URL
    Now, please excuse me whilst I go back to recalibrating Lozzo
    wessie, Dec 20, 2008
  5. I wish you well with that. I'll go away and see if I can do something
    with a Windows XP disk and fixmbr or summat. Whisky first.
    the man with no idea, Dec 20, 2008
  6. the man with no idea
    Catman Guest
    www.cuore-sportivo.co.uk
    Catman, Dec 20, 2008
  7. the man with no idea
    Well, it's obviously attempting to boot into Mandrake if it's there or
    not which would suggest that the boot sector/mbr hasn't been overwritten
    and still points to the Mandrake boot loader.
    Timo Geusch, Dec 20, 2008
  8. the man with no idea wrote:
    [snip]
    If I'm reading this right, you tried to make it too complicated.
    You need to image the entire disk so the MBR etc gets copied as well,
    and there shouldn't be any need to touch the XP disk managment tools-
    just tell trueimage to copy and resize proportionately.
    Can you use an external drive to hold the image?
    Chris Bartram, Dec 20, 2008
  9. The only external drive I have with enough space is the 160 gb target
    drive. Also, restoring the image doesn't seem to have affected the mbr
    - or is that cos I was doing one partition at a time?
  10. Yes, I think. Do it "all or nothing".
    Dr Ivan D. Reid, Dec 20, 2008
  11. <boggle>
    I've obviously missed too many threads lately!
    </b>
  12. Yep.
    You need to find another disk to hold the image of the entire disk, or
    find a PC you can attach both disk to temporarily.
  13. Yes, that may work.
  14. Well yeah, anyone can say that.
