I may well need the services of a bodyshop where I can trust folks to actually do what I want and do a proper job so I was wondering whereabouts in the country you are? I know that Owen's in/near Reading... Background is that I've had a couple of repairs done on my RX-7 convertible and I'm not happy with the quality of at least one of them (and I guess I'll find out in the next couple of days if the MOT tester is as unhappy about it as I am). I'll try to get the bodyshop I used to sort it out and redo the repair the way I want it to but if it turns out that they're not really interested in doing that, I need someone else to sort out the mess[1]. Travelling a reasonable distance to get this work done isn't really a problem - at the end of the day I go to the other side of Reading from here (Ashford) just to get it serviced. Owen, I know you said that you guys aren't normally interested in taking jobs where the customer is quite far away but I'd rather not experiment with bodyshops again so I'd rather go to someone I've met before, even if it was "just" in a NG. I'd like to point out that I'm not expecting mate's rates or anything like that, just good workmanship. As a potential bonus (depends on how you look at it), the other RX-7 I'm in the process of buying will need a decent respray in the same colour[2] within a year or so and I do tend to turn into a repeat customer if I'm happy with the workmanship. [1] Repair of the outer sill - there was a bit of rust that needed cutting out but instead of letting new metal in it looks like the guys plated over it (although they did cut out the rust, supposedly). If I wanted to plate over the rust I would have welded that myself... Anyway, unfortunately this messed up both the shape of the bottom of the sill (the rest is spot on) and a seam on the sill right next to it. The more often I look at that, the more pissed off I become... [2] The One True Colour that is, and I know that it's a bastard to spray.
