OT(ish): Flame Master from Maplin
Discussion in 'UK Motorcycles' started by Whinging Courier, Aug 17, 2005.
  1. What a neat thing.
    I bought one today because I needed to make a battery for something and
    oh-my-gosh, what a nifty tool.
    To be honest, I only used the soldering iron but it's got (butane
    powered) soldering iron, HT flame torch, hot cutting knife, hot air
    blower (presumably for that shrink wrap type stuff that goes round
    electrics) and a "wide area flame torch".
    Mega! Had loads of fun with it today and comes with all the bits (and
    more besides) you need[1]
    Not bad for something that was less than 20 quid!
    http://www.maplin.co.uk/module.aspx?ModuleNo=3887&doy=17m8 if you're
    interested[2]
    [1] Apart from butane, but being a smoker I've got loads of that ;)
    [2] Of course you are.
  2. Whinging Courier
    Catman Guest
    Been using them for ages. Be aware that the catalytic soldering heads don't
    have a long life, especially if you use them on 'high'.
    Damned good though.
    www.cuore-sportivo.co.uk
    Catman, Aug 17, 2005
  3. In uk.rec.motorcycles, Catman amazed us all with this pearl of wisdom:
    Just a "hiss" seemed to be enough and I had to fill it up again.
    What's a long life as you put it? About the same as a mantle in a gas
    lamp?
    Sure is, after some thought I might even wire my bike properly now :)
  4. Whinging Courier
    Catman Guest
    Dunno, I've never used a gas lamp. I'm lucky if mine last maybe 2-3 hours
    total use. I do tend to have them on pretty high since I use them to
    solder automotive cables which can be a bit thick.
    I do also tend to chuck them in the tool box, which dunt do them any good :)
    *ding*
  5. Whinging Courier
    I wouldn't mind that, but I've already got a gas soldering iron and a
    blow torch.
    What I wouldn't mind is an oxy propane brazing kit for that much. :)
    Muck, Aug 17, 2005
  6. In uk.rec.motorcycles, Catman amazed us all with this pearl of wisdom:
    Blimey, not long then. They better have replacements. I've put off
    getting a soldering iron for yonks but this thing is just the ticket. I
    would've put it off again today but I just *had* to have one and for an
    extra fiver you get the convenience of being portable.
    Yep.
  7. In uk.rec.motorcycles, Bear amazed us all with this pearl of wisdom:
    Because you're a pervert ;)
    I do sometimes sit on my sofa you know but the gas blower in question
    would have no problem re-sculpting foam or leather and horsehair.
  8. Whinging Courier
    I noticed that some of the gas soldering irons use a sort of wool like
    element, and some use a more solid grid type element. My old one had the
    former element, my new one has the latter type, and has put up with
    being thrown into my tool box for quite some time so far. :)
    Muck, Aug 17, 2005
  9. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    It says "good for brazing" or something like that in the destructions :)
  10. Whinging Courier
    Catman Guest
    Not seen one like that. The wool type is platinised asbestos, AIUI and is
    pretty delicate.
  11. Whinging Courier
    My one is made by iroda, and is called a solderpro 50. Maplin sell it
    for about £10. I bought it after spotting that other one, with the
    fragile element.
    Muck, Aug 17, 2005
  12. Whinging Courier
    Good for brazing very small things indeed. :)
    Muck, Aug 17, 2005
  13. Whinging Courier
    Catman Guest
    Noted, ta.
  14. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    Like copper wire carburetor gaskets ;)
    Whinging Courier, Aug 18, 2005
  15. Whinging Courier
    It was a hollow copper gasket, and that.. I soldered. :)
    Muck, Aug 18, 2005
  16. Whinging Courier
    Paul - xxx Guest
    Catman came up with the following;:
    Yup.
    We race Radio Control Model Cars and I use one of these all the time ... but
    we do away with the catalyst 'wool' and remove the bridge bit inside [1] so
    that the flame burns directly onto the back of the bit. Makes for a much
    hotter bit and a better join, we find.
    [1] very small drill in a dremel and a small tungsten carbide burr to
    'carve' it away.
    Paul - xxx, Aug 19, 2005
