OT : iPhone battery life
Discussion in 'UK Motorcycles' started by frag, Feb 3, 2010.
  1. frag
    frag Guest
    A quick survey of battery life.
    What type of iPhone do you have? (2G, 3G, 3GS)
    Battery life?
    Do you use MMS?
    Reason why is the battery life I'm usually getting is about 4.75 days. (I
    guesstimate just over 5 days to flat but a flat phone isn't much use to me
    during the daytime :)
    *If* I (try) to send an MMS [1] the battery life from then on is less than 2
    days.
    I need to do a hard reset to get it back to normal. (press power and home
    buttons until the phone turns itself off and resets - you don't loose any
    data doing this)
    [1] I say try because MMS's never seem to send. I think I've sent one
    successfully and about 10 have failed.
    It looks like something is getting stuck, possibly because it's failed to
    send the MMS, and from then on carries on trying to send it and eating the
    battery.
    I haven't bothered to stick the phone next to the computer speakers to see if
    it's talking to the base station all the time.
    frag, Feb 3, 2010
  2. No.
    new iP.OS updated yesterday, one of the fixes was for situations where
    battery indicator was inaccurate.
    doetnietcomputeren, Feb 3, 2010
  3. frag
    Nige Guest
    Mine lasts for fucking ages, they are shit & I don't have one.
    My HTC is even shitter & lasts about a nanosecond.
    Any touchscreen/web type phone is worse than getting fucked by a rather
    large penised man, in the arse. Twice.
    An hour.
    DP.
    Nige, Feb 3, 2010
  4. frag
    Die.
    Krusty, Feb 3, 2010
  5. frag
    Nige Guest
    Good call.
    Nige, Feb 3, 2010
  6. frag
    3G, Nokia E75
    Depends on usage. I use my phone a lot for calls during the course of a
    working day and send a shitload of sms. I have managed to scrape two
    full days use out of it before it went totally flat. I also managed to
    get four days out of it when I was in hospital, mainly because I wasn't
    using it to make many calls, but did send a fair few sms.
    Rarely
    Lozzo, Feb 3, 2010
  7. frag
    JackH Guest
    Indeed.
    Most people use a webcam for that 'sort of thing' these days.
    JackH, Feb 3, 2010
  8. frag
    JackH Guest
    iPOS sounds so much better, don't you think?
    JackH, Feb 3, 2010
  9. frag
    mr p Guest
    Should have bought a mobile phone where you can at least change the
    battery.
    Iphone is for Fashion victims, can't see why else it's so popular.
    mr p, Feb 4, 2010
  10. Yeah - exactly the reason I didn't buy an Iphone on the last change.
    This HTC is just about dying but I'm buggered if I am buying a phone
    that I can't carry a spare battery with me. Have spare battery for
    netbook, phone, older backup phone, camera, plus a bunch of
    rechargeable batteries in a mic case in my backpack that will fire up
    my torches, guitar tuners, DIs, etc. I like my electrons and do not
    want them running out on me at inconvenient times.
    Kevin Gleeson, Feb 4, 2010
  11. frag
    Catman Guest
    Which one, Nige? My Diamond 2 will happily go a couple of days.
    You don't half talk some crap at times.
    www.cuore-sportivo.co.uk
    Catman, Feb 4, 2010
  12. frag
    SteveH Guest
    <looks at battery 'sleeve' for iPhone that slips on and makes it around
    the same size as your average HTC type WinMobile device, but gives a
    good few days of battery life>
    SteveH, Feb 4, 2010
  13. My TytnII will only go a day or so. I have 3 normal batteries for it
    plus one of the bulkier longer lasting ones for when I want to run it
    in GPS mode. Regardless of battery life, I still want to be change to
    a spare battery I get caught out. IPhone don't allow that. Waiting for
    Nexus.
  14. frag
    Catman Guest
    You mean you add a sleeve, and it makes the iPhone *Smaller*? *impressed* ;)
    Catman, Feb 4, 2010
  15. frag
    Catman Guest
    That is some 2-3 generations old.
    Catman, Feb 4, 2010
  16. frag
    About 2 days max, depending on usage. Use the apps a lot and it
    decreases considerably. That's with 3G turned off and Wifi on most of
    the time, though.
    Nope.
    Timo Geusch, Feb 4, 2010
  17. frag
    Cab Guest
    I read that post and then figured out it was Nige writing it. Just a sudden
    flash, that caught me by surprise.
    Cab, Feb 4, 2010
  18. frag
    Cab Guest
    My iPhone goes for ages. My Dext too (although that's quite new atm).
    I have a battery pack that I slot into the iPhone in case of emergencies
    which works quite well. I've only used it once or twice though.
    Cab, Feb 4, 2010
  19. frag
    Cab Guest
    Phones are consumer items today. A decent battery will live _up_ _to_
    four years but will probably die at around 18 months (on continuous
    usage). I won't have my iPhone at 18 months but will have the next
    generation of funky phone (even if it's an updated iPhone, probably).
    Cab, Feb 4, 2010
  20. frag
    frag Guest
    How's the Ford Model T going nowadays?
    frag, Feb 4, 2010
