OT in some locations: New skis
Discussion in 'UK Motorcycles' started by Jérémy, Sep 17, 2009.
  1. Jérémy
    Jérémy Guest
    (x-posted to ukrm in case no-one uses the ski groups any longer)
    With great sadness I think I'm going to have to give up my old X-Screams.
    The bases remain as indestructible as ever, but the gimmicky shock
    absorbers on top are leaking some horrible sticky black substance.
    I have taken no notice of current ski trends for several years, and I
    have no idea what is on offer these days, so I'm looking for suggestions
    to narrow the field.
    I am 179cm and weigh 76kg. Ski style toute neige tout terrain - I enjoy
    bumps, I like silly tricks on the piste (but I only jump in a straight
    line, I'm too old for any more ski injuries), but mostly I ski off piste
    in any conditions. I love steep couloirs when I'm in practice, but
    anything is probably going to be shorter than what I have now anyway. The
    skis will get Diamir bindings, so no silly modular stuff. Skins will only
    be for occasional use for access and insurance against route finding
    cock-ups (I have touring skis), but I'd still prefer the skis not be too
    heavy. Obviously I don't need the latest fad, last year's classic would
    be ideal, especially if I can pick them up cheap in the early season
    sales (I live in the Alps, so I have plenty of shops to choose from).
    So, what should I be looking at?
  2. Jérémy
    B650 Guest
    I went from my X-Screams to K2 Apache Recon a couple of years back
    after mine started leaking the same goo
    Very happy I am
    B650, Sep 17, 2009
  3. Jérémy
    Jérémy Guest
    Looks promising, except for what looks suspiciously like some silly
    modular stuff to do with bindings. Can you put Diamirs on them?
    OTOH, now I look at the K2 web site, they seem to have an entire range
    designed for me. Unfortunately it's called "Backside".
  4. Jérémy
    Not much, it's true. Year on year it's been dropping. Only two
    threads, four posts, since July. But I'm still here.
    OK, let's stop you there. If this is the priority, then you need to be
    looking at mid-fat or fat skis. But what you don't say is how hard you
    ski. This is of utmost importance - if you glide gently and stylishly
    over all types of terrain you'll want something very different than if
    you blast at max speed wherever you are.
    I used to tend towards the latter, but since the broken back have been
    little more circumspect, so I've not fully embraced the big, long, fat
    skis, sticking with my 3-y-o 177cm Foils. Seems that the current (well
    last season's) Salomon equivalent is the Lord, which is somewhat
    wider, but not excessively so. There are a number of skis by all
    menufacturers in this category, and you could do worse than start by
    looking at the tests on the skiclub site at
    http://www.skiclub.co.uk/skiclub/membersonly/skitests/default.aspx
    Oh, it's members only - you are a member, aren't you?
    Well, I'll C&P their descriptions of the two types you'll most likely
    be looking at, to get you started.
    Big Mountain
    "Last season the introduction of rockered skis from the big
    manufacturers was the big new story. This year sees an evolution of
    that, with more variations of full, semi and front-rockered fats
    emerging. Many models have a rockered tip and tail, but a traditional
    camber through the middle. To add to the confusion, classic
    backcountry skis with a more traditional sidecut and flex are still
    out there, and are still favoured by high-speed freeride specialists.
    Because we were blessed with fresh, light, deep powder for most of the
    week, this was a true test of the latest fat skis. So much choice can
    be daunting for buyers. It’s hard to generalise with these fat skis,
    but here are a few simple guidelines: Generally, rockered skis are
    easier to pivot, and feel playful - while allowing you to be more
    balanced over the middle of the ski. Classic fats with traditional
    camber are more stable at speed, less twitchy and normally smoother
    and grippier on the piste. In any type of ski, more width in the waist
    makes for extra flotation and easier riding, but will make them slower
    onto the edge and less responsive for shorter turns. There is still a
    massive variation in performance between each model - more than in any
    other category we test - so, if you can get the chance, try before you
    buy."
    Freeride:
    "If you are really into your off piste, but also happy to rip around
    on the groomed runs when the powder’s not happening, these are the
    type of skis you need to check out. There is a massive choice and
    variation in design, but essentially it’s about deciding what type of
    skiing you’ll usually do. If you are obsessive about searching out
    even the smallest powder stash, go for the more off-piste orientated
    models. If you tend to be more of a 50/50 skier, and hack around on
    the piste quite regularly, then it’s the models that offer a
    good-quality piste performance. Generally the skis in this range have
    got wider this year, but don’t let that deceive you: it’s now possible
    to get good carving performance with anything up to 90mm of waist
    width. A while back, this would have seemed crazy, but as always, the
    manufacturers seem to be able to move the goalposts as new materials
    and designs emerge."
    Ace, Sep 17, 2009
  5. Jérémy
    Buzby Guest
    As per subject - anyone been? Recommendations?
    Buzby, Sep 17, 2009
  6. Jérémy
    Can I get back to you in a couple of weeks? I'm sitting in the lounge
    at LHR waiting for my flight to Buenos Aires, from where I'll be
    joining my newly-BASI-level2-qulified wife at Bariloche (in Argentina)
    and skiing both there and some of the Chilean resorts which are
    apparently just a few hours away in a rental car.
    I'll try and do a full write up when I get back. If anyone objects to
    it being here, on RSREurope, well, I'll be very surprised, and not in
    the least bit bothered ;-)
    Ace, Sep 17, 2009
  7. Jérémy
    Buzby Guest
    Ha! You lucky git.
    Enjoy. I'll be picking your brains on your return!
    Buzby, Sep 17, 2009
  8. Jérémy
    You make your own luck.
    Please do so. I confess to knowing almost nothing about where we're
    going to ski, but in this I'm quite happy to leave the decision-making
    to J, who will have the benfefit of local knowledge, having been there
    for eight weeks now.
    And she's not really 'lucky' to be there either. Sure, she's still
    being paid as a full-time employee while she's there, but on the flip
    side come December she's out of a job.
    On the other flip side, she'll walk in to any number of consultancy
    jobs, while doing the odd but of instructing in Engelberg and reaping
    all the benefits thereof, like free lift pass and hyooge discounts on
    everything.
    Well, that's _my_ plan, anyway. Hers may be slightly different :-}
    Ace, Sep 17, 2009
  9. Jérémy
    BrritSki Guest
    Feck 'em I say. Enjoy the hols and congrats to your better half !
    BrritSki, Sep 17, 2009
  10. Jérémy
    Acherly, I realise the congrats are premature. Tomorrow's the last
    day[1], so she should have passed by the time I get there. Looking
    forward to a good passing-out party when I arrive.
    [1] Although there's still another week for remedials[2], but from
    what I can gather she'd not going to need any. 60-odd people on the
    course, though, so a fair few may need it.
    [2] Which also offers race-training and other stuff, in with which I'm
    welcome to join. Shit. [3]
    [3] Unfit, out-of-season, newly-passed instructors, mostly very young.
    I'm likely to be severely embarrassed.
    Ace, Sep 17, 2009
  11. Jérémy
    B 650 Guest
    Hmmm, missed that part of the original post, I've got them with the
    stock bindings on, so not sure if there's an alternative.
    If you buy a pair of K2s, be wary of going to Colorado and leaving them
    in a rack outside a restaurant, you'll come out and realise the racks
    have all filled up with *exactly* the same skis as yours, then wish
    you'd paid more attention to where you'd left them....
    B 650, Sep 17, 2009
  12. Jérémy
    Roger Moss Guest
    Whatever you decide, if you're in the Alps then you should definitely be
    looking at http://achat-ski.com/ for some of the best deals.
    I picked up a pair of previous season's Rossignol B3s at around 60-70%
    discount - some real bargains to be had if you don't 'need' latest fad
    graphics!
    But you already knew that...
    RM
    www.mountainpassions.com - an Online Magazine with Altitude
    Roger Moss, Sep 18, 2009
  13. Jérémy
    Brian Mc Guest
    : I went from my X-Screams to K2 Apache Recon a couple of years back
    : after mine started leaking the same goo
    : Very happy I am
    I am also very happy with my Apache Recon's! Excellent skis!
    Brian Mc, Sep 18, 2009
  14. Jérémy
    No answers from me, just the observation that I'm also toying with the
    idea of buying new, or secondhand skis too. I've got a reasonable pair
    of Head carving skis but I had to hire something more off-piste
    oriented last year after a couple of hints from my instructors.
    If I do then they'll probably something like Rossignol Bandits or
    whatever they call them this year (none of that twin-tip stuff for
    me). Ideally good second-hand so I won't be so worried about losing or
    damaging them.
    Damn that ski club for getting me interested in off-piste!
    Pip Luscher, Sep 18, 2009
  15. Jérémy
    BrritSki Guest
    Wife and I both lke our Bandits which we've had for a few years now.
    If you live in the Alps, narrow it down to a few different skis and then
    demo to see which ski you like best and in which length for the type of
    skiing/conditions you'll most likely encounter. But you knew that right ?
    Good luck
    BrritSki, Sep 19, 2009
  16. Jérémy
    I think they were the ones I hired, actually. Seemd to carve well
    enough and I didn't have any [ski related] problems off piste, other
    than a nervous sense of "help, these aren't my usual skis!"
    They carved a lot better than I expected, though I didn't really
    manage the tight radius turns my Head skis could.
    How well do they cope with hard-packed icy home runs?
    I'd love to be able to do that. Sadly, round here is about as far form
    Alpine a it's possible to get (I live close to the Cambrifgshire Fens,
    in much the same way the Brighton is close to the sea). If the
    exchange rate were better then I'd try out a few different types and
    buy abroad, but it's probably not worth it at the moment.
    I have seen what look like some good deals online, but I'm a little
    unsure about that. Possibly just older models, but that wouldn't
    bother me too much.
    Ta.
    Pip Luscher, Sep 19, 2009
  17. Jérémy
    BrritSki Guest
    I manage to do a complete on snow 360 on them - i.e. find a nice flat
    wide piece of piste and hit it at one side at max. speed and then lay
    them over as far as they can go - if you're going fast enough you can do
    a complete circle :)
    OK I guess, but I tend to avoid resorts like that :)
    Ah, I was replying as much to the original poster who I think said he
    lived near some mountains...
  18. Jérémy
    Eugene Miya Guest
    What this got to do with bikes?
    A colleague at Oxford did sabbaticals at Bariloche. He probably skied
    there.
    I am on a waiting list for volunteers on research experiments which can
    require skiing on the Chile/Bolivan border. Pay for fly down there? Ha.
    Check the Reuter's book.
    Eugene Miya, Oct 1, 2009
