OT : IIS State
Discussion in 'UK Motorcycles' started by dwb, Apr 3, 2004.
  1. dwb
    dwb Guest
    Hence my reply a little up/down there about it not being the problem.
    I know it's not the problem because we sucessfully ran with 10 ten times the
    load but with the previous version without incident over Christmas.
    What I'm trying to work out is how to to resolve it - if it can be resolved.
    Tomorrows task will be code optimisation :'-(
    dwb, Apr 4, 2004
  2. dwb
    dwb Guest
    The server is not failing Steve.
    An application running on the server (IIS) is exhibiting undesirable
    behavior due to a client of that program.
    The server is happy as larry.
    dwb, Apr 4, 2004
  3. dwb
    Steve Morgan Guest
    Possibly an oversimplication, but, yes. Especially in loops. Find out why
    there's so much concatenation going on and do it some other way. If they're
    doing something way clever like creating XML by concatenating strings
    together then don't hesitate, just kill them. I had an application some time
    ago that did a lot of string concatenation that would have been really
    difficult to avoid. So, I wrote a small C++ COM component that implemented
    an efficient 'growing' string class. It's a bit awkward in VBScript, because
    you haven't got anything useful like a StringBuilder or buffers without
    calling something else.
    If you don't find a simple answer, get a better description of the problem
    and I'll come up with something a bit more specific.
    Steve Morgan, Apr 4, 2004
  4. dwb
    Steve Morgan Guest
    I are suggesting that having done some more detailed analysis of the
    original evidence, I am very, very, very confident that it's an application
    problem. I are also relatively qualified to be very, very, very confident.
  5. dwb
    deadmail Guest
    You don't need to be qualified to be very, very, very confident. Of
    course, being qualified/experienced it's more likely that when you're
    confident you're also correct ...
    deadmail, Apr 4, 2004
  6. dwb
    Steve Morgan Guest
    *ding*
  7. dwb
    Ianf Guest
    Following up on this, see if there's any huge strings involved, as the
    code you originally caught this thread executing chops up allocations freed
    and bungs them on the appropriate sized freelist buckets for the heap in
    question.
    if it then goes and makes another allocation > the bucket size for the
    largest freelist, it'll take virgin heap again. This in the long run would
    leave you with long unused freelists.
    Ianf, Apr 5, 2004
  8. dwb
    dwb Guest
    <snip>
    Well the MS group were right - it did appear to be a string issue.
    Changed the logic and the code today and the CPU usage went straight back
    down to <30% with a responsive website.
    Cheers to all for the suggestions, though I reckon that Sorby's suggestion
    to change the regional settings was the thing that actually worked.
    dwb, Apr 5, 2004
  9. dwb
    Klaatu Guest
    Jeremy thinks "taking the system down" is putting them in the lift.
    Klaatu, Apr 5, 2004
