OT : HTML editors?
Discussion in 'UK Motorcycles' started by frag, Jan 14, 2006.
  1. frag
    frag Guest
    Right, I've been tasked with customising an applications help files
    which are written in HTML using Frontpage.
    Now its been years since I had a play with HTML editors, but I'm
    looking for one that will let me manage all the .htm and image (and any
    other) files as a project, and give me an overview of the whole
    project, what links to what, a sort of connection diagram.
    I've had a little play with Frontpage 2003 (free via MSDN subscription)
    but is there anything else out there better?
    Whats Dreamweaver like? And what happened to HotMetalPro? And would it
    be more hassle than its worth to try to use something like RoboHelp?
    This has got to be a quick revamp done by next Friday, remove sections
    not wanted and re-write a couple of sections. Something that could
    import all the HTML, let me edit it quickly, and then produce compiled
    HTML and PDF would be great!
    frag, Jan 14, 2006
  2. frag
    elyob Guest
    That sounds like a really horrid task. Tell them to stuff it.
    Frontpage and other WYSIWYG's are generally shite from a developers point of
    view, but excellent if you cannot be arsed to learn the simple language of
    HTML.
    I personally use a text editor (ultraedit) and subversion for version
    control. I run a web server and sql database on all my machines. I swap
    between different machines depending where I'm going to be.
    If you have to use WYSIWYG's, then DreamWeaver is probably better, but it
    sounds like you're already on a frontpage extensions server.
    It might be worth them paying me as at least I sound like I know what I'm
    doing. ;)
    elyob, Jan 14, 2006
  3. frag
    jussij Guest
    Another non-WYSIWYG HTML editor is Zeus for Windows:
    http://www.zeusedit.com/features.html
    It does the standard things like code folding and
    syntax highlight and also has features like project
    workspace mangement, ftp editing etc.
    NOTE: Zeus is shareware and offers a 45 day fully
    functional trial period.
    Jussi Jumppanen
    Author of: Zeus for Windows
    jussij, Jan 14, 2006
  4. frag
    frag scribbled on the back of a napkin:
    Nvu is a pretty decent HTML editor and it produces pretty conforming
    HTML, too.
    That said you'll probably need Adobe Distiller to get .pdfs out of it.
    Timo Geusch, Jan 14, 2006
  5. frag
    Cane Guest
    It's better than R obbo help.
    I'd go for Mozilla.
    Cane, Jan 14, 2006
  6. frag
    Judge Guest
    FWIW, I use Nvu to get the initial page layout right and then switch to Vim
    with a couple of macros from the Vim web site to do the rest of the work.
    I've also written a bit of Python to format the HTML source and do things
    like list the images or links used or report on structural errors (opening
    tags without closing tags).
    Judge, Jan 14, 2006
  7. frag
    elyob Guest
    Just because you have been 'clever' enough to put some sort of google alert
    on the word ultraedit, it doesn't mean you can come along and spam your own
    product. Now, if you had posted on here before it'd be understandable. But
    other than that, stay well clear of this shit if the author has to go down
    to these levels. Fucking targeted spammer.
    elyob, Jan 14, 2006
  8. frag
    R obbo Guest
    Typo or an attempt at humour?
    You'd go for anything IIRC
    ;-p
    R obbo, Jan 14, 2006
  9. frag
    frag Guest
    elyob scribbled:
    I'm sure my employer would take kindly to me saying that, 2ish months
    into my new job.
    Its not that I CBA to learn html (I already do), they're just quicker
    when it comes to simple changes.
    This is HTML thats sitting on disk and displayed as the help for the
    program. No server anywhere.
    Hah, I not EKS anymore!
    frag, Jan 14, 2006
  10. The message <dq9jdp$b8v$>
    from "frag" <> contains these words:
    /snip/
    Just about anything.
    For a WYSIWYG pogrom, Dreamweaver is the best I've come across.
    I use Notepad, or Arachnophilia, but when using the latter I tend to
    hand-craft most of what goes into the page.
    Validate what you have at www.W3.org first. Frontpage makes
    uranium-weight pages - most of the output is nothing but useless
    rubbish.
    Rusty Hinge 2, Jan 28, 2006
  11. The message <-consult.com>
    Or OpenOffice
  12. The message <>
    Can't get on with it, personally, though I have used it when on the
    Debian box..
  13. frag
    frag Guest
    Rusty Hinge 2 scribbled:
    I ended up using Dreamweaver, and ended up doing most of the HTML
    editing in the source code window.
    <sigh>
    Might have well just used Notepad :-S
    Yes, about half the time was spent removing FP rubbish, for instance
    what on earth is the <o:p> tag for?
    frag, Jan 28, 2006
  14. frag
    Ben Guest
    What's often more useful when editing xml type documents, is not
    WYSIWYG, but syntax highlighting. Makes it a lot easier to see if
    you've missed something out. UltraEdit and Editplus are very good at
    this. They will also do code completion as well.
    And if you want to see what you've done, then just keep a copy of the
    file open in a browser and hit refresh whenever you change something.
    Ben, Jan 28, 2006
  15. The message <drg0d3$oc$>
    Pass.
    I tried the M$ Worm option of 'Save as HTML' or whatever, and then did
    the same page in Dreamweaver, and again, in Notepad.
    The Worm file was about five times the size of the Dreamweaver one,
    which was only slightly larger than the Notepad one.
    I'm working on getting the bloke who does our village site to dump
    FrontSplurge and use something a bit better, and which is compliant with
    protocols.
    If you want to risk your hair, have a look at: http://www.bunwell.org.uk
  16. The message <>
    Thanks for that.
    I usually keep Firefox and Opera open on the 'Doze box.
  17. frag
    frag Guest
    Ben scribbled:
    In Dreamweaver if you edit the source, you have to save it and then hit
    F5 to see the changes in the WYSIWYG window, bit daft.
    frag, Jan 28, 2006
  18. frag
    frag Guest
    Err... The first page I clicked on, Parish Plans, the 2nd & 3rd text
    boxes are about 2.5 x as wide as they should be. First ones fine.
    In FF and IE.
    frag, Jan 28, 2006
  19. frag
    Ben Guest
    Ben, Jan 28, 2006
  20. frag
    Ben Guest
    That's because it has an IE engine built into it and it simply reloads
    the page in the browser after you save it.
    Ben, Jan 28, 2006
