OT-Help, error message :-(
Discussion in 'UK Motorcycles' started by Blotto, Jul 11, 2004.
  1. Blotto
    Blotto Guest
    Wonder if any of you tech people can help with this. I am running XP pro on my
    laptop and every time I start up I am greeted with this message:
    Error Signature BC Code : ce BCP1 : F9C02B04
    BCP2 : 00000000
    BCP3 : F9C02B04
    BCP4 : 00000000
    OSVER : S_1_2600 SP : 0_0
    Product : 256_1
    After displaying this message the machine then works fine, but annoying that
    this message comes up as obviously something is not quite right.
    TIA
    Matt.
    SV1000S.....Stickier than Sticky the Stick Insect stuck on a sticky bun.
    SV1000S, TL1000R, ER5, CD175D
    www.mhrandall.freeserve.co.uk (please pop the "pop" to reply)
  2. Blotto
    Stonge Guest
    Your best bet is to run MSCONFIG (from start>>run) and then untick all the
    things in the startup tab...
    If the problem goes away, then tick them one at a time until the problem
    comes back. This should give you some idea where the problem is.
    Stonge, Jul 11, 2004
  3. Blotto
    mb Guest
    Could be a hardware thing, maybe a driver been corrupted. Have a look
    here:
    http://aumha.org/win5/kberrmsg.htm
    mb, Jul 11, 2004
  4. Blotto
    Blotto Guest
    Cheers Mate, will do that and see what happens. Thanks for the reply.
    Matt
    Blotto, Jul 12, 2004
