OT FOAK smoke/steam after engine stopped?
Discussion in 'UK Motorcycles' started by Wizard, Jan 10, 2006.
  1. Wizard
    Wizard Guest
    What does it mean when white smoke/steam comes out of an exhaust
    for more than three minutes after the engine's been switched
    off?
    I test drive a Galant this weekend, and after 10 minutes
    driving, where the engine seemed fine, I was surprised to see
    the exhaust continue to discharge while I discussed the car with
    the seller.
    OK, it was a cold day, and our breath condensed and made us look
    like little dragons as we talked, but what the car was doing
    still seems odd.
    I'm thinking it probably means, in layman's terms, that the car
    is telling me to walk away from it. What does the FOAK think?
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    BMW 520i (RIP- Ebay item 4601147727)
    Toyota Nondescript 1.3 Mobility Appliance (on loan)
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Remove location from email address to reply
  2. Wizard
    Linger Guest
    I think it's a sign that it has been sitting for a while so there is a build
    up of water in the exhaust.
    10 mins would just about set it off evaporating and the heat stored in the
    exhaust system would keep it vaporising.
    wibbly flip.
    Linger, Jan 10, 2006
  3. Wizard
    Wizard emerged from their own little world to say
    Did the car have a turbo? If so then there may be a fan that runs for a
    while after the engine is switched off. This would cause hot air to come
    from the exhaust. As the air cools the water vapour within would condense.
    wessie, Jan 10, 2006
  4. Wizard
    Wizard Guest
    No turbo. A catalytic converter, which I suppose could trap
    moisture in line with Linger's suggestion.
    FWIW it wasn't just a few wisps, it was enough to get Fred
    Dibnah interested. About as much as you'd see from a kettle
    about to boil. So if it was condensation, there'd have been a
    fair bit of water in there.
    Ebay item 4602348521, if anyone's interested.
    <8P Wizard
  5. Wizard
    ginge Guest
    It very much depends if it is smoke or steam. Take a clean white rag
    and hold it in the path of the vapour.
    If it leaves a dark and smoky residue something is burning, somewhere,
    and it could be expensive.
    if it's watery vapour it's likely to be nothing, or maybe less
    expensive.
    ginge, Jan 10, 2006
  6. Wizard
    SteveH Guest
    AFAIK it's a bit of condensation in the exhaust system. I've noticed it
    a few times recently from my car.
    BTW, you clumsy **** ;-)
    SteveH, Jan 10, 2006
  7. Wizard
    Wizard Guest
    It is indeed. I was impressed by it. I can see why SWMBO still
    raves about hers.
    Sadly, he's reversed it into a post, and the rear plastic
    skirting round the bottom is crumpled. It may be possible to
    push it back into shape, but it may snap.
    Also, at 128,000 miles, I'm wondering if a lot of things may be
    about to go wrong.
    I think it'll go for more than 500GBP- probably more like 800.
    But not, I think, to me.
    <8P Wizard
  8. Wizard
    Wizard Guest
    Or a buggered head gasket letting water leak slowly into a
    cylinder?
    <8P Wizard
  9. Wizard
    Wizard Guest
    SteveH
    () says...
    Guilty, yeronner.
    <8P Wizard
