OT / FOAK: PC problem
Discussion in 'UK Motorcycles' started by Frooty, Dec 21, 2005.
  1. Frooty
    Frooty Guest
    You guys have helped with a PC problem in the past so I thought it would be
    worth another go!
    Desktop PC (HP / Aspire T120, Win XP, Socket A - 462 MoBo, Athlon XP3000+
    CPU, GeForce MX440 graphics, 19" CRT monitor).
    In the past when booting up it would occasionally run right through until
    loading personal settings then reset itself, booting up OK the next time.
    More recently it would do the same, but on rebooting the monitor wouldn't
    startup.
    Switching it off for a couple of minutes resolved it & it was fine next
    time.
    Now it won't boot the monitor up at all (no error beeps or similar) - it
    spins the HD, everything else seems to be starting but no screen - I've
    tried the following, all to no avail:
    Swapping the monitor cable to the onboard graphics (removing the AGP card,
    of course), tried a different monitor, in both connections, tried an older
    graphics card, unplugged the monitor (it popped a message on screen saying
    it was disconnected - so I don't think the monitor is faulty). Also tried
    two different memory chips.
    I Googled and found the only people with an IDENTICAL problem eventually
    found the CPU was at fault (I know this is quite rare).
    So, thinking I would take the chance to upgrade a bit, bought a Socket 754
    Asus MoBo & Sempron 3100+ CPU (guaranteed working!).
    Fitted it, with the aid of the manual & ensuring everything was where it
    should be & guess what - exactly the same!!!!!
    No monitor signal & no way of telling what the bloody problem is!
    Now I'm at the end of my tether, & copious use of the big hammer may ensue
    if I can't get it fixed!
    Any ideas on what's causing the problem?
  2. Frooty
    Vass Guest
    Format disc with new CPU + MBoard - reinstall OS
    Vass, Dec 21, 2005
  3. Frooty
    Dr Zoidberg Guest
    Failing PSU would be my guess.
    That matches the symptoms.
    Alex
    www.drzoidberg.co.uk www.ebayfaq.co.uk
    Dr Zoidberg, Dec 21, 2005
  4. Frooty
    Catman Guest
    *DING*
    possible check would be *unplug* it for 10 minutes and try again. It
    *might* boot. If it does, the PSU is almost certainly dying (although
    sometimes they will carry on for ages) if it dunt, it proves very little.
    Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3 OMF#22
    Alfa 116 Giulietta 3.0l (Really) Sprint 1.7 156 TS S2
    www.cuore-sportivo.co.uk
    Catman, Dec 21, 2005
  5. Frooty
    You've gone blind.
    Krusty.
    http://www.muddystuff.co.uk
    http://www.muddystuff.us
    Off-road classifieds
    '02 MV Senna '96 Tiger '79 Fantic 250
    Krusty, Dec 21, 2005
  6. Frooty
    Didn't Dodger have this exact problem, only a couple of weeks ago?
    Having just looked at the price of new ones, I'd go and buy a new PC
    and cut out all the crap.
    Pip, Dec 21, 2005
  7. Frooty
    Frooty Guest
    I knew all that wanking would have an effect in the long run!
  8. Exactly the same as I had a couple of weeks ago. Turned out to be a
    dodgy PSU. Bit of a bugger, as it was a decent make and quite good
    quality.
    GS850x2 XS650
    On UKRM you're just a **** with opinions.
    Grimly Curmudgeon, Dec 22, 2005
