OT FOAK how to get end of broken HT lead? (long)
Discussion in 'UK Motorcycles' started by Wizard, Nov 3, 2004.
  1. Wizard
    Wizard Guest
    My car's been getting hard to start, and sometimes failing entirely in
    damp weather, so I decided to check over the HT leads and distributor.
    Leads and dizzy off, quick wipe down, check for condensation in the
    dizzy, no problem. Put insulating tape over some bits of the leads where
    the insulation's chafed and is getting thin. Good stuff.
    Then I go to put it all back... problem.
    This is a 16V DOHC engine, so there's a camshaft along the front of the
    engine, four plugs down the middle, then a camshaft along the back. Each
    plug is at the bottom of a shaft about six inches deep and an inch
    across. Each HT lead runs through a right-angled rubber thing, then down
    a rigid plastic tube, with the connector that clips onto the plug on the
    end.
    Three leads go back in, easy. One just squodges. Comparing it with the
    other leads, I find that the connecter that clips onto the plug has
    broken off, and the end of the HT lead is dangling in the plastic tube.
    So... more in hope than expectation, I bung it all together as best
    it'll go, and take it for a test drive. It works! It misfires below
    2500rpm, but it works. This is handy because I'm at SO's place, 70 miles
    from home, and need to get home. So, I set off home, and arrive without
    problems.
    Next day, however, the luck runs out, and the car won't start.
    So... any ideas on how to get that squodgy rubber connecter out? I'm
    assuming the little metal bit inside is nicely clipped to the plug,
    holding it in place.
    My first thought was a big FOAD pair of long-nosed pliers. But I'm not
    convinced that it'll work, as they'd have to be *very* long-nosed, and
    even then I'm not sure it would be possible to get a strong enough grip
    on the rubber bit.
    Second thought was to take the cam cover off, hence exposing the plugs
    and the offending broken-off connecter. Trouble is, the inlet manifold
    runs over the top of the engine, so that would have to come off as well.
    If it's gotta be done, it's gotta be done, but... <8(
    Can the FOAK suggest any better ideas?
    TIA
    <8( Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    Golf GTi 16v
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Wizard, Nov 3, 2004
  2. Wizard
    SP Guest
    Buy a new one, they aren't all that expensive. In fact, replace the
    whole lot including the leads, jobs a good 'un.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Nov 3, 2004
  3. Wizard
    Wizard Guest
    Eh? Lesley???
    Er... I think there might be a whoosh here, or something. I'm not sure
    if it's you or me being whooshed, though. Depends what you mean by "Buy
    a new one".
    If you mean "Buy a new car", then FOYRNB, you are Darsy AICM5
    "Considerably Richer Than Yow" posts, etc etc.
    If you mean "buy a new HT lead", then sure, that goes without saying,
    but the problem is how to get the end of the old one out of the engine,
    as it's at the bottom of a shaft six inches deep and one inch wide.
    <8P Wizard
    Golf GTi 16v
    Wizard, Nov 3, 2004
  4. Wizard
    Changing the leads would be the sensible option as to getting out of your
    current predicament:
    Remove the plug with a plug spanner and then remove the end in the
    comfort of your well equipped workshop.
    sweller, Nov 3, 2004
  5. Wizard
    Dan White Guest
    Turn the car upside down and shake it.
    Dan White, Nov 3, 2004
  6. Wizard
    flash@work Guest
    I tried that once with a CB250G5. My top tip is to remove the oil first.
    flash@work, Nov 3, 2004
  7. Wizard
    eh?
    darsy, Nov 3, 2004
  8. Wizard
    Preston Kemp Guest
    Chomp it up with a sharpened screwdriver then suck the bits out with a
    hoover? Or pour some petrol down the hole & flambé the fucker.
    Preston Kemp, Nov 3, 2004
  9. Wizard
    Dan White Guest
    Length of dowelling rod with epoxy resin on the tip. Stuff it down hole and
    contact rubber bit. Leave for an hour to harden, then pull the fucker out.
  10. Wizard
    Ben Blaney Guest
    I think he might be harking back to the glory days of 1999.
    Ben Blaney, Nov 3, 2004
  11. Wizard
    even so, he appears to have got me confused with Sniper and Ace...
    darsy, Nov 3, 2004
  12. Wizard
    SP Guest
    Of course not! And I'm deeply hurt that you put me in the same league
    Well, although it is a tad hard to do, it can be done and would really
    be your best option, as a botch fix for now won't last long and you
    will have to replace them sooner or later, so you may as well do it
    sooner. You could always take it to a mechanic and let them do the job
    for you but naturally that costs more beer vouchers :eek:)
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Nov 3, 2004
  13. Wizard
    Zymurgy Guest
    Hmm, can't you leave the bit of lead in place and use a box spanner
    (as I think sweller is suggesting) rather than a plug socket and
    extension to get it off.
    Or use a plug socket with a hex around the top and use the hex with a
    box spanner rather than the 3/8" or 1/2" square drive
    Or use a pair of locking forceps to get the metal bit off. I got a
    nice pair (fnarr) from an autojumble once. Much slimmer than a pair of
    long nose pliers.
    None of this helps you if you have none of the above ... !
    Cheers,
    Paul.
    Zymurgy, Nov 3, 2004
  14. Wizard
    Wizard Guest
    The question is, how to do it. Fortunately, I had an idea while at work;
    I remembered one can get tools with a claw at one end, which could fit
    down the hole and grab the offending thingy. The estimable Midnight
    Motor Co of Watford has such a tool in stock for a fiver. I'll be
    visiting them later this evening.
    "Get a man in"?
    You are Cane AICM5-
    Oops.
    <Offers box of tissues again.>
    <8P Wizard
    Golf GTi 16v
    Wizard, Nov 3, 2004
  15. Wizard
    Wizard Guest
    *Nice*
    <8P Wizard
    Golf GTi 16v
    Wizard, Nov 3, 2004
  16. Wizard
    Verdigris Guest
    On Wed, 03 Nov 2004 00:40:38 +0000, Wizard wrote:
    Crochet hook.
    Verdigris, Nov 3, 2004
  17. Wizard
    SP Guest
    Pay cheques?
    Cool.
    Ta.
    Lesley
    CBR600FW
    BONY#54P BOB#18
    SP, Nov 4, 2004
