OT FOAK: Cleaning oil from an ECU
Discussion in 'UK Motorcycles' started by Buzby, Apr 9, 2009.
  1. Buzby
    Buzby Guest
    It would appear there has been an ingress of oil up a wire sleeve
    overtime which has flooded the (auto) gearbox ecu on the Buzby
    battlebus, sending it into a hissy fit and refusing to change out of
    first gear.
    Is is possible to wash them out with cleaner - and if so any
    recommendations as to what to use?
    Buzby, Apr 9, 2009
  2. Buzby
    We used a giant water based dishwasher when refurbishing electronics
    at an industrial scale. Then baked them in an oven to dry.
    In this case I'd probably use isopropanol and hope that the oil didn't
    contain any metallic compounds that allowed those pesky little
    electrons to get to places they shouldn't have...
    wessie, Apr 9, 2009
  3. Buzby
    Paul - xxx Guest
    Landrover Discovery 2's have a similar fault, oil ingress into the
    injector wiring loom and/or ECU. The real fix is a new loom ... but
    good results are said to be had from flushing using Gunk (an oil
    detergent), then Contact Cleaner and a copper (spark plug stylee) brush
    on all the wiring and connections.
    The affected part of the loom and ecu need to be out really, to do a
    proper job.
    Paul - xxx, Apr 9, 2009
  4. Buzby
    Buzby Guest
    We'll see - although I'm going to give the dishwasher a miss as I can't
    split the box.
    Buzby, Apr 9, 2009
  5. Buzby
    Buzby Guest
    Swot I figured - I'm going to have at cleaning the ecu up - I think
    that part of the loom may be a strightforward swap out. I better grease
    up and go see the local merc spares emporium . . . . .
    Buzby, Apr 9, 2009
  6. Buzby
    Timo on tour Guest
    Electrical Contact Cleaner is your friend - get the automotive "safe
    on plastic" version. I'd open the ECU and clean it out, though.
    Timo on tour, Apr 14, 2009
