ot car special editions
Discussion in 'UK Motorcycles' started by darsy, Oct 31, 2004.
  1. darsy
    SteveH Guest
    Difference is that Honda can screw things together properly, Ford can't.
    I'd even trust the Italians and the French to do a quad-cam, 24v V6
    before I'd trust Ford to do it.
    SteveH, Nov 3, 2004
  2. darsy
    Bear says...
    Once upon a time I was workshop manager for a firm that fitted car
    alarms. We got the contract with Maranello Concessionaires to fit alarms
    to used and new Ferraris and Lamborghinis. My boss was dead chuffed
    about this, because it meant us having a Ferrari/Lambo kicking around
    most of the time for him to pose in when picking them up and delivering
    them back[1]. This would have been great for him, if he hadn't weighed
    about 25 stone. He found it almost impossible to cram his bulk into a
    308GTB, let alone any of the more sporty versions we encountered. Once
    he had squeezed himself into the cars he found he couldn't drive the
    things. As there were only two people on the firm who were over 25 and
    posessing clean licences it fell upon the other person ....me, to drive
    these cars around.
    [1] New cars were delivered on a trailer by M.C. I drove the old company
    C15 van down to pick up the used ones from the compound at Silverstone
    and drove them back, leaving the van behind.
    Lozzo, Nov 3, 2004
  3. darsy
    SteveH says...
    <coughcamchaintensionerscamshaftsandreg/recscough>
    Lozzo, Nov 3, 2004
  4. darsy
    SteveH Guest
    To be fair, the camchain tensioner issue was sorted out years ago. The
    only rectifier fail I've had so far was on a Suzuki - however, my
    brother had his VFR fry one, so he's fitted a heatsink and CPU fan to
    his now.
    SteveH, Nov 3, 2004
  5. darsy
    Andy Hewitt Guest
    It is more efficient yes, but it doesn't produce more power, you need to
    increase the revs to do that, or burn more fuel.
    Andy Hewitt, Nov 3, 2004
  6. darsy
    Andy Hewitt Guest
    No, they aren't *that* powerful, however, as Steve says, there's a lot
    more complication, and the chain on these is 7 ft long!.
    Yes, the old Rover was good too, especially the Vitesse version. Shame
    about the rust though.
    Yes, no engine likes that kind of life much.
    None of the Fords handled well at that time. Try a Sierra estate!
    Oooh, not nice.
    I must admit I like curves, these new sharp angles just don't do
    anything for me at all.
    No, but I have seen one squeeze into an Arkley kit car!
    It was a great engine, why change something that works? (eh Rover!)
    <Snipped Text>
  7. darsy
    I must be missing something.
    More efficient means, to me, more power from the same volume of fuel.
    Or, to use a classical definition, efficiency is the ratio of energy
    in (fuel) to energy out (torque, *not* power.)
    On that basis, if a diesel makes more torque per unit volume of fuel
    than a petrol engine, then it must make more power at the same revs.
    Increasing the revs is just another way of using a greater volume of
    fuel per unit time, and has nothing to do with efficiency per se.
    ogden, Nov 3, 2004
  8. darsy
    Bear says...
    Ummmm.....my quad cam V6 2.5 litre Mazda engine wasn't reliable. It ate
    camshafts with a regularity that threatened to take my old VF750's title
    as "Most unreliable vehicle I've had"
    Lozzo, Nov 3, 2004
  9. darsy
    tallbloke Guest
    Hey, that's my line.
    And it's HONDA by the way.
    tallbloke, Nov 3, 2004
  10. Sniff, sniff.....
    <swims away>
    The Older Gentleman, Nov 3, 2004
  11. The Fabia is a much, much smaller, lighter car. It's comparing a
    Polo-sized car with a Mondeo-sized car.
    My old ZX 1.9 TD returned mid-40s, and when driving gently, 50mpg. I've
    yet to do a long gentle run in the Silver Tuddy, but to judge by the
    econometer-thingy, I reckon low-to-mid 40s is about right.
  12. Depends which car they're bolted into, as I said up there somewhere. For
    example, in the Skoda Superb, the 1.9 only gives about 30mpg.
    In the Fabia, it gives closer to 50.
  13. *Ding*
    For years, that's been the case, but the advent of Euro 5 and beyond
    means new engines have to be developed.
    Previously, you've been able to add common rail, CRTs and cats,
    four-valve heads, etc etc, but there are limits.
  14. *Smart*.
  15. I'm sure this is right.
    As said somewhere else in this thread, there's only so much you can do
    to an engine to make it meet emissions targets. As the regulations get
    tighter and tighter, sooner or later you have to design a new lump.
    But the old Rover V8 has had a bloody good run for its money - something
    like 40 years, innit?
  16. darsy
    The Older Gentleman was seen penning the following ode to ... whatever:
    Close to - AFAIR Rover got it in the early-to-mid sixties, so Buick
    probably developed it in the late fifties...
    Timo Geusch, Nov 3, 2004
  17. darsy
    Wizard Guest
    <SNIP>
    IIRC Granadas could be made in Dagenham or Cologne.
    Certainly there was some Ford car that could be made in Britain or
    Germany, and it was pot luck what you'd get; but if you got one with a
    vinyl roof, it definitely be Germany.
    My Mum worked in a Ford dealer at that time (late 70s/early 80s). Her
    job involved sitting down with customers after they'd signed up to buy a
    new car, and sorting out the nitty gritty of where to get it; she'd
    either get hold of an existing one from elsewhere in the Ford UK
    distribution network, or she'd arrange for one of the factories to build
    it.
    Obviously she wasn't allowed to bias the choice between the two
    factories in any way. But the conversation used to go something like
    this:
    "Your new car will be from either Dagenham *WINK* or Cologne *WINK*.
    Obviously you won't care one way or the other if your car's Made In
    Britain *WINK* or Made In Germany *WINK*. But I should mention that if
    you order it with a vinyl roof *WINK* then it'll be Made In Germany
    *WINK* *WINK*".
    <8P Wizard
    Suzuki GS550 "I like that. Nicely shite" - TOG
    Golf GTi 16v
    ANORAK#17b BOMB#19 BOTAFOT#138 BREast#5 COFF#24
    COSOC#8 DFV#11 STG#1
    Wizard, Nov 3, 2004
  18. darsy
    Salad Dodger Guest
    Orthopaedic?
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 3, 2004
  19. darsy
    But you can't increase the revs, you wouldn't have enough time to
    actually burn the fuel needed. That's why they run at lower speeds.
    Muck, Nov 3, 2004
  20. darsy
    SteveH Guest
    MkIV Escorts came from either Germany or Britain.
    I was lucky in that I got one from Germany - essentially they were an
    utterly shite car, but the German ones didn't rust in the same way and
    also seemed to avoid the CVH death-rattle for another 30k miles.
    SteveH, Nov 3, 2004
