ot car special editions
Discussion in 'UK Motorcycles' started by darsy, Oct 31, 2004.
  1. darsy
    Andy Hewitt Guest
    I have to ask, and I've been wondering now, but WTF is a Silver Tuddy?
    They're only a standard CD/DVD drive, so no reason they won't last as
    logn as a pooter one.
    Andy Hewitt, Nov 2, 2004
    #81
  2. darsy
    Andy Hewitt Guest
    And the Japs of course, both Honda and Toyota develop their own. Mazda
    and Nissan do not.
    Hyundai do as well.
    That'll be most of them I guess, the volume will also make a difference
    too.
    #82
  3. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember (Andy
    Hewitt) saying something like:
    About 18months then.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Nov 2, 2004
    #83
  4. Silver Primera - new shape. Se trim level
    Looks just like a tapered-at-both-ends tuddy to me.
    Done about 1800 miles in it now - chassis is impressive, equipment no
    less so, 2.2 DCI engine okey and torquey - potentially economical but
    for the temptation to tonk it. It's doing about 37-40mpg overall. I had
    hoped for slightly better.
    The Older Gentleman, Nov 2, 2004
    #84
  5. Yes, absolutely.
    Toyota sell millions of Corollas, for example. With big engines and
    shorter production runs, you get problems. Like truck engines.
    People moan about "loads of lorries on the road" but the number of
    trucks on Uk roads has been falling for decades, as vehicles and
    distribution systems get more efficient.
    There are only about 400,000 trucks (over 3.5 tonnes) on UK roads,
    compared with 21 million cars. But this means if you're devloping a new
    engine that will only sell, maybe, 100,000 units globally, your
    amortisation of devlopment costs makes you weep.
    #85
  6. darsy
    Ginge Guest
    I get 30MPG out of my 150 BHP 2.2 Petrol engine, despite being driven
    with a lead foot.. That's shocking for a diseasel.
    Ginge, Nov 2, 2004
    #86
  7. darsy
    SteveH Guest
    I suspect your lead foot may not be as heavy as some other lead feet....
    SteveH, Nov 2, 2004
    #87
  8. darsy
    Andy Hewitt Guest
    Not really. It's the old free lunch thing again. You can't have power
    without using fuel, more power uses more fuel. It's all quite simple
    really. If you get similar power from a diesel to a petrol, then they'll
    most likely do similar consumption too. Most notably the BMW 5 series a
    few years ago, the petrol was *more* economical.
    #88
  9. darsy
    Andy Hewitt Guest
    They do normally rattle first, yes. It can be hard to decide if its the
    chain or not though. Quite often you'll lift off the covers to find the
    plastic guides are in peices in the sump, anf the chain has ground away
    on the metal posts, leaving filings floating around the oil system.
    That's done quite well.
    I always liked those.
    They all did that in those days.
    Fucking ugly IMHO, otherwise I agree.
    That's summin' like it :)
    IIRC some of the early ones used the old Rover V8, which was an OK lump
    to use. Then again, what do you expect from a bloke called Trevor?
    It's just that final attention to detail really. Just look at even the
    hidden castings. The Jap suff looks finished and smooth, others you'll
    find sharp edges and casting lines left behind. They also think more
    about the assembly as well, and use better quality fixings.
    Believe it or not, but spending a little more on good quality fixings
    actually reduces production costs. There was an article in a motoring
    magazine a few years ago that showed that by spending a few pence more
    on better screws, meant they could be inserted faster. The time saved
    was greater than the cost to manufacture them.
    It's really their whole philosophy, make it better, and it's better to
    make IYSWIM?
    #89
  10. darsy
    Andy Hewitt Guest
    I'll bet. I'd suspect that truck engines only evolve, rather than get
    created.
    #90
  11. darsy
    Ginge Guest
    Not convinced, Take my trip to the office, I do the 57 mile run to the
    office in around an hour.. that's twisty country lanes (somewhere
    between 4K and the redline), 3 junctions of crawl on the M42 in rush
    hour (somewhere around 1200RPM, if I'm lucky).. then another stretch of
    country lanes.
    Admittedly I have had my fuel consumption down to 207 miles from a £38
    tank worth of fuel too.. but that's not average, and was the result of
    sustained 3 figure speeds.
    Ginge, Nov 2, 2004
    #91
  12. darsy
    Ginge Guest
    Maybe... Your curious scandanavian automobile certainly is.
    Ginge, Nov 2, 2004
    #92
  13. darsy
    SteveH Guest
    It's not that shocking considering it's power output. (130-ish bhp?).
    SteveH, Nov 2, 2004
    #93
  14. darsy
    SteveH Guest
    It's only a posh Vectra....
    SteveH, Nov 2, 2004
    #94
  15. darsy
    Ginge Guest
    Shocking when both the VW and Vauxhall 1.9's units do far better for
    both power and economy.
    Ginge, Nov 2, 2004
    #95
  16. darsy
    SteveH Guest
    Depends on the kind of driving. Urban cycle, which I suspect is where
    TOG is racking up his miles at the moment, is under 40mpg for all of
    'em.
    Power is 12ps more for the Vauxhall, so that's not a million miles away
    either.
    I'd be amazed if any car I got my hands on managed to do 40mpg - even my
    Cinq. would only average low 30mpg in my hands.
    SteveH, Nov 2, 2004
    #96
  17. darsy
    Hmm. Doesn't the diesel perform more efficiently than the equivalent
    petrol by using a much higher compression ratio? Or is that a red
    herring?
    ogden, Nov 2, 2004
    #97
  18. darsy
    SteveH Guest
    But it's an extra 12 valves and 2 cams. Added complication isn't good.
    SteveH, Nov 2, 2004
    #98
  19. darsy
    SteveH Guest
    Bad form, but I forgot to add, there's also an additional camchain.
    Sounds like an absolute nightmare to work on - as bad as the quad-cam
    Alfa Boxer.
    SteveH, Nov 2, 2004
    #99
  20. darsy
    SteveH emerged from their own little world to say
    Honda got it wrong with the VFR then?
    wessie, Nov 3, 2004
