OT, anyone got a t-mobile usb stick 110?
Discussion in 'UK Motorcycles' started by gazz, May 7, 2009.
  1. gazz
    gazz Guest
    Want to get a new way to connect to the net when out campin, currently use
    my phone as a gprs modem (phone does 3G, but dosent seem to connect at that)
    connecting via bluetooth to the laptop, but that's 2 sets of batteries to
    keep charged, plus having to put the phone in the roof vent to get a good
    signal (reason revealed later)
    Was looking at getting one of those t-mobile 3.5G usb broadband dongles, but
    cant find any 'technical' info about the fucking thing.
    They say it has an external antenna connector (their words are "slot"!) but
    i cant find out what connector is used, anyone with ones of these able to
    tell me? or even a photo of the external antenna connection.
    i know the built in antenna is supposed to be good, but it's different when
    inside the motorhome, the thing is built of alli sheet, and the window
    blinds have a foil backing to them for heat retention, but that does a
    really good of making the interior a fariday cage, i drop 4 bars of signal
    on all phones in here when the blinds are up.
    Hence i put a mobile phone antenna on the roof years ago (used to use it
    with a pcmcia gprs card, and always got full signal) and have a socket on
    the wall, i just need to know what fly lead i need to make up to connect
    t-mobiles usb broadband stick to the roof top antenna,
    gazz, May 7, 2009
  2. gazz
    bod43 Guest
    Use a USB extension lead and put the whole thing in
    the skylight (or wherever). I understand that there are
    significant losses in an antenna lead.
    bod43, May 7, 2009
  3. gazz
    bod43 Guest
    http://www.panorama-antennas.com/shop/index.html
    Seem to be somewhat clued up on the matter. UK.
    According to them O2 use 2 different sticks, one with
    antenna connector and one without. They do have a
    solution for the no connector case but it works by
    magic (no physical connection, no active components)
    and might not be very good. Seems to be called Modem
    Mate.
    bod43, May 7, 2009
  4. gazz
    bod43 Guest
    This one intrigued me so I did some more digging. This
    has come from a bit of googling and may be crap.
    They seem to use different modems for pay monthly and PAYG.
    correlating the O2.co.uk and panorama-antennas.com
    sites using modem colour and appearance, the PAYG
    ones (white with obvious LEDs) have an antenna
    connection and the pre pay (blackish) do not.
    http://broadband.o2.co.uk/mobile/
    http://service.o2.co.uk/IQ/SRVS/CGI...7561,K=8615,Sxi=9,t=broadband_case,CASE=20312
    PAYG seems to be
    http://www.panorama-antennas.com/shop/3g_networks/O2/huawei_e160/index.html
    pre pay may be
    http://www.panorama-antennas.com/shop/3g_networks/O2/usb_stick/index.html
    There is a third one too - look for yourself.
    bod43, May 8, 2009
  5. gazz
    Do you have 3G coverage where you go camping?
    If the dongle looks like a memory stick, it's probably a Huawei E160. If it
    looks like soap-on-a-rope, it's probably a Huawei E220. Plenty of info out
    there if you google for it by the manufacturer's name and number.
    platypus, May 8, 2009
  6. That does work, but you might need a small parabolic dish to take full
    advantage of it if you're marginal. The OP said he's got an antenna
    there already.
    Not if you do it right.
    Grimly Curmudgeon, May 8, 2009
  7. gazz
    boots Guest
    boots, May 8, 2009
  8. gazz
    gazz Guest
    I usually do, my phone is showing a full 3G signal right now,
    i dunno if it's due to the bluetooth link, but i'm not getting anywhere near
    as fast a connection as i used to when using the phone usb tether.
    looks like a memory stick, so it'll be the E160 then,
    i've noticed t-mobile do 2 sticks like o2 do as bod mentioned, the pre-pay
    jobbie which i'll be getting does mention an antenna 'slot' in the
    description, guess i'll have to toddle off to a t-mobile shop and have a
    look see,
    bet it wont be the same as the fly lead i already have which fitted my 8
    year old t-mobile pcmcia card (pre 3G and all that stuff)
    i do have a 5 meter usb lead routed from the big sky light to above where i
    sit/lay in bed, so i could put the dongle in that, i use it for my wifi
    dongle to get a good signal when i was in germany and they have lots of
    stellplatz's with free wifi,
    i'm on a campsite right now with wifi, but the fuckers want 4 quid an hour,
    or a 24 hour pass for almost 20 quid!! ffs.
    Just i also have the roof top antenna connection right next to me too, and i
    could go from barely 1 bar of signal to full 5 bars on the old gprs card
    when using the roof top antenna,
    gazz, May 8, 2009
  9. gazz
    zymurgy Guest
    I have the Huawei E220. No antenna socket in it. I ended up getting a
    PCMCIA 3G card, which does have the MMCX (or whatever) mini antenna
    slot, which improves reception in marginal areas (like Co. Down). The
    soap on a rope works fine in town, or back in England.
    P.
    zymurgy, May 8, 2009
  10. gazz
    B 650 Guest
    I have an O2 E160, and managed to get a photo of the connector
    http://www.duncanw.net/ukrm/e160.jpg
    Apologies about the shit image quality, only camera to hand was on phone...
    B 650, May 8, 2009
  11. gazz
    gazz Guest
    excelent, cheers for that, looks similar to the one on the fly lead i have.
    gazz, May 8, 2009
  12. There is available a dumb cradle the soap-type sits on which is
    connected to an outside antenna. Unlike much of the other 'signal
    booster' bollocks, these things actually work, albeit a dB or so down
    from a proper connector.
    Grimly Curmudgeon, May 9, 2009
