OT Anyone got a lathe?
Discussion in 'UK Motorcycles' started by Nicknoxx, Nov 8, 2005.
  1. Nicknoxx
    Nicknoxx Guest
    Second son has bought an exotic (www.staticbikes.co.uk) jump bicycle
    frame but it has 14mm dropouts and he has 9mm axles. He needs a couple
    of washers about 4mm thick (exact size to be confirmed) with a hole
    diameter of 9mm and an outside diameter of 14mm.
    Any (helpfuy/relevant) suggestions welcome
    Nick Brooks
    GN125 ('till test passed)
    1960 SWB Landrover
    1974 Mercedes Camper Van
    Klein Attitude
    Golf VR6
    Combined vehicle age 90
  2. Nicknoxx
    Nick Brooks Guest
    Nick Brooks, Nov 8, 2005
  3. Nicknoxx
    Ben Guest
    Might be worth looking at some new hubs with 20mm thru-axles and
    bringing them down to 14mm. That'd give him more strength that he'll
    certainly need if he's using a jump bike properly.
    I notice the manufacturer does inserts to bring 9mm axles up to 14mm
    though. Or he could buy their rear hub which isn't too expensive at 80
    quid.
    Bloody odd size is 14mm. Standards are changing slowly to 20mm on the
    front and 10mm on the back for downhill and jumping and staying at 9mm
    for xc frames.
    Ben, Nov 8, 2005
  4. Nicknoxx
    Molly Guest
    Our Bee has a lathe?
    Molly, Nov 9, 2005
  5. Nicknoxx
    Nicknoxx Guest
    Despite what it sais on the website they don't have any converters
    available.
    He could buy their hub but
    a) it's only 36 hole
    b) He's already build a 48 spoke wheel around a Hope hub and Haro rim
    c) he's spent all his money already
    BMX innit?
    Thanks though
    Nicknoxx, Nov 9, 2005
  6. Nicknoxx
    Biffa @ Work Guest
    If you can get summat resembling a technical drawing to me then I'll see if
    there is any spare time in my step dads shop. Let me know what it needs to
    be made out of.
    - http://www.rot13.com/
    Biffa @ Work, Nov 9, 2005
  7. I do indeed, however, I am embarking upon the nausea of moving house as
    of Friday.
    There's always Uncle Nigel....?
    BeelzebubNot@Work, Nov 9, 2005
  8. Nicknoxx
    Ben Guest
    Pah, you don't ever need more than 32 spokes.
    Sounds familiar.
    I assumed it was an mtb based jump bike.
    Ben, Nov 9, 2005
  9. Nicknoxx
    Who is currently working in France.
    Pip, Nov 9, 2005
  10. Nicknoxx
    ginge Guest
    Isn't "working" a bit strong?
    ginge, Nov 9, 2005
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    <Beeeeeep>
    This is WUN Engineering Services. We're not in the workshop until the
    end of the month. Your engineering requirements matter to us, so if
    you'd like to call back then, we'd be delighted to help. Have a *great*
    day.
    <Beeeeeep>
    Wicked Uncle Nigel, Nov 9, 2005
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique, ginge
    <waves wineglass>
    **** orft! I'm working like a bl... ni... hard working person here!
  13. Nicknoxx
    Nicknoxx Guest
    It is. Well sort of. It's MTB size and shape, can run gears and spongy
    forks but has a three piece crank, disc and rim brake mounts and those
    big dropouts.
    Nick Brooks
    1960 SWB Landrover
    Klein Attitude
    Golf VR6
  14. Nicknoxx
    'Hog Guest
    Hurry up, think I'm going to have some CB1 restrictor discs requiring
    some ID machining!
    'Hog
    'Hog, Nov 9, 2005
  15. Nicknoxx
    Just buy a Dremel of file the fuckers out you idle cheapskate.
    Andy Bonwick, Nov 9, 2005
  16. Nicknoxx
    'Hog Guest
    Well I would but if you read up the plan was for them to look very
    original. Then again by the time WUN has finished with them.......
    'Hog
    'Hog, Nov 9, 2005
  17. Nicknoxx
    I wouldn't imagine the originals are anything better than rough old
    cold stamped blanks so a Dremel will make them look better.
  18. Nicknoxx
    Yep. That's WUN.
    You know, you might just have something there.
    Pip, Nov 9, 2005
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, 'Hog
    <sniff, sniff>
    Cor! Stinky!
    <inspects 'cast-by' date>
    Ah! That would explain it.
    <swims away>
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Pip
    <bottom lip trembles>
    Et tu, Ginga?
