Ordering parts from a trade only place
Discussion in 'UK Motorcycles' started by CampinGazz, Jun 18, 2004.
  1. CampinGazz
    CampinGazz Guest
    Finaly found a place that does ecery single part i need for the 1985 Suzi TS
    125 X, from swing arm bushes that seem to replace the whole stoopid assembly
    of needle roller bearings, metal bushes, spacers, oil seals, more spacers,
    caps and so on (£100 quids worth of metal there) to crank bearings, seals,
    gasket sets, even light switch gear.
    Too good to be true tho.. they're a trade only supplier, anyone heard of
    Stainforths ??
    Local bike dealers dont know them, and arent interested in ordering me parts
    from them, it's be a bit of a hassle for me to pretend to be a dealer and
    set up an account.. just to order a few parts from them :) we are a limited
    company.. just computers not bikes.. and it's not me.. me dad.. IT
    contractor and all that.
    Anyhoo, anyone know where i may find a place that deals with these people..
    http://www.staniforths.com/index.htm
    i guess i should ask them direct, but i was kinda hoping there's someone on
    here who orders stuff from them, and can get me some prices and let me order
    some parts through them.. i'll pay a little bit towards the trouble of
    someone doing that if i can get parts near trade prices of course.
  2. CampinGazz
    CampinGazz says...
    They're reasonably big and have a good enough reputation within the
    trade. I'm surprised your local dealer hasn't heard of them, cos quite a
    few independent bike shops use them for pattern parts.
    Lozzo, Jun 18, 2004
  3. Staniforths. They're a long old-established wholesaler, and they don't
    deal with the public, only with shops.
    So tell your dealer to order from them. OK, you tried that. Go to
    another dealer, since this one is shite.
    Bills mounting up already, aren't they? ;-))
    The Older Gentleman, Jun 19, 2004
  4. CampinGazz
    JB Guest
    Not that he didn't get fair warning on the prices on the suspension
    components! I was amazed at how needlessly complicated the Suzuki "Full
    Floater" back end was when I bought one for the SO. Also when he gets his
    new crank bearings and finds he can't just bodge them on there (assuming he
    can get the old one's off before bolloxing the crank webs), then it's off to
    a good MotoX dealer who can do the crank for £30-40 or so.
    The joy of Ebay and SOBs.
    JB
    JB, Jun 19, 2004
  5. CampinGazz
    CampinGazz Guest
    I expected that with any machine i bought, so far we've spent about 50 quid
    on it, and it was fine untill i decided to 'whip' the engine out to replace
    the crank bearings, as the engine vibrates quite a bit.. it does have 23k
    miles on it, so i did expect that,
    That's true, but once i've replaced these bearings, and grease them up every
    year, they'll last another 17 years or so, that's the reason i'm doing the
    crank bearings.. actually replacing all the bearings in there i can find,
    the biggest ones are 8 quid, smaller ones 3 to 5 quid, so i may as well bung
    new uns in while i have the case appart, but when i've finished, the engine
    will be fit for another 15k or so.. which is how long they're supposed to
    last, this one has had top end re-builds before, but the crankcase has never
    been appart.
    Crank shaft bearings are already out, came out easily.. heated the cases up
    in the oven a bit, and pushed them out, jury rigged a press.. bottle jack
    pushing against a roof joist, (near the wall for strength) length of wood
    for the extension, sockets used for spacers/pushers on the bearings, poped
    out easily,
    I'm not attempting to seperate the crank shaft it's self yet, that'll be
    taken to an engineering co with the proper presses etc to replace the big
    end bearing,
    Wasn't an ebay motor.. responded to an ad in the local paper for a DT125,
    ended up with the TS for half the price, even if i'd have bought the DT, or
    even the kmx they had, i'd have prolly had the suspension appart for
    re-greasing, then found seized bushes etc, so would be in the same
    position.. just suzuki decided to make things harder with the full floater
    swing arm,
    CampinGazz, Jun 19, 2004
  6. Greease them up? How do you think two-stroke bearings are lubricated?
    Sheesh.
  7. Bad form - ah. Suspension bearings. Not main bearings.
  8. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember
    (The Older Gentleman) saying
    something like:
    The last twostroke gentleman's motorcycle to have individually
    greaseable bearings was the Spagthorpe GoLightly - a mere stripling of a
    machine, with three horizontally opposed cylinders of some 2.5litres
    displacement per cylinder. Piston ported, with inspection chambers, the
    rider had to take great care the ports didn't open up during riding as
    his leg could be sucked into the cylinder.
    Production was halted in 1904 when the supply of bearing grease was
    found to be contaminated with coaldust, which gave rise to crankcase
    fires.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Jun 19, 2004
  9. CampinGazz
    mb Guest
    [snip]
    You expected to have to replace the crank bearings after 23k miles =:-O
    mb, Jun 19, 2004
  10. CampinGazz
    mb says...
    It's a TS125 that has probably been in the hands of a few clueless
    teenagers, I'd expect to change them after 10K miles.
    Lozzo, Jun 19, 2004
  11. .....and if it's been run out of two-stroke oil by some numty teenager,
    even earlier than that.
    The Older Gentleman, Jun 20, 2004
