In Sean triped:[QUOTE] Andy Ashworth let forth with a mighty belch and uttered : I'm intruiged now. Does the MEMS feature a knock sensor?, does this Optimax stuff play games with the O2 sensor?, roughly how long would it take a unit to recalibrate if it didn't get its usual O2 signals?. Does it advance the ignition until it detects the beginning of knock then hold/retard the advance?. I'm curious as to how it calibrates.[/QUOTE] Knock is ignition related while O2 is fuel related. Here's a very brief description of how fuel and ignition work.... Fuel - the basic requirement of a fuel injection system is to inject just enough fuel to make the catalyst work at its most efficient; this occurs at a air-fuel ratio of 14.7:1. So to determine fuel amount we need to know how much air is going into the engine. This can be achieved by one of two methods - either measure the flow directly or determine the amount from the manifold pressure. The first relies on expensive (but accurate) sensors, the second relies on the basic gas equation, i.e. PV = nRT (P=pressure, V=volume of cylinder [constant], n = number of moles of gas [i.e. amount], R = Gas constant, T = air temperature [in deg K]); this calculation can, believe it or not, be carried out relatively straight-forwardly even on an old Intel 8096 8-bit processor. Once you know the mass of air, the mass of fuel calculation is a doddle, and this can be used to determine the injector pulse-width. Ignition - the basic function of ignition is to set fire to the fuel we have so carefully injected in the preceding paragraph! This is done by creating a spark, however the timing of this spark is critical - too late and no power is the result; too early and we have the dreaded knock. The spark is timed such that peak pressure from the combustion process is achieved just as the piston hits Top-Dead-Centre (TDC). The combustion time is constant, so as the engine speed increases the spark will need to be triggered earlier with respect to he angle of rotation, hence the term ignition advance. The load of the engine also affects the combustion time, so the basic ignition timing is determined form a matrix of speed and engine load. Knock is detected by means of a sensor tuned to the resonant frequency of the engine block usually mounted between cylinders 2 & 3 (on a 4 cylinder car). When knock is detected the ignition is retarded, i.e. fired later, which reduces the damaging effects of this phenomenon. BTW, I understand that during the testing of the K-Series engine in the late 1980s, early 90s (my era) the engine proved extremely difficult to break and was not susceptible to destructive knock no matter how hard the engineers tried. Also a standard production unit was takne off the line and revved to its maximum which was recorded as somewhere in the region of 13000. Cheers
