Optimating a very dead battery?
Discussion in 'UK Motorcycles' started by gomez, Apr 4, 2005.
  1. gomez
    gomez Guest
    At the weekend, I tried to charge up the battery on a friend's bike
    which has been parked up in my garage for several months using the
    Optimate. Only the green power light came on and after 24 hours none
    of the charge lights came on.
    So, tried a bog-standard charger instead which originally didn't seem
    too hopeful either but when I checked it just now after another 24
    hours its meter was showing signs of life. Just changed back to the
    Optimate and now it is showing the first couple of charge lights.
    So what do you reckon the chances of saving the battery are? The
    battery was brand new last summer.
    gomez, Apr 4, 2005
  2. gomez wrote
    Slim if it has been a day to just show signs of life on a normal
    charger.
    Still if you don't try you will never succeed will you, so it was well
    worth the very small effort it cost.
    steve auvache, Apr 4, 2005
  3. gomez explained on 04/04/2005 :
    As a last resort if that fails, try _fully_ discharging the battery,
    recharging it with the + to - and - to +, discharging it again followed
    by a recharge with the correct polarity. That should remove the
    sulphate buildup on the plates and (perhaps) restore it back to full
    health.
    Harry Bloomfield, Apr 4, 2005
  4. Harry Bloomfield wrote
    What!!!
    I am not so sure that particular piece of advice is correct given the
    competency level and ability to understand risk that the majority of
    this newsgroup possess.
    Not one of your strong point presumalabley.
  5. gomez
    Mikey Guest
    If the battery isn't a sealed for life or gel type, you might want
    to check the fluid levels in each cell. I had a similar problem
    last month on my R80GS and recovered the battery by filling the
    cells up using distilled water.
    Mikey
    Mikey, Apr 4, 2005
  6. gomez
    gomez Guest
    Not sure I am going to risk that that. It will be my friend's call,
    so if she wants to try it, she can wheel the bike outside as far away
    as possible then I will stand well back with 999 on speed-dial.
    gomez, Apr 4, 2005
  7. gomez wrote
    Nah I wouldn't if I were you, stick to what you know eh, prolly safest.
    She?
    Did I mention that I do on site training as well, not just this distance
    learning stuff.
  8. gomez
    gomez Guest
    It is a gel type.
    gomez, Apr 4, 2005
  9. gomez
    gomez Guest
    She is probably a bit out of your league
    gomez, Apr 4, 2005
  10. There is absolutely no difference in the design of the cells, other
    than one of the poles having one more plate than the other. A fully
    discharged battery, is a fully discharged battery and it can be
    recharged either way, except that it is designed to work a little
    better (due to the layout of the plates) with the correct polarity.
    Now does anyone want to know how to recover/repair neglected NiCads :D
  11. most chargers will pick up the incorrect connection and shut down , unless
    of course the battery is showing no voltage whatsoever , if its this far
    gone then it will be fucked anyway
    steve robinson, Apr 4, 2005
  12. gomez wrote
    There isn't a woman who isn't a virgin in one of the biblical senses
    been born wot is out of my league.
    What does seem to be out of my league though is convincing them that I
    ain't.
  13. gomez
    gomez Guest
    If you can ride hard all day and party hard all night and still be
    fresh as a daisy then you might stand a chance. GSH essential.
    gomez, Apr 4, 2005
  14. gomez
    Eiron Guest
    gomez wrote:
    Kipling?
    Eiron, Apr 4, 2005
  15. gomez wrote
    Kin trademark mate. Friction burns an optional speciality.
    I like a good joke, as much as any man. Some things, obviously and
    there is no real need to mention the details here, I get a bit sensitive
    about but then doesn't everybody.
    This for example, mailed to me today by one of my window licker mates:
    Q. How do you make an Iranian Girl pregnant?
    A. Spunk on the floor and let the flies do the rest.
    How offensive can you get? Were it not for that fact that he would just
    dribble back at me I would give him a good telling off.
  16. gomez
    gomez Guest
    She might be persuaded. She is up for most things.
    gomez, Apr 5, 2005
  17. gomez
    gomez Guest
    Can you do two hours sitting in a pool of petrol? ( I only lasted
    twenty minutes).
    LOL. Mind if I use that on her tomorrow?
    gomez, Apr 5, 2005
  18. gomez
    gomez Guest
    Oh yes, You must know her well. Our mutual friend, perchance?
    gomez, Apr 5, 2005
  19. gomez
    gomez Guest
    The lights on the Optimate show no change from when it was first
    switched on so things are not looking good. It might be worth putting
    the other charger back on and see what happens before trying out your
    tip.
    gomez, Apr 6, 2005
