Optimates and Alarms
Discussion in 'UK Motorcycles' started by darsy, Feb 15, 2005.
  1. darsy
    darsy says...
    Sawbridgeworth BMW should have a genuine BMW one, or you might try
    Maplins.
    Lozzo, Feb 15, 2005
  2. darsy
    on balance, I've decided to get one of the Optimate "permanent
    connection" leads, that ends in a connector that connects straight to
    the "long bit" of the standard Optimate connection lead - 2 quid.
    darsy, Feb 15, 2005
  3. Good thinking. You could buy a couple of "optimate end" ones and attach
    them to other appliances so you can do other stuff while your battery
    charges like GPS or whatever else has a temporary connection to your
    battery.
    Hey, if you left the engine running, you could even use one of these:
    http://www.outdoorgear.co.uk/eshop.asp?wce=53104501&wci=product
    Whinging Courier, Feb 15, 2005
  4. darsy
    darsy says...
    That's exactly the thing I was talking about. Accumate plugs are smaller
    than Optimate ones. Make sure you get the correct one. Personally I'd
    just take my charger to HG and see what lead matched the plug on the
    charger.
    Lozzo, Feb 15, 2005
  5. darsy
    darsy says...
    Which is exactly what I was advising you to buy. Maybe we got our wires
    crossed (no pun intended)
    Lozzo, Feb 15, 2005
  6. darsy
    yeah - until I looked at the Accumate web page, I didn't realise they
    sold these - I thought I would have to buy a mini ciggie lighter socket
    and wire it in myself.
    thanks anyway.
    darsy, Feb 15, 2005
  7. I got one of these in the box with my recently purchased optimate.
    Adie
    Triumph 955iSS / GSF1200 bandit / CG125
    Adrienne M Bonwick, Feb 15, 2005
  8. actually cancel that I got one of these
    http://www.accumate.co.uk/it020006.html
    Adie
  9. This is what I do. I have the special adaptor for the BMW but I have
    attached the clips, cable and socket on the Honda and Kwak and simply
    attach the Optimate as necessary when it needs a charge. About the only
    thing I can do in terms of "repairing" a bike is deal with dud
    batteries.
    There is the "fix to the battery on the bike" cable and also a "clip to
    the battery when it is outside of the bike" cable with every new
    Optimate. They changed the design of the connectors between Version 2
    and Version 3 of the Optimate which can cause some complications.
    Paul Corfield, Feb 15, 2005
  10. darsy
    simonk Guest
    Shit, I always forget that.
    I know ...
    simonk, Feb 15, 2005
  11. darsy
    simonk Guest
    Assuming it's the "seven shamurai", I'd just blame shitty kwak late-70s era
    electrics, then.
    If it's the blade, well, obviously it's the alarm's fault ...
  12. They do - mine is mounted so that it comes out under the side of the
    seat behind my legs. I put a bit of tape over the end to stop the road
    grunge building up on the contacts but thats about it.
    And it means I don't have to take the seat off to charge the battery.
    Phil
    Phil Launchbury, Feb 16, 2005
  13. darsy
    Most of my bikes have one of those. Worth noting, the on-bike bit is
    'shrouded male' and on the Guzzi has corroded to the extent of no longer
    making a connection - that is after 8 odd years mind.
    Leading me on to: I was recently lent (by a motorcycle shop) a set of
    electrical connector cleaners, whether that's what they're for I don't
    know, but it contained what appeared to be wire wool pipe cleaners,
    minature chimney sweep brushes and the like.
    Where can I get some?
    (I know I could always ask them but that would be missing the point).
    sweller, Feb 19, 2005
  14. darsy
    Aha! Just noticed that they're weatherproofed the early ones I've got
    aren't, which explains something.
  15. darsy
    Sean Guest
    Maplins.
    Look for a PCB cleaning brush as the bristles are glass fibre, so less risk
    of leaving conductive strands floating about in the connectors.
    Sean, Feb 19, 2005
