Ooops
Discussion in 'UK Motorcycles' started by Mark Derbyshire, Mar 25, 2005.
  1. Mark Derbyshire
    Eiron Guest
    Also stops the fluid absorbing water from the atmosphere
    whilst allowing the level to drop as the pads wear.
    Eiron, Mar 26, 2005
    #41
  2. Well, yes, but surely the m/cylinder cap on its own is tight-fitting
    enough to do that?
    The Older Gentleman, Mar 26, 2005
    #42
  3. But, the less fluid you have in the res, the more air you have, so the
    more likely it is to be absorbed. The bellows minimise this.[/QUOTE]
    Yep, OK, that makes sense, I'm convinced.
    #43
  4. Mark Derbyshire
    Eiron Guest
    I'm not going to remove the lid just to find out but ISTR
    that the bottom of the bellows is a tight fit on the reservoir
    and the top of the bellows or the underside of the lid has a
    channel to allow air in without contacting the fluid.
    It's better than car brake fluid reservoirs which are just leaky.
    Eiron, Mar 26, 2005
    #44
  5. Mark Derbyshire
    SP Guest
    Oh, I dunno. When you specifically tell someone that you don't want
    them to touch your bike, go into the house to make a brew and return
    with said brew(s) to find bits of your bike on the drive, then it is
    really annoying.
    Especially on the occasion when 'mr helpful' managed to lose a washer
    down the centre of the engine on the GPX, as I was in the process of
    replacing the camchain in-site and didn't want to have to take the
    engine out of the frame.
    I can relate to Lady Nina's frustration about it.
    Lesley
    CBR600FW
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    SP, Mar 26, 2005
    #45
  6. Champ wrote
    Wimmin eh?
    steve auvache, Mar 26, 2005
    #46
  7. Mark Derbyshire
    Ginge Guest
    I think there's a moral to this story....
    I'm just not brave enough to say what it is. :)
    Ginge, Mar 26, 2005
    #47
  8. Mark Derbyshire
    Lady Nina Guest
    Know all the facts before you make judgements?
    Lady Nina, Mar 26, 2005
    #48
  9. Mark Derbyshire
    mups Guest
    Ginge says...
    A woman only wants one one thing bleeding at a time...
    mups, Mar 26, 2005
    #49
  10. Mark Derbyshire
    Ben Guest
    To be honest, I get quite annoyed if someone moves my bike without
    asking. Mainly because I'm worried about someone dropping it.
    Someone did try and move it at work the other day and cracked the
    front mudguard with the disc lock.
    Ben, Mar 27, 2005
    #50
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, The Older
    I would follow this line of reasoning:
    1. It must cost *something* to make and fit the Little Rubber Bellows.
    2. The Nips haven't built a globally successful motorcycle business by
    being thick.
    3. The Nips think the LRB is A Necessary Item.
    4. The LRB is likely to be ANI.
    Wicked Uncle Nigel, Mar 27, 2005
    #51
  12. Mark Derbyshire
    Kiran Guest
    I suppose as long as you didn't ride it, there'd be no reason to be
    suspicious.
    Kiran, Mar 27, 2005
    #52
  13. Come on chaps - you're all intelligent fellows...
    The cap must have a hole in it to allow in air to replace the fluid
    that goes into the calipers and to ensure that the resovoir doesn't
    become pressurised and force the brakes on.
    A car stays, pretty much, shiny side up all the time. Bikes tip around
    and fall over. So the way to allow air into the resovoir without
    letting the fluid out needed to be found...
    That's why the little rubber bellows are there.
    Simon Atkinson, Mar 27, 2005
    #53
  14. Mark Derbyshire
    Ben Guest
    I wouldn't be as annoyed, but I still feel it's a matter of politeness
    and I should have been asked.
    This would obviously be different in an emergency of someone about to
    reverse into it or summat.
    Ben, Mar 27, 2005
    #54
  15. Where were you when I needed you?
    The Older Gentleman, Mar 27, 2005
    #55
  16. I think it's rag week in Derby.
    #56
  17. Mark Derbyshire
    Simon Atkinson says...
    Students - you've got to love them.
    All that time to themselves for shagging and doing drugs, and they still
    find time to type centuries old jokes on a few photocopied sheets of
    paper and get scantily clad slappers to flog them off to unsuspecting
    middle aged men.
    Lozzo, Mar 27, 2005
    #57
  18. It's all I live for.
    #58
  19. Mark Derbyshire
    rb Guest
    Ginge wrote:
    I think so, I went out to Tesco this afternoon but they were already
    shut so my watch must be wrong.
    rb, Mar 27, 2005
    #59
