only if I push it?
Discussion in 'Motorbike Technical Discussion' started by troubled, Jul 4, 2006.
  1. troubled
    troubled Guest
    My bike will only start if I push it, and very easily. when I try the
    electronic ignition I get nothing. I have replaced the battery and
    plugs. when I use the starter it turns,but the bike doesn't want to
    fire over. after running the battery down in attempt to start it I
    will go to the street and push it and the beast will come alive so
    easily.
    Why won't the starter kick it over?
    It is on a 86 ninja zx600.
  2. troubled
    FB Guest
    Maybe the the voltage drops too much when the starter is turning so the
    electronic ignition won't operate? Some other posters have suggested
    that this can happen. Check all the electrical connections from the
    ignition switch, through the kill switch to the coils and on to the
    electronic ignition module to see if you have 12 volts everywhere.
    Check all connections to be sure they are clean and tight.
    OTOH, you might be running into a problem with Kawasaki's diabolical
    sidestand safety interlock system. When you are pushing the starter
    button, are you sitting on the motorcycle with the sidestand up, and
    pulling in the clutch and the starter is spinning the engine madly but
    it doesn't fire?
    Kawasakis are wired so the starter will crank the engine over but you
    won't get any spark if the sidestand is down or the sidestand safety
    interlock switch doesn't work right.
    Or, are you standing beside the motorcycle with the sidestand down and
    trying to start the engine?
    Try disconnecting the sidestand switch and jumpering across the two
    pins of the connector coming from the motorbike's wiring harness and
    see if the engine starts.
    I have jumpered the connector on my Kawasaki duel sport after the
    sidestand switch gave me a lot of trouble.
    Then there is the possibility that your carburetors have dirty idle
    jets. When the idle jets get all gummed up, the engine will stall and
    the owner will adjust the idle speed screw to make the engine idle
    faster.
    The problem with doing that is the engine becomes very hard to start
    because the throttle butterflies are open too far. There isn't enough
    engine vacuum to suck mixture through the starting enrichener bypass
    system.
    You can clean the carburetors out by putting 3 or 4 ounces of
    Berryman's B-12 Chemtool Choke and Carburetor Cleaner in a full tank of
    gasoline and riding slowly until the engine idle speed increases. That
    means the B-12 is cleaning out the idle jets and you can adjust the
    idle speed lower by turning the master idle knob.
    If you live in a part of the world where you call gasoline "petrol",
    look for a carburetor cleaner that contains xylene, acetone, and methyl
    alcohol, or maybe toluene to clean your carbs while you ride.
    FB, Jul 5, 2006
