One up on Team UKRM
Discussion in 'UK Motorcycles' started by Salad Dodger, May 30, 2005.
  1. Salad Dodger
    Salad Dodger Guest
    I appear to have a working clutch! [1]
    <does "Numa Numa" dance> :)
    If anything, it feels a little heavy.
    No driveline slop from the new shaft, either.
    Michelin radial rear may take some getting used to, though.
    <does "Numa Numa" dance again>
    [1] apologies to residents of E14 for the last ten minutes.
    | ___ Salad Dodger
    |_\_____/_| ..75127../..18653.../..3196./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR Landmarks: 12 Pts: 220 Miles: 914
  2. Salad Dodger
    Robbo Guest
    The mental picture of a larger than average person doing a strange dance not
    far from Canary Wharf at 8 in the evening conjures up thoughts of warnings
    being issued for earthquakes and evacuation of entire office blocks !
    Robbo
    Trophy 1200 1998
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, May 30, 2005
  3. DOH, mine is still slipping. Is it common for the ZX9R-C1 clutch to start
    slipping at 18k?
    eric the brave, May 30, 2005
  4. Salad Dodger
    JB Guest
    I used BT45s for over 40k on my FJ1100 and then picked up a *very* cheap set
    of Avon Azarros. I''m now on my second set of these and I'll have to
    disagree with the FJ club on this issue. I'll never go back to BT45s, ever,
    ever. The FJ is not exactly a nimble beast, but I can chuck it around all
    over the place on the radials with much more confidence now than I ever
    could on the BTs. (My current commute is a 50 mile each way mix of fast A
    roads and cracking country lanes/B roads).
    Just my tuppence worth.
    JB
    JB, May 30, 2005
  5. Thanks, I'll order some new plates from Cradley tomorrow then.
  6. Salad Dodger
    Pip, May 30, 2005
  7. Salad Dodger
    Salad Dodger Guest
    I'd be more worried about valve float at those kind of revs.
    | ___ Salad Dodger
  8. Salad Dodger
    Salad Dodger Guest
    The Big Honda Book of Fables and Fibs said exactly the same.
    I diddit wivva paintbrush.
    All nineteen of 'em.
    Of course, when you clamp it in the vice, to re-fit the spring, it
    oozes out all over the shop.
    | ___ Salad Dodger
  9. Salad Dodger
    eric the brave says...
    I'm shocked that the rev counter goes that high. Try keeping it under
    the red-line and see if that works.
    Lozzo, May 30, 2005
  10. Salad Dodger
    Beav says...
    It's the way I was taught too.
    Lozzo, May 31, 2005
  11. Salad Dodger
    Salad Dodger Guest
    As I mentioned, when I had the old ones apart, some of them were "dry"
    in patches. Or seemed it. Could this have been the root of the problem
    all along?
    One other thing I've picked up - 97/98 GL1500s have different clutch
    lifting mechanisms to those either before, or after.
    The 99-01 models use the "old" version. Suspicious?
    | ___ Salad Dodger
    Salad Dodger, May 31, 2005
  12. LOL.
    eric the brave, May 31, 2005
  13. The funny thing is it started when I changed the oil. It did it in
    France most of the time. But flat out on the way home it gripped again.
    I guess it's duw to the viscosity of the oil when the motor gets really
    warm.
    simonb
  14. You may be onto something here. Did you use a fully synthetic car oil,
    or a bike oil? And what grade. I've known more than one bike that
    slipped on 20/50 (which wasn't the right grade for the machine) until it
    was warmed up.
    The Older Gentleman, May 31, 2005
  15. From a previous post I did ( sorry for the length I don't seam to be
    able to post a link in google groups.)
    Is Motul 5100 Ester OK to use in the ZX9R?
    SimonB - South Wales. BOF#32
    email simonb_at_zapik_dot_co_dot...@­foo.com
    http://simonb.zapik.com mine
    http://sportstourer.org for all your touring needs.
    Lozzo Mar 26, 8:40 am show options
    Newsgroups: uk.rec.motorcycles
    Date: Sat, 26 Mar 2005 13:40:51 -0000
    Local: Sat,Mar 26 2005 8:40 am
    Subject: Re: Motul Oil
    Reply to Author | Forward | Print | Individual Message | Show original
    | Report Abuse
    Been to Hein Gericke?
    I've used it in all of my bikes over the past few years, so I don't see
    any reason why not. It's a semi-synth 10W/40 oil, as recommended by
    Kawasaki.
    Lozzo
    ZX-9R
    "As know it all cunts go he actually has half a clue"
    (tm) Steve Auvache
    eric the brave Mar 26, 11:16 am show options
    messages by this author
    Date: Sat, 26 Mar 2005 16:16:33 +0000
    Local: Sat,Mar 26 2005 11:16 am
    | Report Abuse
    Er no?
    Jolly good. Time for an oil change then.
    Bear Mar 26, 11:56 am show options
    Date: Sat, 26 Mar 2005 16:56:49 -0000
    Local: Sat,Mar 26 2005 11:56 am
    | Report Abuse
    I was told to use fully synth after the first 1,500 miles, but I guess
    all good quality oils are pretty much of a muchness. Although it didn't
    need a single shim change in 35,000 miles ...
  16. Salad Dodger
    Salad Dodger Guest
    ... and I still do.
    I have spent the entire day overtaking stuff, simply because I could.
    A brief trundle around the SE was a good way to spend a day in mild
    sunshine.
    Set off after dropping madam at work, and headed off to Broadstairs,
    like you do.
    A2/M2 was despatched with ease, and was used to test the previous
    Achilles' Heel: the slippy clutch on uphill overtakes. Not a hint of
    it.
    There was a brief shower as I passed Manston, but it soon passed, and
    Mr Crampton's water tower was easily located.
    From there, back up the A299, then a little cross-country jaunt down
    the A28 to Northiam. Through Battle, then a diversion due to bridge
    work led me onto the coast at Pevensey. Up over Beachy Head (not
    literally) and down into Friston, to get a piccie of the Tapsel Gate
    at thechurch.
    Landmark #3 for the day was at Shoreham. Piece of cake - straight
    along the A259, keep the sea on left. Simple.
    So why was the GPS insisting that I should turn right at every
    junction, then?
    That would be so I could get on the A27, and save ages, I guess.
    Perhaps I should give it a little more credit, sometimes.
    That Roedean School's a bit imposing, isn't it?
    Anyway, after fighting along the coast, I cut inland and along one
    junction of the A27 before visiting the airport, to get a piccie of
    the War memorial there.
    A drink, and a Topic bar later, I was off to Surrey.
    Merstham, site of the first public railway in the world. Okay, it was
    horse-drawn, but it was still on rails.
    I couldn't find the site at first, and asked an old fellow in an RAF
    blazer if he knew where it was. It turned out he needed to walk past
    it on his way home, so off we went, me riding the Wing at a gentle
    walking pace. As we made our way, the old chap told me he'd just been
    off for a squadron reunion over the bank holiday weekend.
    I checked his blazer badge, and, on reflection, foolishly said "35
    Sqdn, isn't that the Pathfinder force?"
    His eyes lit up, and I was regaled with many tales of derring-do, such
    as Halifaxes dropping mines on the Tirpitz, etc.
    About an hour later, he was in desperate need for a pee, so repaired
    to the pub across the road. Sensing an opening, I wished him well, and
    took my photo and scarpered.
    Final landmark was the Churchill statue on the Green in Westerham,
    then up the A21/A20 and home.
    The clutch didn't slip once - even under *extreme* provocation.
    That awful rumbling's gone away - new drive shaft.
    I'm glad I wear specs, or that bird shit would have gone right in my
    eye.
    | ___ Salad Dodger
    |_\_____/_| ..75409../..18748.../..3196./.19406
    '^' RBR Landmarks: 18 Pts: 305 Miles: 1193
  17. Nice to get the chance to talk to one of the old codgers before they're
    all gone. A helluva lot of them never spoke much about it and left so
    much untold.
    Grimly Curmudgeon, May 31, 2005
  18. Salad Dodger
    muddycat Guest
    BTDT ruined my t-shirt cleaning off the seagull shit.
    Are you going to post the pictures of this year's RRB or wait till the
    end?
    muddycat, May 31, 2005
  19. Salad Dodger
    Salad Dodger Guest
    All clue dropping has been thoroughly kiboshed this year, on pain of
    disqualification.
    I shall have to temper my reports accordingly.
    All photos will be posted at the end.
    | ___ Salad Dodger
  20. Salad Dodger
    muddycat Guest
    Right then. <sulks> I'll wait till the end then.
    muddycat, Jun 1, 2005
