One for the engineering types.
Discussion in 'UK Motorcycles' started by toad_oftoadhall, Feb 16, 2006.
  1. I've got a Givi rack for a B12 with most of the fastenings missing.
    I can easily bodge most of it but there are a two things I can't bodge
    so easily.
    Namely spacers/bushes to slot over bolts.
    A spacer to slot over an M6 bolt: 14mm long 10mm external diameter.
    A spacer to slot over an M8 bolt: 22mm long 12mm external diameter.
    Steel would be best. It does need to be strong.
    I've tried places that sell standoffs, & all my local fastening places.
    At a push I could just use a pile of washers (I think most pipe would
    be too thin) but I'd rather do it nicely and buy them off the shelf.
    Anyone know somewhere that will do this kind of thing without a 100
    euro minimum order?
  2. toad_oftoadhall
    zymurgy Guest
    Did you go to the parts counter and ask for a "long standoff" ? ;-)
    P.
    zymurgy, Feb 16, 2006
  3. toad_oftoadhall
    antonye Guest
    B&Q. Seriously!
    The sell tubing in there, in various lengths, which you can cut to
    the size you want. Take a couple of each bolt you need sleeves
    for and see which ones fit.
    I used it to sleeve the 620 engine, which takes an M10 bolt, down to
    use the 600 engine's M8 bolt, rather than arsing around with drilling
    the frame and buying a new bolt. For a 1/2 metre length I think it
    was about 3 quid or so.
    HTH,
    antonye, Feb 16, 2006
  4. toad_oftoadhall
    said...
    Givi sell fitting kits quite cheaply. Ask at your local bike shop or
    another Givi stockist.
    Lozzo, Feb 16, 2006
  5. I take your point but I'm a little reluctant to throw away a perfectly
    good fitting kit when all I need is two pairs of spacers that are
    probably worth 3p each.
    FWIW I've talked to Givi and the kit is £70 quid and they don't sell
    spares for fitting kits.
  6. wrote
    No need to throw it away, I'll give you a tenner for it and as a bonus
    you save 12p on spacers. Can't say fairer than that can I?
    Another 70 quid you could save.
    At this rate you will be a wealthy man by half past seven.
    C'mon, a tenner?
    steve auvache, Feb 16, 2006
  7. toad_oftoadhall
    said...
    Woo. They used to do just the nuts and bolts/spacers on their own. 70
    squids is a bit much.
    Lozzo, Feb 16, 2006
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    send me a snail mail address and I'll turn a couple up and bung them in
    the post.
    Steel will corrode so you'll have to paint them. Are you sure they're
    load-bearing? Ally won't corrode (as much) and wouldn't need painting.
    Wicked Uncle Nigel, Feb 16, 2006
  9. Fraid not:
    Dear <Toad>,
    I am very sorry but having asked the questions for you I have been told
    in no uncertain terms that we are unable to supply spares for these
    kits since they only come complete from Italy,
    Very Sorry
    <Givi Worker>
    GIVI UK Ltd
    Nuts and bolts, of course are no problem. Just bog standard metric
    bolts. But there were few things that would have made my life at bit
    easier and these two collars that I don't fancy doing without.
  10. toad_oftoadhall
    Mark Guest
    : I've got a Givi rack for a B12 with most of the fastenings missing.
    : I can easily bodge most of it but there are a two things I can't bodge
    : so easily.
    : Namely spacers/bushes to slot over bolts.
    : A spacer to slot over an M6 bolt: 14mm long 10mm external diameter.
    : A spacer to slot over an M8 bolt: 22mm long 12mm external diameter.
    Lots of washers?
    Mark
    Mark, Feb 16, 2006
  11. Hi,
    That's a big yes, and much appreciated.
    Have responded with answers to your questions and a snail mail address
    to the address in your header with the letters 'me' replaced with 'co'.
    Somehow I don't think that's right. If not could you mail me to give me
    something to reply to.
    Many thanks.
  12. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    Got it. I'll do it over this weekend.
  13. Thanks. That's a big help.
    toad_oftoadhall, Feb 17, 2006
