One for the engine gurus
Discussion in 'Australian Motorcycles' started by Manning, Jul 31, 2003.
  1. Manning
    atec77 Guest
    didn't the 1st vfr spin in reverse to the later model.. the one with the
    shaft drive out the left.
    atec77, Aug 1, 2003
  2. Manning
    Fireblades!
    (Oops sorry... it's the RIDERS who are backwards.....)
    Knobdoodle, Aug 1, 2003
  3. Manning
    Vulture Guest
    A bit like the 37 litre (yes thirty seven) supercharged Griffon engines
    used in the later model Spitfires towwards the end of WWII. It was said
    that the pilot had to use a bootfull of rudder and some stick to stop the
    aircraft turning off the runway on takeoff, such was the torque reaction.
    Simon
    Vulture, Aug 1, 2003
  4. Manning
    Theo Bekkers Guest
    "Knobdoodle" wrote
    Gogomobiles (not the Dart) and Lightburn Zetas both had two stroke
    engines with no reverse in the gearbox. The engine was stopped and
    started in the other direction to go backwards. Except for the Dart.
    It had a reverse gear.
    My lawnmower engine goes clockwise when viewed from the top. When I
    stick it in reverse it still goes the same way... mmmm?
    Which is the front end of the engine in a VW Beetle? When viewed from
    the front of the car, the flywheel is on the front of the engine and
    turns anti-clockwise. Cylinder # 1 is the one nearest the flywheel,
    the next cylinder is # 3. How about Citroens, where the engine is
    behind the gearbox. # 1 cylinder is closest to the driver.
    Anyone see a trend yet? Neither do I. Viva la difference.
    Theo
    Theo Bekkers, Aug 1, 2003
  5. Manning
    John Littler Guest
    used contra-rotating cranks. (As
    *Benelli, and the foggy petronas also does
    JL
    John Littler, Aug 2, 2003
  6. Manning
    No, I was talking about the two-smokes. It was actually the Paton. (But I still can't remember that German,
    sidecar-engine , Peter Clifford team that Gobert qualified real well at PI but then crashed at the Southern
    Loop first lap. They used to be silver/grey and I think Van der Goorbergh rode a year with them...)
    Knobdoodle, Aug 2, 2003
  7. Manning
    Nathan Smith Guest
    The point I trying to make, was to get him thinking about the larger
    picture.
    And just what is the reason they made them with counter rotating cranks?
    Nathan
    Nathan Smith, Aug 3, 2003
  8. Manning
    So the gyroscopic forces were equally opposed and cancelled each-other out. (Making the engine a non-factor
    in the handling and geometry of the bike.)
    Knobdoodle, Aug 3, 2003
  9. Manning
    Theo Bekkers Guest
    "Nathan Smith" wrote
    When you couldn't see it yourself. :)
    cranks?
    When you gear two cranks together they sort of tend to run in opposite
    directions naturally. It's the easiest way to couple them.
    Theo
    Theo Bekkers, Aug 3, 2003
  10. Manning
    Errmm... I was being serious Theo....
    (Now I'm gonna' be real troubled trying to figure out what it was the Theo thought so wicked!)
  11. Manning
    Nathan Smith Guest
    I know this, hmmm sometimes things get lost in the translation... and
    please, give Clem the reason why you found his post funny...
    Nathan
    Nathan Smith, Aug 4, 2003
  12. Manning
    Theo Bekkers Guest
    I might but not here.
    Theo
    Theo Bekkers, Aug 4, 2003
  13. Manning
    conehead Guest
    Shhhh......Don't mention the o's alzheimer's, Clem
    conehead, Aug 4, 2003
  14. Manning
    Theo Bekkers Guest
    "Knobdoodle" wrote
    I thought you were leading him on. Now I think you may be leading me
    on as well.
    They made them with counter-rotating cranks because that is the
    easiest, cheapest, and most efficient way to couple them.
    Theo
  15. Manning
    Oh; OK, yeah I'd never thought of it that way....
    I was a GP fan during the late eighties when the contra-rotating Yam (and it's clones) was touted as being
    "perfect" while the single-crank Honda was the flawed design.
    Shit; ...you're telling me it was just the low-tech way to do it?!!?
    Damn I feel ripped off!
    (But secretly chuffed that you think I'm waaay smarter than I really am!)
    Knobdoodle, Aug 4, 2003
  16. Manning
    Gary Woodman Guest
    Which V2 500 was that? The transverse one, or the longtitudinal one?
    Gary
    Gary Woodman, Aug 5, 2003
