one for the computer techies
Discussion in 'UK Motorcycles' started by Steve Robinson, May 31, 2006.
  1. Daughters laptop screen goes blank then comes back on when she moves
    the lid/ screen any ideas whats wrong with it likely cost to repair
    the lid does seem to have some play in it
    thanks
    steve
  2. The ribbon connector between the base and the screen panel is probably
    cracked.
    If it's a common make you may be able to get a replacement connector
    from Ebay or online spares places.
    Phil
    Phil Launchbury, May 31, 2006
  3. Steve Robinson
    antonye Guest
    May be an internal switch to detect when the lid closes and
    switches the screen off? Could be worth dismantling the
    case and cleaning it out with a tin of compressed air to
    remove any build-up of dust.
    If there's an external switch (like the little sticky out bit here:
    http://www.ixbt.com/portopc/g-max-n-411/buttons-big.jpg )
    then it still may be iffy - give it a press or ten and see.
    antonye, May 31, 2006
  4. There will be an "umpteen" way connector from the LCD Panel connecting it to
    the Laptop's Motherboard.
    This will normally be your culprit.
    Either the connector won't be seated correctly, or the cable will be
    damaged.
    Normally pretty easy to fix if you know how to get at it.
    Brownz @ Work, May 31, 2006
  5. Steve Robinson
    Dr Zoidberg Guest
    Angle grinder
    Dr Zoidberg, May 31, 2006
  6. Steve Robinson
    Me here Guest
    GAMI
    Me here, May 31, 2006
  7. tried going down the desktop route before i bought her the laptop
    little cow wouldnt have it and as both of my girls can twist me around
    there little fingers i dont bother arguing any more
    pitty the poor bastard that marries them
  8. Ahh, you've visited our repair agents then .....
    Brownz \(mobile\), Jun 1, 2006
